查看: 3456|回复: 0
912 The computer has been removed , The machine dover has been
ID:104287 发表于 2016-1-29 19:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    开机后出现报警声并且提示912错误,屏幕显示:“912 The computer has been removed , The machine dover has been --------”,经上网一查,原来是HP台式机特有的开箱报警,处理方法可以进入BIOS 设置,将Reset case open status 的设置改为Enabled。
