查看: 3257|回复: 1
定时开关计时器 当我用Arduino UNO 测试时,计时器工作但是开关计计数不工作
ID:118080 发表于 2016-5-8 02:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是小弟的代码
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
int runTimer = 1;
int runFor = 50; // time in seconds
int buzzerPin = 13;
int relayPin=4;
int data = 0;
const int switchPin = 5;
int hits = 0;
int switchState = 0;
int prevSwitchState = 0;
const int switchPin1 = 6;
int hits1 = 0;
int switchState1 = 0;
int prevSwitchState1 = 0;
void setup() {
   pinMode(buzzerPin, OUTPUT);
   pinMode(relayPin,OUTPUT);
   lcd.begin(16, 0);
   lcd.begin(16, 2);
   pinMode(switchPin,INPUT);
  pinMode(switchPin1,INPUT);
void loop() {
   switchState = digitalRead(switchPin);
  if (switchState != prevSwitchState) {
    if (switchState == LOW) {
      hits = hits + 1;
      lcd.clear();
      lcd.setCursor(0, 1);
      lcd.print("Hits:");
      lcd.setCursor(7, 1);
      lcd.print(hits);
      lcd.setCursor(11, 1);
      lcd.print(hits1);
      delay(90);
   prevSwitchState = switchState;
   switchState1 = digitalRead(switchPin1);
  if (switchState1 != prevSwitchState1) {
    if (switchState1 == LOW) {
      hits1 = hits1 + 1;
      lcd.clear();
      lcd.print("Hits:");
      lcd.print(hits1);
      lcd.print(hits);
      delay(90);
  prevSwitchState1 = switchState1;
   if(runTimer == 1){
      digitalWrite(relayPin,LOW); // relay is OFF during countdown
      lcd.clear();
      lcd.print("TIMER=");
      lcd.print("Hits:");
      lcd.print(hits);
      lcd.print(hits1)
      //Start timer
      ;timer();
   runTimer = 0;
   lcd.noDisplay();
   delay(250);
   for(int duration = 0; duration < 100; duration ++){
      digitalWrite(buzzerPin, HIGH);
      delayMicroseconds(500);
      digitalWrite(buzzerPin, LOW);
   lcd.display();
   delay(250);
void timer() {
   for(int timer = runFor;timer > 0; --timer){
   if(timer >= 10) {
      lcd.setCursor(6,0);
   } else {
      lcd.setCursor(6,0);
      lcd.print("0");
      lcd.setCursor(7,0);
   lcd.print(timer);
   lcd.print(" SECOND!");
   delay(1000);
   lcd.setCursor(1,1);
   lcd.clear();
   lcd.print(" TIMER OUT!");
      lcd.print("Hits:");
      lcd.print(hits);
      lcd.print(hits1);
当我用Arduino UNO 测试时,计时器工作但是开关计计数不工作。。请大神指点
ID:118080 发表于 2016-5-8 02:19 | 只看该作者
具体功能是,倒计时50,然后在倒计时这段时间记录两个开关的按键次数。倒计时结束 停止开关计数。。。
