查看: 3268|回复: 3
我在做环境温度监测系统,可是用下面这个程序4位数码管老是显示8000没有变化 怎么办
#include <reg51.h>
#include <intrins.h>
sbit led0=P3^4;
sbit led1=P3^5;
sbit led2=P3^6;
sbit led3=P3^7;
sbit DQ=P2^4;
float data TMP[2]={0,0};
unsigned char data f[2]={0,0};
unsigned char data disp_buf[4]={0,0,0,0};
unsigned char data dot_position=0;
unsigned char data chno=0;
unsigned char code SN[2][8]={{16, 62,148,60,0,0,0, 247},{16,229,146,60,0,0,0, 87}};
unsigned char code seg_table[ ]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x6f,0x76};
unsigned char code CH[ ]={10,11,12,13,14,15,16,17};
// 将0.00~99.9之间的浮点数转为单个数码,并送显示缓冲区和返回小数点位置
void ftochar(float valp)
if(valp<10.0)
   dot_position=1;
   valp*=100.0;
else if((valp>=10.0)&&(valp<100.0))
  dot_position=2;
  valp*=10.0;
else if((valp>=100.0)&&(valp<1000.0))
dot_position=3;
disp_buf[1]=(int)valp/100;
disp_buf[2]=((int)valp%100)/10;
  disp_buf[3]=((int)valp%100)%10;
    //延时15微秒的函数
void delay(unsigned char n)
do {
    _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
    _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
n--;
}while(n);
//DS18B20复位函数
void ow_reset(void)
DQ = 0;
delay(120);
DQ = 1;
delay(24);
//DS18B20读位函数
unsigned char read_bit(void)
unsigned char i;
  DQ = 0;
  DQ = 1;
  for(i=0; i<5; i++);
  return(DQ);
//DS18B20写位函数
void write_bit(char bitval)
DQ = 0;
if(bitval==1) DQ =1;
delay(6);
DQ = 1;
//从DS18B20读取字节函数
unsigned char read_byte(void)
unsigned char i;
unsigned char value = 0;
for(i=0;i<8;i++)
if(read_bit()) value|=0x01<<i;
delay(11);
return(value);
//写字节到DS18B20
void write_byte(char val)
unsigned char i;
unsigned char temp;
for (i=0; i<8; i++)
temp = val>>i;
temp &= 0x01;
write_bit(temp);
delay(10);
//读温度代码
void  read_temp()
unsigned char i,j;
unsigned char a,b;
int mr;
for(j=0;j<2;j++)
ow_reset();
delay(20);
write_byte (0x55);
for(i=0;i<8;i++)
  write_byte(SN[j][i]);
write_byte (0xbe);
a = read_byte();
b = read_byte();
mr=b*256+a;
if((mr&0xf800)!=0)
  mr=-mr+1;
TMP[j]=mr*0.5;
//定时器T0终端函数,每中断一次,显示一次数码管
void Time_disp(void) interrupt 1
static unsigned char dispno=0;
TH0=0xee;
TL0=0x00;
P3|=0xf0;
P0=seg_table[disp_buf[dispno]];
if(dispno==dot_position) P0|=0x80;
switch(dispno)
case 0 :  led0=0;
break;  case 1 : led1=0;
break;  case 2 : led2=0;
break;  case 3 : led3=0;
break;
dispno++;
if(dispno==4) dispno=0;
//定时器T1中断函数,每50ms中断一次
void Timer1(void) interrupt 3
static unsigned int count;
TH1=0x4c;
TL1=0x00;
count++;
if(count>=20)
count=0;
ftochar(TMP[chno]);
disp_buf[0]=CH[chno];
chno++;
if(chno==2) chno=0;
//主函数
main( )
TMOD=0x11;
EA=1;
ET0=1;
ET1=1;
TH0=0xee;
TL0=0x00;
TH1=0x4c;
TL1=0x00;
TR0=1;
TR1=1;
do
ow_reset( );
write_byte(0xcc);
write_byte(0x44);
read_temp( );
while(1);
ID:127450 发表于 2016-6-21 20:05 | 只看该作者
这程序网上找的
ID:111634 发表于 2016-6-28 22:21 | 只看该作者
DS18B20 测温
DS18B20 测温
先Proteus仿真一下,确认有效。
实例97 DS18B20测温.rar (51.78 KB, 下载次数: 7)
以上摘自张志良编著《单片机实验实训100例》 ISBN 978-7-5124-1603-1,北航社出版
书中电路和程序设计有详细说明,程序语句条条有注解。
ID:127881 发表于 2016-6-28 22:35 | 只看该作者
网上应该可以找到可以用的程序
