查看: 2523|回复: 0
时钟程序
ID:117161 发表于 2016-5-14 17:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit dula=P0;
sbit wela=P2;
uchar code table[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0X80,0X90};
void delay(ms);
uint num,shi,ge,fshi,fge,sshi,sge,aj,a,b;
unsigned char num1,num2,num3,dfg,dfs,dsg,dss;
void display()
          P2=0x80;
          P0=table[ge];
          delay(5);
          P0=0xff;
          P2=0x40;
          P0=table[shi];
          delay(5);
          P0=0xff;
          P2=0x20;
          P0=0xbf;
          delay(5);
          P0=0xff;
          P2=0x10;
          P0=table[fge];
          delay(5);
          P0=0xff;
          P2=0x08;
          P0=table[fshi];
          delay(5);
          P0=0xff;
          P2=0x04;
          P0=0xbf;
          delay(5);
          P0=0xff;
          P2=0x02;
          P0=table[sge];
          delay(5);
          P0=0xff;
          P2=0x01;
          P0=table[sshi];
          delay(5);
          P0=0xff;
void delay(ms)
        uint i,j;
         for(i=ms;i>0;i--)
     for(j=10;j>0;j--);
void TO_time()interrupt 1
      num++;
            if(num==5000)
                                num=0;
                                num1++;
                                if(num1==60)
                                {num1=0;
                                        num2++;
            if(num2==60)
                        {  num2=0;
                                num3++;
                                if(num3==24)
                                 {num3=0;
                shi=num1/10;
                 ge=num1%10;
                fshi=num2/10;
                 fge=num2%10;
         sshi=num3/10;
                sge=num3%10;
{     TMOD=0x02;
            TH0=(256-200);
            TL0=(256-200);
            EA=1;
            ET0=1;
            TR0=1;
                num1=30;
                                 num2=59;
                                 num3=23;
                                display();
