查看: 2155|回复: 0
1602显示程序
ID:117256 发表于 2016-4-28 11:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
sbit LCD_RS = P0^7;
sbit LCD_RW = P0^6;
sbit LCD_EN = P0^5;
sbit LED = P1^0;
#define Data P2
#define   Data_0_time    4
//独立按键接口 可自行修改
函数名称:delay();
函数功能:粗略延时
void delay1(U16 i)
        U16 j,k;
        for(j=i;j>0;j--)
        for(k=125;k>0;k--);
void DelayUs2x(U8 t)
        while(--t);
void DelayMs(U8 t)
    while(t--)
     //大致延时1mS
       DelayUs2x(245);
       DelayUs2x(245);
void Delay(U16 j)
         U8 i;
         for(;j>0;j--)
                for(i=0;i<27;i++);
void  Delay_10us(void)
   U8 i;
   i--;
   i--;
   i--;
   i--;
   i--;
   i--;
函数名称:bit lcd_busy()
函数功能:检查LCD忙状态
输入值  :无
返回值  :
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_EN = 1;
    delay1(1);
    result = (bit)(Data&0x80);
    LCD_EN = 0;
    return(result);
函数名称:void LCD1602_WriteCmd(unsigned char cmd)
函数功能:写指令数据到LCD
输入值  :指令
返回值  :无
    LCD_RS = 0;
    LCD_EN = 0;
    delay1(1);
    Data = cmd;
    delay1(5);
    LCD_EN = 1;
    delay1(5);
    LCD_EN = 0;
    delay1(10);
函数名称:void LCD1602_WriteData(unsigned char dat)
函数功能:写显示数据到LCD
输入值  :数据
返回值  :无
void LCD1602_WriteData(U8 dat)
    LCD_RS = 1;
    LCD_EN = 0;
    Data = dat;
    delay1(1);
    LCD_EN = 1;
    delay1(1);
    LCD_EN = 0;
    delay1(10);
函数名称:void lcd_init(void)
函数功能:LCD1602初始化函数
输入值  :无
返回值  :无
void lcd_init(void)
    LCD_RW = 0;
    delay1(15);
    LCD1602_WriteCmd(0x01);      //清除LCD的显示内容
    LCD1602_WriteCmd(0x38);      //16*2显示,5*7点阵,8位数据
    delay1(5);
    delay1(5);
    delay1(5);
    LCD1602_WriteCmd(0x0c);      //开显示,不显示光标
    delay1(5);
    delay1(5);
函数名称:void LCD1602_WriteChar(unsigned char x,unsigned char y,unsigned char Dat)
函数功能:写单个字符到指定坐标
输入值  :x:行 (可取0~1) y:列 (可取0~15) Dat:为要显示的数据
返回值  :无
void LCD1602_WriteChar(U8 x,U8 y,U8 Dat)
  if(x==0)
    LCD1602_WriteCmd(0x80+y);
    LCD1602_WriteData(Dat);
    delay1(5);
  if(x != 0)
    LCD1602_WriteCmd(0x80+0x40+y);
    delay1(5);
函数功能:写字符串到指定坐标    (x,y)为首个字符的显示位置
返回值  :无
void LCD1602_WriteString(U8 x,U8 y,U8 *String)
  U8 i;
  for(i=0;String[i]!='\0';i++)
    LCD1602_WriteChar(x,y++,String[i]);
void init(void)
    TMOD = 0x20;          //定时器T1使用工作方式2
        TH1 = 253;        // 设置初值
        TL1 = 253;
        TR1 = 1;          // 开始计时
        SCON = 0x50;          //工作方式1,波特率9600bps,允许接收
        ES = 1;
        EA = 1;           // 打开所以中断
void main(void)
        int a;
        lcd_init();
        init();
        while (1)
           LCD1602_WriteString(0,0,"GangBanHou:");
           LCD1602_WriteString(1,3,"mm");
           LCD1602_WriteChar(1,0,'f');
           a++;
           DelayMs(500);
           LCD1602_WriteChar(1,1,a+'0');
1602显示程序.zip
39.58 KB, 下载次数: 6, 下载积分: 黑币 -5
1602显示程序
