查看: 4069|回复: 11
我用51板子连接GPS,用1602显示。可是显示不出来,有大神能帮我看看么
ID:102745 发表于 2016-3-11 08:52 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include <reg52.h>
#include "LCD1602.h"
#include "UART.h"
#include "Delay.h"
#include "GPS.h"
#include "config.h"
void main(void)
        unsigned char i;
        Uart_Init();
        LCD1602_Init();
        GPS_lock=1;
        GPSUSE_satellite[0]='0';
        GPSUSE_satellite[1]='0';
                if(Data_legitimate==0)                                //无GPS信号时
                        LCD1602_WriteCMD(CMD_clear);
                        Print_String(line_one,"  RTrobot GPS");
                        Print_String(line_two,"Please Waiting. ");
                        while(Data_legitimate==0);
                        Delay_Ms(200);
                else        //有GPS信号
                        if(Data_legitimate|0x01)        //GPGGA处理
                                        if(GPS_lock==0)                                        //未定位
                                                Print_String(line_two,"Waiting...");
                                        else        //已定位
                                                Print_Char(line_one,0,GPS_longitude_dir);                        //显示经度
                                                for(i=0;i<3;i++)
                                                  Print_Char(line_one,i+1,GPS_longitude[i]);
                                                Print_Char(line_one,4,'.');
                                                for(i=3;i<10;i++)
                                                        Print_Char(line_one,i+2,GPS_longitude[i]);
                                                Print_Char(line_two,0,GPS_latitude_dir);                        //显示纬度
                                                Print_Char(line_two,1,' ');
                                                for(i=0;i<2;i++)
                                                        Print_Char(line_two,i+2,GPS_latitude[i]);
                                                Print_Char(line_two,4,'.');
                                                for(i=2;i<9;i++)
                                                        Print_Char(line_two,i+3,GPS_latitude[i]);
                                        Data_legitimate&=~0x01;
                        Delay_Ms(500);
串口中断
void uart(void) interrupt 4
        unsigned char UART_data;
        if(RI)
                UART_data=SBUF;
                switch(UART_data)
                        case '$':
                                GPSDATA_number=0;                //GPS数据类型清空
                                GPSDATA_mode=1;                        //接收命令模式
                                GPSDATA_count=0;                //接收位数清空
                                break;
                        case ',':
                                GPSDOT_count++;                //逗号计数加1
                                GPSDATA_count=0;
                                break;
                        case '*':
                                switch(GPSDATA_number)
                                        case 1:
                                                Data_legitimate|=0x01;//GPGGA
                                                break;
                                        case 2:
                                                Data_legitimate|=0x02;//GPGSV
                                                break;
                                        case 3:
                                                Data_legitimate|=0x04;//GPRMC
                                                break;
                                GPSDATA_mode=0;
                                break;
                        default:
                                if(GPSDATA_mode==1)        //类型种类判断
                                        GPSDATA_cmd[GPSDATA_count]=UART_data;                        //接收字符放入类型缓存
