查看: 15992|回复: 15
语音控制的智能小车设计资料
凌阳语音智能控制小车设计方案以及代码实现,包含源码 资料 与设计文档
以上压缩包的所有资料下载: 语音遥控小车礼包.rar (570.1 KB, 下载次数: 173)
源码预览:
  1. //======================================================
  2. //  The information contained herein is the exclusive property of
  3. //  Sunnnorth Technology Co. And shall not be distributed, reproduced,
  4. //  or disclosed in whole in part without prior written permission.
  5. //  (C) COPYRIGHT 2003  SUNNORTH TECHNOLOGY CO.
  6. //  ALL RIGHTS RESERVED
  7. //  The entire notice above must be reproduced on all authorized copies.
  8. //========================================================
  9. //========================================================
  10. //  工程名称:        Car_Demo
  11. //  功能描述:        实现小车的语音控制
  12. //  涉及的库:        CMacro1016.lib
  13. //                    bsrv222SDL.lib
  14. //                                sacmv26e.lib
  15. //  组成文件:        main.c
  16. //                                Flash.asm, hardware.asm,ISR.asm
  17. //                             hardware.h,s480.h, hardware.inc
  18. //        硬件连接:        IOA0-----KEY1
  19. //                                IOA1-----KEY2
  20. //                                IOA2-----KEY3
  21. //                                IOB8-----前进
  22. //                                IOB9-----倒车
  23. //                                IOB10----左拐
  24. //                                IOB11----右拐
  25. //        维护记录:        2005-12-12 v1.0
  26. //========================================================
  27. #include "s480.h"
  28. #include "bsrsd.h"
  29. #define        P_IOA_Data                         (volatile unsigned int *)0x7000
  30. #define P_IOA_Dir                         (volatile unsigned int *)0x7002
  31. #define P_IOA_Attrib                 (volatile unsigned int *)0x7003
  32. #define P_IOB_Data                        (volatile unsigned int *)0x7005
  33. #define P_IOB_Dir                        (volatile unsigned int *)0x7007
  34. #define P_IOB_Attrib                (volatile unsigned int *)0x7008
  35. #define P_TimerA_Data                (volatile unsigned int *)0x700A
  36. #define P_TimerA_Ctrl                (volatile unsigned int *)0x700B
  37. #define P_TimerB_Data                (volatile unsigned int *)0x700C
  38. #define P_TimerB_Ctrl                (volatile unsigned int *)0x700D
  39. #define P_Watchdog_Clear        (volatile unsigned int *)0x7012
  40. #define P_INT_Mask                        (volatile unsigned int *)0x702D
  41. #define P_INT_Clear                        (volatile unsigned int *)0x7011
  42. #define NAME_ID                         0x100
  43. #define COMMAND_GO_ID                 0x101
  44. #define COMMAND_BACK_ID         0x102
  45. #define COMMAND_LEFT_ID         0x103
  46. #define COMMAND_RIGHT_ID         0x104
  47. #define S_NAME                                0                                                        //给我取个名字吧
  48. #define S_ACT1                                1                                                        //前进
  49. #define S_ACT2                                2                                                        //倒车,请注意
  50. #define S_ACT3                                3                                                        //左拐
  51. #define S_ACT4                                4                                                        //右拐
  52. #define S_RDY                                5                                                        //Yeah
  53. #define S_AGAIN                                6                                                        //请再说一遍
  54. #define S_NOVOICE                        7                                                        //没有听到任何声音
  55. #define S_CMDDIFF                        8                                                        //说什么暗语呀
  56. #define S_NOISY                                8                                                        //说什么暗语呀
  57. #define S_START                                9                                                        //准备就绪,开始辨识
  58. #define S_GJG                                10                                                        //拐就拐
  59. #define S_DCZY                                11                                                        //倒车,请注意
  60. extern  unsigned int BSR_SDModel[100];                                        //外部变量BSR_SDModel[100],辨识器自带
  61. extern void F_FlashWrite1Word(unsigned int addr,unsigned int Value);
  62. extern void F_FlashErase(unsigned int sector);
  63. unsigned int uiTimeset = 3;        //运行时间定时,调整该参数控制运行时间
  64. unsigned int uiTimecont;        //运行时间计时
  65. //=============================================================
  66. // 语法格式:        void Delay();
  67. // 实现功能:        延时
  68. // 参数:                无
  69. // 返回值:                无
  70. //=============================================================
  71. void Delay()
  72. {
  73.         unsigned int i;
  74.         for(i=0;i<0x3Fff;i++)
  75.         {
  76.                 *P_Watchdog_Clear=0x0001;
  77.         }
  78. }
  79. //=============================================================
  80. // 语法格式:        void PlaySnd(unsigned SndIndex,unsigned DAC_Channel);
  81. // 实现功能:        语音播放函数
  82. // 参数:                SndIndex-播放语音资源索引号
  83. //                                DAC_Channel-播放声道选择
  84. // 返回值:                无
  85. //=============================================================
  86. void PlaySnd(unsigned SndIndex,unsigned DAC_Channel)
  87. {
  88.         BSR_StopRecognizer();        //停止识别器
  89.         SACM_S480_Initial(1);        //初始化为自动播放
  90.         SACM_S480_Play(SndIndex, DAC_Channel, 3);                        //开始播放一段语音
  91.         while((SACM_S480_Status()&0x0001)!= 0)                                //是否播放完毕?
