查看: 4229|回复: 0
TI DSP精华问答(50个问题)
ID:128229 发表于 2016-6-27 14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.问: C6712怎样访问 I/O空间?
答: Acturally, C6000 have only one memory space, include Data and Prog memory.
The I/O also be mapping to memory space, can be accessed through EDMA and
EMIF bus.
2.问: TMS320C6712 的 32 位浮点特性与以往推出系列相比,有哪些优势,可提
供哪些性能,存在哪些不足?
答: It support IEEE_SP32 and IEEE_DP32 and IEEE_DP64 float_point. Compare
with C3x, it has strong C compiler and also good development tool CCS.
3.问: TI 能否尽可能将闪存集成在今后的 DSP产品中,以减少外设和提高线路精
度?
答: TI 具备将 FLASH 集成到 DSP中的能力。但是不同的用途有不同的要求。所
以我们针对用量较大的客户会进行集成以满足客户要求。
4.问: Is 6712, 6711 and 6701 all pin compatible?
答: Yes, they are all compatible.
5.问: 以 5409 为例,很多 DSP 产品在使用前必需进行内存分配,该工作目前由
用户自己进行,虽提供了很大的灵活性,但对经验较少的人来说会耗费很多不必
要的精力,所以请问 TI 能否在发货时就为芯片提供标准的配置文件?
答: DSP link comand file is effective tool  to manage DSP memory configuration to
improve system feature. DSP BIOS has visuable tool to deliver the function.
6.问: 请问 DSP与 CPU、MPU有什么区别?
答: The structure of DSP is difference from CPU/MPU. In DSP, there are different
memory for data and instruction. And it focus on computing not flow management.
7.问: TI 能否为其 DSP产品提供更加灵活的外设以满足多样的应用需要?
答 : Yes. In C6000, we have peripherals as these McBSP, HPI/Expension
BUS/PCI,EMIF(can connect with SBSRAM, SDRAM, Async RAM flush ROM
SRM), DMA/EDMA, timers etc.
8.问: 请问"数字信号处理器"的对象是什么?
答: wireless communication, broadband internet access, image process, modem,
disital motor control ... We believe it can be used in every internet action, every bit.
9.问: TI的DSP产品的C代码编译效率低, 常使开发者感到其结果不能达到预期,
请问 TI 有无应对之策?(11:01:19 AM)
答: The C6000 C compiler performance can reach 70-80%. This is just because the
from the beginning time of C6000 core design, the RISC like structure have make the
C compiler and optimizer can be easy design and reach high performance. That means
the C optimizer is begin from basic hardware design. So the question is true for other
DSP, for C6000 good C compiler is our strong point.
10.问: TI 公司的 DSP 有什么特点?即在处理速度、存储量、接口以及软件编程
等方面有什么特点?
答: For C6000, it is the most advanced DSP, our C64x can run at 700Mhz to 1.1Ghz,
the memory space for C6000 can be 32 bits wide. And we have DSP/BIOS which is
industry proved and free real time kernal  can help engineer design more easy and
focus on their application.
11.问: DSP是不是扩大了功能的单片机?
答: No.
12.问: 在未来,DSP是否有代替 CPU的可能?
答: TI believe that in the coming internet era, many application engines will be driven
by DSP such as image, communication, digital consumer appliances. CPU can be
used as a controller, DSP will be used for specific functions.
13.问: DSP 与 FPGA  的区别?性能及用途方面。
答: DSP can be reprogramble offline and online, have more flexible than FPGA.
14.问: 请问贵公司的 6712 可用在民用的哪些方面?
答: C6000 的特点是高性能,应用比较容易(用 C 开发) ,如用在应用复杂的场
合,  会很有优势,如网络相机,用户端网络加密等。
15.问: TMS320C6712 高频特性适用于跳频、扩频的哪些具体应用?是否适用于
蓝牙技术?
答: 跳频、扩频 Yes,蓝牙技术  No because its power consumption.
16.问: 除了众所周知的 DSP外。TI 在模拟器件领域最关心的方向是什么?
答: TI is taking effort for provide all kinds of analog products portfolio.
17.问: 5000系列做便携式现场数据采集合适吗?
答:C5000 is suitable for portable application such as for low power requirement.
18.问:DSP的电源设计和时钟设计应该特别注意哪些方面?