                                        if(GPSDATA_count==4)        //如果类型数据接收完毕,判断类型
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='G'&&GPSDATA_cmd[4]=='A')//判断GPGGA
                                                        GPSDATA_number=1;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='S'&&GPSDATA_cmd[4]=='V')//判断GPGSV
                                                        GPSDATA_number=2;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='R'&&GPSDATA_cmd[3]=='M'&&GPSDATA_cmd[4]=='C')//判断GPRMC
                                                        GPSDATA_number=3;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                其他类型照搬
                                else if(GPSDATA_mode==2)                                        //接收数据处理
                                        switch (GPSDATA_number)
                                                case 1:        //类型1数据接收。GPGGA
                                                        switch(GPSDOT_count)
        case 2:        //纬度处理
        if(GPSDATA_count<9)
        GPS_latitude[GPSDATA_count]=UART_data;
        break;
        case 3:        //纬度方向处理
        if(GPSDATA_count<1)
        GPS_latitude_dir=UART_data;
        break;
        case 4:        //经度处理
        if(GPSDATA_count<10)
        GPS_longitude[GPSDATA_count]=UART_data;
        break;
        case 5:        //经度方向处理
        if(GPSDATA_count<1)
        GPS_longitude_dir=UART_data;
        break;
        case 6:        //定位判断
        if(GPSDATA_count<1)
        GPS_lock=UART_data;
        break;
        case 7:        //GPS使用卫星个数
        if(GPSDATA_count<2)
        GPSUSE_satellite[GPSDATA_count]=UART_data;
        break;
        case 9:        //海拔高度处理
        if(GPSDATA_count<6)
        GPS_altitude[GPSDATA_count]=UART_data;
        break;
                                                        break;
                                                case 2:        //类型2数据接收。GPGSV
        case 3:        //GPS可见卫星个数
        if(GPSDATA_count<2)
        GPSVISIBLE_satellite[GPSDATA_count]=UART_data;
        break;
                                                break;
                                                case 3:        //类型3数据接收。GPRMC
        case 1:        //时间处理
        if(GPSDATA_count<6)
        GPS_time[GPSDATA_count]=UART_data;
        break;
        case 2:        //定位判断
        if(GPSDATA_count<1)
        if(UART_data=='A')
        GPS_lock=1;
        if(UART_data=='V')
        GPS_lock=0;
        break;
        case 3:        //纬度处理
        if(GPSDATA_count<9)
        break;
        case 4:        //纬度方向处理
        if(GPSDATA_count<1)
        break;
        case 5:        //经度处理
        break;
        case 6:        //经度方向处理
        if(GPSDATA_count<1)
        break;
        case 7:        //速度处理
        if(GPSDATA_count<5)
        GPS_speed[GPSDATA_count]=UART_data;
        break;
        case 8:        //方位角处理
        if(GPSDATA_count<5)
        GPS_Angle[GPSDATA_count]=UART_data;
        break;
        case 9:        //日期
        if(GPSDATA_count<6)
        GPS_date[GPSDATA_count]=UART_data;
        break;
                                                        break;
                                GPSDATA_count++;                //接收数位加1
                                break;
#define LCD1602_DB0_DB7  P0   //1602液晶数据端口
sbit LCD1602_RS = P1^0;  //1602液晶指令/数据选择引脚
sbit LCD1602_RW = P1^1;  //1602液晶读写引脚
sbit LCD1602_E  = P1^5;  //1602液晶使能引脚
定义LCD1602指令集 (详细请见查看1602指令集手册)
#define                        CMD_clear                0x01            // 清除屏幕
#define                        CMD_back                0x02            // DDRAM回零位
#define                        CMD_ac                        0x06            // 读入后AC(指针)加1,向右写
#define                        CMD_display                0x0c            // 开显示_关光标_关光标闪烁
#define                        CMD_set                        0x38            // 8位总线_2行显示