  92.         {
  93.                 SACM_S480_ServiceLoop();                                                //解码并填充队列
  94.                 *P_Watchdog_Clear=0x0001;                                                //清看门狗
  95.         }
  96.         SACM_S480_Stop();        //停止播放
  97.         BSR_InitRecognizer(BSR_MIC);                                                //初始化识别器
  98. }
  99. //=============================================================
  100. // 语法格式:        int TrainWord(int WordID,int SndID);
  101. // 实现功能:        训练一条指令
  102. // 参数:                WordID-指令编码
  103. //                                SndID-指令提示音索引号
  104. // 返回值:                无
  105. //=============================================================
  106. int TrainWord(unsigned int WordID,unsigned int SndID)
  107. {
  108.         int Result;
  109.         PlaySnd(SndID,3);        //引导训练,播放指令对应动作
  110.         while(1)
  111.         {
  112.                 Result = BSR_Train(WordID,BSR_TRAIN_TWICE);                //训练两次,获得训练结果
  113.
  114.                 if(Result==0)break;
  115.                 switch(Result)
  116.                 {
  117.                 case -1:        //没有检测出声音
  118.                         PlaySnd(S_NOVOICE,3);
  119.                         return -1;
  120.                 case -2:        //需要训练第二次
  121.                         PlaySnd(S_AGAIN,3);
  122.                         break;
  123.                 case -3:        //环境太吵
  124.                         PlaySnd(S_NOISY,3);
  125.                         return -3;
  126.                 case -4:        //数据库满
  127.                          return -4;
  128.                 case -5:        //检测出声音不同
  129.                         PlaySnd(S_CMDDIFF,3);
  130.                         return -5;
  131.                 case -6:        //序号错误
  132.                         return -6;
  133.                 default:
  134.                         break;
  135.                 }
  136.         }
  137.         return 0;
  138. }
  139. //=============================================================
  140. // 语法格式:        void TrainSD();
  141. // 实现功能:        训练函数
  142. // 参数:                无
  143. // 返回值:                无
  144. //=============================================================
  145. void TrainSD()
  146. {
  147.         while(TrainWord(NAME_ID,S_NAME) != 0) ;                          //训练名称
  148.         while(TrainWord(COMMAND_GO_ID,S_ACT1) != 0) ;                  //训练第1个动作
  149.         while(TrainWord(COMMAND_BACK_ID,S_ACT2) != 0) ;          //训练第2个动作
  150.         while(TrainWord(COMMAND_LEFT_ID,S_ACT3) != 0) ;          //训练第3个动作
  151.         while(TrainWord(COMMAND_RIGHT_ID,S_ACT4) != 0) ;        //训练第4个动作
  152. }
  153. //=============================================================
  154. // 语法格式:        void StoreSD();
  155. // 实现功能:        存储语音模型函数
  156. // 参数:                无
  157. // 返回值:                无
  158. //=============================================================
  159. void StoreSD()
  160. {        unsigned int ulAddr,i,commandID,g_Ret;
  161.         F_FlashWrite1Word(0xef00,0xaaaa);
  162.         F_FlashErase(0xe000);
  163.            F_FlashErase(0xe100);
  164.            F_FlashErase(0xe200);
  165.            ulAddr=0xe000;//********
  166.         for(commandID=0x100;commandID<0x105;commandID++)
  167.         {
  168.                 g_Ret=BSR_ExportSDWord(commandID);
  169.                 while(g_Ret!=0)        //模型导出成功?