答:时钟一般使用晶体,电源可用 ti 的配套的电源。
19.问:DSP 一般有二种供电方式:一种是开关电源,另外一种是 TI 有许多的
LDO,开关电源电路相对复杂,而 LDO相对非常简单。我想问一下电路相对简
单的 LDO 供电会有什么缺点,还是没有缺点。例如 TI的 TPS75933已经可以提
供最大 7.5A 的电流,按功率来说已经完全足够了。如果没有缺点,我是否能够
把 LDO用于其它功耗相对较多的 CPU。
答:一般是没有什么问题的,是可以用在其它的cpu的。
20.问:TI的 DSP是否可以真正实现实时进行 MPEGII 编解码,技术支持是否能
足够?
答:Yes. You need to do MPEG codec with c64x。
21.问:TI 的 DSP产品中,对 USB的支持情况是什么样的?我要做一个 USB接
口的高速数据采集卡,应该选用什么型号的DSP和 AD芯片?
答:We do have c5509 DSP which support USB。
22.问:dsp/bios 中的 system clock,是否是用于系统的任务、调度、周期任务的
管理?如果不用外部事件,使用 system clock将要占用一个定时器硬件资源,那
么这个定时器就不能用于定时、计数等正常。我的理解对吗?
答:是的。
23.问:C6000的 BIOS 的工作过程是怎样的?
答:BIOS 是一种实时多任务的操作系统,用户只需编写各项任务的进程,程序
的进程由 BIOS 的管理。
24.问:TMS320LF2407 的工作电压为 3.3V,DSP 的抗干扰能力能允许多大的电
源毛刺?
答:5%。
25.问:1、CORE 和 I/O 供电的时序有那些要求?如果 I/O 供电超前于 CORE,
超前时间应限制在多少以内?2、最新的高速DSP对供电电源的动态特性有何要
求?要求 di/dt 为多少?
答:对 DSP本身而言,没有上电次序要求。
26.问:堆栈寻址和 dp 指针寻址哪一个效率高?
答:dp 指针寻址效率高。
27.问:请问,DSP在与前向通道(比如说 AD)接口的时候,布线过程中要注意哪
些问题,以保证 AD采样的稳定性?
答:模拟地和数字地分开,但在一点接地。
28.问:请简单介绍 DSP与 89C52接口方式(HPI 方式)
答:可把 HPI 口作为一个上位机的 Io 口来处理。
29.问:用 dsp 硬件仿真设备调试 usb 接口板等设备时,与脱机调试,在时序及其
它方面有何不同。谢谢!
答:没有不同。
30.问:1.3.3V的 DSP 能否与 5V的 A/D相连接 2.目前设计一个浮点的系统采用
哪一种芯片较好?
答:1.    No. You need a level  shifting IC between them.2.    If you need an high
performance floating DSP, I recommend C6000. For more details, you could refer to
the DSP selection guide http://www.dspvillage.ti.com/dspguide.
31.问:器件布局应重点考虑哪些因素?如在集中抄表系统中应用系统成本台
何?
答:可用Tms320vc5402,成本不是很高,器件布局应重点应是存贮器与DSP 的
接口。
32.问:请问如何通过仿真器把.HEX 程序直接烧到 FLASH 中去? 所用 DSP 为
5402.是否需要自己另外编写一个烧写程序,如何实现?谢谢!!
答:直接写.OUT。是 DSP中写一段程序,把主程序写到 FLASH中。
33.问:设计 c6701 的计算机 pci板卡时,怎样通过计算机下载程序到 c6701 中?
如果板卡有 flash,仿真器可以直接写flash 吗?flash 地烧写程序由谁提供,是自
己编写吗(c6701 程序)?
答:可以,要自己写。
34.问:1.DSP芯片内是否有单个的随机函数指令?2.DSP内的计算速度是快的,
但是它的I/O口的交换速度有多快呢?3.DSP如何配合EPLD或FPGA工作呢?
答:1.    No.2.    Depeneded on which I/O you are referring. For HPI, the transfer rate
(in bytes) could be about 1/4 of CPU clock. For McBSP, the bit rate (kbps) could be
about 1/2 CPU clcok.3.    You could cascade the emuation interface with the one on
EPLD/FPGA. Please see the following application notes for
details.http://www.ti.com/sc/docs/psheets/abstract/apps/spra439a.htm
35.问:请问在 DSP硬件电路板 Layout 时,EMI 方面的问题应主要注意哪几点?
