查看: 26399|回复: 4
STM32F0系列MCU中断向量表的重映射
ID:94349 发表于 2015-11-9 14:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    最近使用了一款Cortex-M0内核的芯片STM32F030CC,发现它中断向量表的重映射方法与STM32F10x系列的有所区别,在这里记录与分享一下。
     由于需要通过IAP进行固件升级,所以芯片的FLASH里面要烧录两份代码:一个Boot loader, 一个用户应用程序。理所当然的,在用户应用程序中,必须得重新映射中断向量表。
     可是在ST提供的固件库里,我却没有发现类似于stm32f10x固件库中的voidNVIC_SetVectorTable(uint32_t NVIC_VectTab, uint32_t Offset)接口。
     浏览了一下Cortex-M0的Programmingmanual,原来M0并没有SCB->VTOR这个寄存器,难怪ST的库里没有提供NVIC_SetVectorTable这个接口。
     这下要怎么办?在网络上搜索了一下,受到网友findaway123这篇文章的启发,我在STM32F030CC的Reference manual中找到以下说明:
     Physicalremap
  Once the boot mode is selected, the application software canmodify the memory accessible in the code area.This modification isperformed by programming the MEM_MODE bits in the SYSCFGconfiguration register 1 (SYSCFG_CFGR1). Unlike Cortex? M3 and M4,the M0 CPU does not support the vector table relocation. Forapplication code which is located in a different address than0x0800 0000, some additional code must be added in order to be ableto serve the application interrupts. A solution will be to relocateby software the vector table to the internal SRAM:
  ? Copy the vector table from the Flash (mapped at the base of theapplication load address) to the base address of the SRAM at 0x20000000.
  ? Remap SRAM at address 0x0000 0000, using SYSCFG configurationregister 1.
  ? Then once an interrupt occurs, the Cortex?-M0 processor willfetch the interrupt handler start address from the relocated vectortable in SRAM, then it will jump to execute the interrupt handlerlocated in the Flash.
  This operation should be done at the initialization phase of theapplication. Please refer to AN4065 and attached IAP codefrom www.st.com for more details.
  OK,解决方法找到了!
  在用户应用程序中,按照以上方法,添加以下两行代码:
    memcpy((void*)0x20000000, (void*)0x08004000, VECTOR_SIZE); SYSCFG_MemoryRemapConfig(SYSCFG_MemoryRemap_SRAM);
   其中,0x2000 0000是SRAM的起始地址,这个不需要改动。
   而之后的两个参数需要根据实际情况作出修改。0x08004000是应用程序的起址地址,从这里开始的VECTOR_SIZE字节,存放是的应用程序的中断向量表。VECTOR_SIZE是指中断向量表的大小,具体多大可以在startup.s文件里计算得到。以下以startup_stm32f030.s为例作说明:
  我们只需关注其中的一小部分。从29行开始,直到75行,每一个DCD都代表一个中断向量(所谓中断向量,说得明白点,其实就是某个中断服务程序的入口地址)。例如第74行的:
  DCD     USART1_IRQHandler              ; USART1
  这里的“USART1_IRQHandler"其实就是UART1中断服务程序USART1_IRQHandler这个函数,同时,它也代表这个函数的入口地址。
  以上代码即定义了这样一张表,这张表包括45个元素,每个元素是一个长度为4字节的地址。除了第一个地址是SP(堆栈指针)外,其它的地址都是某个中断服务程序的入口地址。
  那么,回到我们要解决的问题上来,之前memcpy函数中的第三个参数VECTOR_SIZE,针对本例,就应该是45*4=180(0xB4)个字节。
  在执行完以上两行代码后,若发生中断,CPU就会去SRAM(即0x2000 0000处)取中断向量了,所以,以0x20000000作为起始地址之后的VECTOR_SIZE个字节就不能被改动了。为了达到这VECTOR_SIZE个字节不被修改的目的,如下两种方法可以实现。
  ?在工程文件内修改SRAM的起始地址及长度,如下图
  ?如果使用了分散加载文件,则在分散加载文件中修改SRAM的起始地址及长度也能达到目的。
  至此,STM32F0系列Cortex-M0内核芯片中断向量表重映射的问题已解决。
收藏收藏2 分享淘帖 顶顶 踩踩
ID:75662 发表于 2017-11-6 14:33 | 只看该作者
厉害咯,大神!!在这里找到了STM32F0中断生定向的答案!感谢楼主!
ID:384092 发表于 2018-8-8 10:56 | 只看该作者
这两行代码是写在 哪个文件中
ID:446325 发表于 2019-11-19 11:33 | 只看该作者
讲得很详细,最近弄这个网上都是M3系列的例程,在这里终于看懂了M0内核的中断向量表的重映射配置,感谢大神
ID:65369 发表于 2023-5-24 16:03 | 只看该作者
m0  和 m1 有点不一样的, 多谢奉献!