  170.                 g_Ret=BSR_ExportSDWord(commandID);
  171.                 for(i=0;i<100;i++)        //保存语音模型SD1(0xe000---0xe063)
  172.                 {
  173.                     F_FlashWrite1Word(ulAddr,BSR_SDModel[i]);
  174.                         ulAddr+=1;
  175.                 }
  176.         }
  177. }
  178. //=============================================================
  179. // 语法格式:        void StoreSD();
  180. // 实现功能:        装载语音模型函数
  181. // 参数:                无
  182. // 返回值:                无
  183. //=============================================================
  184. void LoadSD()
  185. {        unsigned int *p,k,jk,Ret,g_Ret;
  186.         p=(int *)0xe000;
  187.         for(jk=0;jk<5;jk++)
  188.         {
  189.                 for(k=0;k<100;k++)
  190.                 {
  191.                         Ret=*p;
  192.                         BSR_SDModel[k]=Ret;                                        //装载语音模型
  193.                         p+=1;
  194.                 }
  195.                 g_Ret=BSR_ImportSDWord();
  196.                 while(g_Ret!=0)                                                        //模型装载成功?
  197.                 g_Ret=BSR_ImportSDWord();
  198.         }
  199. }
  200. //=============================================================
  201. // 语法格式:        void GoAhead();
  202. // 实现功能:        前进子函数
  203. // 参数:                无
  204. // 返回值:                无
  205. //=============================================================
  206. void GoAhead()                                                     //前进
  207. {
  208.         PlaySnd(S_ACT1,3);                                                        //提示
  209.         *P_IOB_Data=0x0100;                                                        //前进
  210.         *P_INT_Mask |= 0x0004;                                                //以下为中断定时操作
  211.         __asm("int fiq,irq");
  212.         uiTimecont = 0;
  213. }
  214. //=============================================================
  215. // 语法格式:        void BackUp();
  216. // 实现功能:        后退子函数
  217. // 参数:                无
  218. // 返回值:                无
  219. //=============================================================
  220. void BackUp()                                                //倒退
  221. {
  222.         PlaySnd(S_DCZY,3);                                                        //提示
  223.         *P_IOB_Data=0x0200;                                                        //倒退
  224.         *P_INT_Mask |= 0x0004;                                                //以下为中断定时操作
  225.         __asm("int fiq,irq");
  226.         uiTimecont = 0;
  227. }
  228. //=============================================================
  229. // 语法格式:        void TurnLeft();
  230. // 实现功能:        左转子函数
  231. // 参数:                无
  232. // 返回值:                无
  233. //=============================================================
  234. void TurnLeft()                                               //左转
  235. {
  236.         PlaySnd(S_GJG,3);
  237.         *P_IOB_Data=0x0900;                                                        //右转
  238.         Delay();        //延时
  239.         *P_IOB_Data=0x0500;                                                        //左转
  240.         *P_INT_Mask |= 0x0004;                                                //以下为中断定时操作
  241.         __asm("int fiq,irq");
  242.         uiTimecont = 0;
  243. }
  244. //=============================================================
  245. // 语法格式:        void TurnRight();
  246. // 实现功能:        右转子函数
  247. // 参数:                无
  248. // 返回值:                无
  249. //=============================================================
  250. void TurnRight()                                           //右转
  251. {
  252.         PlaySnd(S_GJG,3);                                                        //语音提示
  253.         *P_IOB_Data=0x0500;                                                        //左转
  254.         Delay();        //延时
  255.         *P_IOB_Data=0x0900;                                                        //右转
  256.         *P_INT_Mask |= 0x0004;                                                //以下为中断定时操作
  257.         __asm("int fiq,irq");
  258.         uiTimecont = 0;
  259. }
  260. //=============================================================
  261. // 语法格式:        void Stop();
  262. // 实现功能:        停车子函数
  263. // 参数:                无
  264. // 返回值:                无
  265. //=============================================================
  266. void Stop()                                                   //停车
  267. {
  268.         *P_IOB_Data=0x0000;                                                        //停车
  269.         PlaySnd(S_RDY,3);                                                        //语音提示
  270. }
  271. //=============================================================
  272. // 语法格式:        void BSR(void);
  273. // 实现功能:        辨识子函数
  274. // 参数:                无
  275. // 返回值:                无
  276. //=============================================================
  277. void BSR(void)
  278. {
  279.         int Result;        //辨识结果寄存
  280.         Result = BSR_GetResult();                                        //获得识别结果
  281.         if(Result>0)        //有语音触发?