#define                        line_one                0x80            // 第一行写入地址
#define                        line_two                0xc0            // 第二行写入地址
LCD1602测忙,若LCD1602处于忙状态,本函数将等待至非忙状态
void LCD1602_TestBusy(void)
           LCD1602_DB0_DB7 = 0xff;                            //设备读状态
           LCD1602_RS = 0;
           LCD1602_RW = 1;
           LCD1602_E = 1;
           while(LCD1602_DB0_DB7&0x80);                //等待LCD空闲
           LCD1602_E = 0;
写指令程序
void LCD1602_WriteCMD(unsigned char LCD1602_command)
          LCD1602_TestBusy();
          LCD1602_DB0_DB7 = LCD1602_command;
          LCD1602_RS = 0;
          LCD1602_RW = 0;
          LCD1602_E = 1;
          LCD1602_E = 0;
向LCD1602写数据
void LCD1602_WriteData(unsigned char  LCD1602_data)
        LCD1602_TestBusy();
        LCD1602_DB0_DB7 = LCD1602_data;
          LCD1602_RS = 1;
          LCD1602_RW = 0;
          LCD1602_E = 1;
          LCD1602_E = 0;
打印字符串程序(本函数调用指针函数)
向LCD发送一个字符串,长度48字符之内
在第一行第一位处从左向右打印字符串
void Print_String(unsigned char  line,unsigned char  *str)
        LCD1602_WriteCMD(line);
        while(*str != '\0')
                LCD1602_WriteData(*str++);
        *str = 0;
打印字符程序
向LCD发送一个字符,
line为行数(使用line_one,line_two定义使用),num为位置,data为打印字符
void Print_Char (unsigned char line,unsigned char num,unsigned char date)
                LCD1602_WriteCMD(line+num);
                LCD1602_WriteData(date);
LCD1602初始化
void LCD1602_Init(void)
          LCD1602_WriteCMD(CMD_set);        // 显示模式设置:显示2行,每个字符为5*7个像素
          LCD1602_WriteCMD(CMD_clear);        // 显示清屏
          LCD1602_WriteCMD(CMD_back);            // 数据指针指向第1行第1个字符位置
          LCD1602_WriteCMD(CMD_ac);            // 显示光标移动设置:文字不动,光标右移
          LCD1602_WriteCMD(CMD_display);         // 显示开及光标设置:显示开,光标开,闪烁开
void Uart_Init(void)
        EA=1;
        ES=1;
        SCON = 0x50;
        TMOD = 0x20;
        PCON=0x00;
        TH1 = 0xFD;
        TL1 = 0xfd;
        TR1 = 1;
        RI = 0;
接收数据是否完整
1有效
0无效
unsigned char Data_legitimate=0;
GPS是否定位
1有效
0无效
unsigned char GPS_lock;
GPS使用卫星个数
unsigned char GPSUSE_satellite[2];
GPS可见卫星个数
unsigned char GPSVISIBLE_satellite[2];
GPS数据类型
1GPGGA
2GPGSV
3GPRMC
unsigned char GPSDATA_number;
GPS数据模式
0结束模式
1类型模式
2数据模式
unsigned char GPSDATA_mode;
逗号计数器
unsigned char GPSDOT_count;
位数计数器
unsigned char GPSDATA_count;
类型模式存储数组
unsigned char GPSDATA_cmd[5];
纬度
unsigned char GPS_latitude[9];
纬度方向
unsigned char GPS_latitude_dir;
经度
unsigned char GPS_longitude[10];
经度方向
unsigned char GPS_longitude_dir;
GPS速度
unsigned char GPS_speed[5]={'0','0','0','.','0'};
海拔高度
unsigned char GPS_altitude[6];
日期
unsigned char GPS_date[6];
时间
unsigned char GPS_time[6];
方位角
unsigned char GPS_Angle[5]={'0','0','0','0','0'};
方位角
unsigned char OUT_speed[5];
void Delay_Ms (unsigned int a)
        unsigned int i;
        while( a-- != 0)
                for(i = 0; i < 600; i++);
收藏收藏2 分享淘帖 顶顶 踩踩
ID:253599 发表于 2019-3-9 11:33 | 只看该作者
我刚刚发了一个和你的差不多的,但是可以显示就是改了两个字母,你可以看一下
ID:253599 发表于 2019-3-9 11:29 | 只看该作者
if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='N'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='G'&&GPSDATA_c
ID:253599 发表于 2019-3-9 11:12 | 只看该作者
把P改成N
ID:185537 发表于 2017-4-4 17:02 | 只看该作者
cjjcjj1 发表于 2017-4-3 14:12
你好!你的GPS出现的什么问题呢
我的也是出现了1602显示不出来,调试了调试了lcd的驱动程序还是不可以显示
你的现在可以显示了吗,可以的话加我qq:975319430 我们一起学习一下
ID:185829 发表于 2017-4-3 19:34 | 只看该作者
字符格式转换
ID:82765 发表于 2017-4-3 14:12 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:185537 发表于 2017-4-2 16:07 | 只看该作者
你现在好了吗
ID:130538 发表于 2016-8-19 10:24 | 只看该作者
不错学习一下
ID:110866 发表于 2016-4-12 15:24 | 只看该作者
改下那个就行的
ID:84495 发表于 2016-4-12 09:28 | 只看该作者
如果你的  Print_String(line_one,"  RTrobot GPS");
这两行可以显示的话,就是gps波特率不对,,,
先确定你的gps模块的波特率,一般有4800和9600两种,可以先在电脑上调试一下,主要是确定gps模块是好的,
还有很重要的一点晶振,晶振误差大可能就跑偏了
ID:105648 发表于 2016-4-12 00:50 | 只看该作者
我也在搞这个, 手里也是显示不出。。。
听说前期调试可以直接用电脑的串口助手之类的仿佛发假的gps格式的信息,方便定位和debug