答:信号的完整。
36.问:1、c5416 的 pcb 板设计是否需要考虑高速数字电路板设计?2、c5416 的
电源,EEPROM,扩展 SRAM,双口 RAM 设计;能否介绍较详细的管脚图?3、刚
进行 c5416 的硬件设计和软件设计时,是否有较好的中文或英文参考书。
答:1. Yes. Since the operating frequency could be higher than 100MHz. 2. You could
refer to our C5416 DSK design.3.For S/W development, you could try the examples
from our CCS. For H/W design, you could refer to our EVM/DSK design.
37.问:我有关于C240的一个问题,为何有时程序从外部运行正常,烧进 FLASH
就不正常。是何原因。
答:可能性较多,建议检查空间设置或初始化段是否写入 FLASH。
38.问: 我想了解TMS320C240及其相关 DSP的设计方法, 用于全桥电源的 PWM
控制,谢谢。
答:  You could download our Developer"s Kits from the following web
page,http://www.dspvillage.com/c2000devkit
39.问:我在使用 5402DSK时,一上电,不接 MIC,只接耳机,不运行任何程序,
耳机中有比较明显的一定频率的噪声出现。有时上电后没有出现,但接 MIC,
运行范例中的 CODEC 程序时,又会出现这种噪声。上述情况通常都在 DSK 工
作一段时间后自动消失。 我在DSP论坛上发现别人用DSK时也碰到过这种情况,
我自己参照 5402DSK 做了一块板,所用器件基本一样,也是这现象,请问怎么
回事,如何解决。
答: 始时没有有效的程序代码, 所以上电后是随机状态, 出现这种情况是正常的。
40.问:请问 TMS320LF2407 与 TMS320C6201 的 HPI 接口怎样连接,有特别的
时序要求吗?
答:没有特别的时序要求。HPI 接口作为 2407 的外围设备,直接接口。
41.问:请介绍一款专用于 FFT,数字滤波,卷积,相关等算法的 DSP,最好集成
12BIT以上的 ADC功能。
答:I recommend TMS320LF240x, if your application is about motor/energy control.
Please also see our DSP selection guide for more information on
it,http://www.dspvillage.ti.com/dspguide
42.问:电路中用到DSP,有时当复位信号为低时,电压也属于正常范围,但DSP
加载程序不成功。电流也偏大,有时时钟也有输出。不知为什么?
答:复位时无法加载程序。
43.问:c5510 芯片如何接入 E1信号?在接入时有什么需要注意的地方?
答:通过 McBSP同步串口接入注意信号电平必须满足要求
44.问:ccs2.0 中有 gel 文件,可以初始化外设。那有了 gel 文件后,我在我的程
序中还需要不需要编写初始化外设的语句。我的程序将脱离调试环境运行。
答:需要。
45.问: 我设计的TMS320C5402板子在调试软件时会经常出现memory错误报告,
排除是映射的问题,是不是板子不稳定的因素?还是 DSP 工作不正常的问题?
如何判别?
答:你可以利用 MEmoryfill 功能,填入一些数值,然后刷新一下,看是不是在
变,如果是在变化,则 MEmory 是有问题。
46.问:VC33的哪些接口可接 AD?最好是无缝连接。
答:You could find recommended data converters for VC33 from the following web
site, http://www.ti.com/sc/docs/msp/c3x.htm
47.问:DSP的程序编写用汇编好还是 C好?
答:You can use C coding and compiler for  assemble code to do the function
verifiction, for better code optimize, you can modify with assemble code.
48.问:TI 公司推出了一款 TS320多媒体处理器(DSP),可以应用在安防系统,可以
开发成硬盘录象机(DVR).再什么地方可以找到这个应用方案.
答: If you are talking about DSC24,  please visit the following web
site,http://www.prodsys.com/DMDK2400/
49.问:我使用的是 TMS320LF2407,但是仿真时不能保证每次都能 GO MAIN。
我想详细咨询以下CMD文件的设置用法,还有 VECTOR的定义。
答:可能看门狗有问题,关掉看门狗。
50.问:系统调试时发现纹波太大主要是哪主面的问题?
答:如果是电源纹波大,加大电容滤波。
