查看: 4876|回复: 0
STM8S终极入门之定时器4应用简易花样流水灯
ID:109770 发表于 2016-3-20 03:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在学习下去,就需要搭建更为复杂的硬件架构了,我对架构这个词理解不了,在这里拿来算是应用吧;
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
BitStatus bit_status;
//BitStatus bit_count;
unsigned char bit_count;
void Delay(uint16_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
void main(void)
  /* Initialize I/Os in Output Mode */
  GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);
  GPIO_Init(GPIOD, GPIO_PIN_ALL, GPIO_MODE_OUT_OD_LOW_FAST);
  GPIO_Init(GPIOA, GPIO_PIN_2, GPIO_MODE_IN_PU_NO_IT);
  GPIO_ExternalPullUpConfig(GPIOA, GPIO_PIN_2, ENABLE);
  //CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  TIM4_TimeBaseInit(TIM4_PRESCALER_128, 15);
  TIM4_ClearFlag(TIM4_FLAG_UPDATE);
  TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
  TIM4_Cmd(ENABLE);
  enableInterrupts();
  while (1)
    GPIO_Write(GPIOD, 0xFE);Delay(65000);
    GPIO_Write(GPIOD, 0xFD);Delay(65000);
    GPIO_Write(GPIOD, 0xFB);Delay(65000);
    GPIO_Write(GPIOD, 0xF7);Delay(65000);
    GPIO_Write(GPIOD, 0xEF);Delay(65000);
    GPIO_Write(GPIOD, 0xDF);Delay(65000);
    GPIO_Write(GPIOD, 0xBF);Delay(65000);
    GPIO_Write(GPIOD, 0x7F);Delay(65000);
    /* Toggles LEDs */
    bit_status = GPIO_ReadInputPin(GPIOA, GPIO_PIN_2);
    if (bit_status == RESET)  //SET or RESET
      Delay(0xFFFF);
      if(bit_status == RESET)
        GPIO_WriteReverse(GPIOE, GPIO_PIN_5);
        GPIO_WriteReverse(GPIOD, GPIO_PIN_ALL);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