  282.         {
  283.                 *P_IOB_Data=0x0000;                                                //临时停车
  284.                 switch(Result)
  285.                 {
  286.                 case NAME_ID:                                                        //识别出名称命令
  287.                         Stop();        //停车待命
  288.                         break;
  289.                 case COMMAND_GO_ID:                                                //识别出第一条命令
  290.                         GoAhead();                                                        //执行动作一:直走
  291.                         break;
  292.                 case COMMAND_BACK_ID:                                        //识别出第二条命令
  293.                         BackUp();                                                        //执行动作二:倒车
  294.                         break;
  295.                 case COMMAND_LEFT_ID:                                        //识别出第三条命令
  296.                         TurnLeft();                                                        //执行动作三:左转
  297.                         break;
  298.                 case COMMAND_RIGHT_ID:                                        //识别出第四条命令
  299.                         TurnRight();                                                //执行动作四:右转
  300.                         break;
  301.                 default:
  302.                         break;
  303.                 }
  304.         }
  305. }
  306. //=============================================================
  307. // 语法格式:        void IRQ5(void);
  308. // 实现功能:        中断服务子函数
  309. // 参数:                无
  310. // 返回值:                无
  311. //=============================================================
  312. void IRQ5(void)__attribute__((ISR));                        //运动定时控制
  313. void IRQ5(void)
  314. {
  315.         if(uiTimecont++ == uiTimeset)
  316.         {
  317.                 *P_IOB_Data = 0x0000;
  318.         }
  319.         *P_INT_Clear = 0x0004;
  320. }
  321. //=============================================================
  322. // 语法格式:        int main(void);
  323. // 实现功能:        主函数
  324. // 参数:                无
  325. // 返回值:                无
  326. //=============================================================
  327. int main(void)
  328. {        unsigned int BS_Flag;                                                //Train标志位
  329.         *P_IOA_Dir=0xff00;                                                        //初始化IOA,IOA0~7下拉输入
  330.         *P_IOA_Attrib=0xff00;
  331.         *P_IOA_Data=0x0000;
  332.
  333.         *P_IOB_Dir=0x0f00;                                                        //初始化IOB,IOB8~11同向输出
  334.         *P_IOB_Attrib=0x0f00;
  335.         *P_IOB_Data=0x0000;
  336.
  337.         BSR_DeleteSDGroup(0);                                                //初始化存储器RAM
  338.         BS_Flag=*(unsigned int *)0xe000;                        //读存储单元0xe000
  339.         if(BS_Flag==0xffff)                                                        //没有经过训练(0xe000内容为0xffff)
  340.         {
  341.                 TrainSD();        //训练
  342.                 StoreSD();        //存储训练结果(语音模型)
  343.         }
  344.         else        //经过训练(0xe000内容为0x0055)
  345.         {
  346.                 LoadSD();        //语音模型载入识别器
  347.         }
  348.
  349.         PlaySnd(S_START,3);                                                        //开始识别提示
  350.         BSR_InitRecognizer(BSR_MIC);                                //初始化识别器
  351.
  352.         while(1)
  353.         {
  354.                 BSR();
  355.                 if((*P_IOA_Data)&0x0004)                                //是否重新训练
  356.                 {
  357.                         F_FlashErase(0xe000);
  358.                         while(1);
  359.                 }
  360.         }
  361. }
参与人数 4黑币 +20 收起 理由
lieyan + 5 赞一个!
sax_yang + 5 共享资料的黑币奖励!
ttt123 + 5 很给力!
lion7452 + 5 赞一个!
收藏收藏7 分享淘帖 顶顶1 踩踩
ID:86621 发表于 2016-4-13 16:07 | 只看该作者
楼主 我用51的话能做吗
ID:128795 发表于 2016-7-1 16:47 | 只看该作者
我可以看看吗
ID:91113 发表于 2017-1-7 15:37 | 只看该作者
如果加wifi控制是不是很麻烦
ID:166756 发表于 2017-2-26 19:18 | 只看该作者
谢谢楼主!
ID:308152 发表于 2018-4-16 14:59 | 只看该作者
为什么我下载失败了呀?楼主能发一份资料么?邮箱563688038@qq.com,感激不尽!
ID:65956 发表于 2018-4-17 11:36 | 只看该作者
用语音控制是一个好的点子,但是要考虑环境干扰及人口语音标准的问题
ID:497690 发表于 2019-3-25 09:59 | 只看该作者
厉害了
ID:502154 发表于 2019-4-1 09:17 | 只看该作者
资料很给力
ID:501893 发表于 2019-4-13 14:30 | 只看该作者
多更新好东西
ID:497690 发表于 2019-4-26 14:23 | 只看该作者
厉害厉害
ID:522648 发表于 2019-4-26 23:00 | 只看该作者
厉害,凌阳单片机难吗
ID:526612 发表于 2019-5-3 19:41 | 只看该作者
谢谢大佬分享
ID:525356 发表于 2019-5-3 21:06 | 只看该作者
谢谢大佬  有其他不同芯片的控制方法吗?
ID:319031 发表于 2019-5-3 21:24 | 只看该作者
谢谢大佬分享
很好的学习资料
ID:854312 发表于 2020-12-4 12:39 | 只看该作者
谢谢大佬分享
相当不错的学习资料
