查看: 7263|回复: 9
单片机双机通信能不能传送数组
ID:147040 发表于 2016-11-15 11:11 来自触屏版 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
假如甲单片机发送数组char a [4] ={1,2,3,4};SBUF=a;乙单片机接收char b [4];
该怎么接收,接收完成后a数组与b数组的值是否完全一致?
ID:1 发表于 2016-11-15 11:18 | 只看该作者
  1. //============================================
  2. B 机(显示数据)的程序如下:
  3. //--------------------------------
  4. #include<reg52.h>
  5. unsigned char  re_i = 0, r_buf[7] = {0,0,0,0,0,0,0};
  6. unsigned char  a = 13, b = 57, c = 40, d;
  7. //--------------------------------
  8. void delayms(unsigned int xms)
  9. {
  10.     unsigned  int i, j;
  11.     for(i = xms; i > 0; i--)  for(j = 110; j > 0; j--);
  12. }
  13. //--------------------------------
  14. void display()
  15. {
  16.     char  i, dis[6];
  17.     char code table[] = {
  18.       0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xd8,0x80,0x90};
  19.     char code WEI[] = {1,2,4,8,16,32};
  20.     dis[0] = a / 10; dis[1] = a % 10;
  21.     dis[2] = b / 10; dis[3] = b % 10;
  22.     dis[4] = c / 10; dis[5] = c % 10;
  23.     for (i = 0; i < 6; i++) {
  24.       P0 = table[dis[i]];
  25.       P2 = WEI[i]; delayms(10); P2 = 0;
  26.     }
  27. }
  28. //--------------------------------
  29. init()
  30. {
  31.     PCON = 0;
  32.     SCON = 0x50;
  33.     TMOD = 0x20;
  34.     TH1 = 0xfd;
  35.     TL1 = 0xfd;
  36.     TR1 = 1;
  37.     ES = 1;
  38.     EA = 1;
  39. }
  40. //--------------------------------
  41. main()        //乙机主函数
  42. {
  43.     init();
  44.     while(1) {
  45.       display();
  46.     }
  47. }
  48. //--------------------------------
  49. recv_abc()  interrupt 4  //乙机接收
  50. {
  51.     if (RI) {
  52.       RI = 0;
  53.       d = SBUF;
  54.       if (d == '
  55. )  re_i = 0;
  56.       r_buf[re_i] = d;
  57.       re_i++;
  58.       if (re_i == 7) {
  59.         re_i = 0;
  60.         a = (r_buf[1] - '0') * 10 + (r_buf[2] - '0');
  61.         b = (r_buf[3] - '0') * 10 + (r_buf[4] - '0');
  62.         c = (r_buf[5] - '0') * 10 + (r_buf[6] - '0');
  63.       }
  64.     }
  65. }
  66. //============================================
  67. A 机(产生数据)的程序如下:
  68. //--------------------------------
  69. #include<reg52.h>
  70. unsigned char  a = 13, b = 57, c = 40, d;
  71. bit  sec;
  72. //--------------------------------
  73. init()
  74. {
  75.     PCON = 0;
  76.     SCON = 0x50;
  77.     TMOD = 0x21;
  78.     TH1 = 0xfd;
  79.     TL1 = 0xfd;
  80.     TR1 = 1;
  81.     EA = 1;
  82.     TH0 = 0x4c;
  83.     TR0 = 1;
  84.     ET0 = 1;
  85. }
  86. //--------------------------------
  87. send(unsigned char x)    //甲机发送
  88. {
  89.     SBUF = x;  while(!TI);  TI = 0;
  90. }
  91. //--------------------------------
  92. main()        //甲机主函数
  93. {
  94.     init();
  95.     while(1) {
  96.       if(sec) {
  97.         sec = 0;
  98.         send('
  99. );
  100.         send(a / 10 + '0'); send(a % 10 + '0');
  101.         send(b / 10 + '0'); send(b % 10 + '0');
  102.         send(c / 10 + '0'); send(c % 10 + '0');
  103.     } }
  104. }
  105. //--------------------------------
  106. T0_INT()  interrupt 1  //50ms定时中断函数
  107. {
  108.     TH0 = 0x4c;
  109.     d++;
  110.     if (d >= 2) {  //20
  111.       d = 0;
  112.       sec = 1;
  113.       c++;
  114.       if (c == 60) {
  115.         c = 0;
  116.         b++;
  117.         if (b == 60) {
  118.           b = 0;
  119.           a++;
  120.           if (a == 24) a = 0;
  121.     } } }
  122. }
  123. //============================================
  124. 上述的两个程序,需分别编译,生成不同 HEX 文件;再分别用两个单片机来装入。
  125. 程序执行后,即可显示出来前面插图的效果。B 机的显示器,每秒更新一次数据。
  126. 当把中间的开关断开后,显示的数据便会停顿,不变了。
  127. 再把中间的开关接通后,显示又会变化,而且数据并不受断开的影响。
  128. 这说明,显示的内容,明显是从 A 机传送来的。
  129. //============================================
  130. 本题目,需要传送的数据有时、分、秒共三个,这就属于多字节的串行通信。
  131. 单片机的串行通信,每次只能传送一个字节,即 0~255。
  132. 多字节的数据传送,需要制订协议。
  133. 否则,连续传送一个一个的字节,到了接收方,也不知道哪个是时、哪个是分、哪个是秒。
  134. 这时,一般要采用 ASCII 码来传送。
  135. 用 0~9,即代表了一系列有用的数据。
  136. 再用一个 0~9 之外的符号,当做《数据头》,就行了。
  137. 本程序,就是以美元符 $ 当做数据头。
  138. 传送了 $ 之后,接着就传送时的十位数、时的个位数、分的十位数、分的位数、秒的个位数。
  139. 每次发送数据,就连续的发出七个字节。
  140. 接收方收到了 $ 之后,就把后面再收到的当做时、分、秒的十位、个位保存。
  141. 当收齐了七个字节,就把这后面的六个字节,送去显示。
ID:111634 发表于 2016-11-15 12:22 | 只看该作者
为什么不可以?
ID:147040 发表于 2016-11-15 13:22 来自触屏版 | 只看该作者
admin 发表于 2016-11-15 11:18
简直帅的掉渣,我基本懂了。我还有两个比较2的问题,
第一个,  send(a / 10 + '0');   a = (r_buf[1] - '0')        这里的+'0'  和  -'0'  是什么意思?
第二个,如果SBUF=120;那么发送是把120一块发送过去,还是分三次‘1’,‘2’,‘0’发送。
如果我定义char a=120;SBUF=a;那么有是分几次发送。
再次感谢!
ID:147040 发表于 2016-11-15 13:23 来自触屏版 | 只看该作者
zl2168 发表于 2016-11-15 12:22
为什么不可以?
菜鸟不太懂(;`O)o
ID:148019 发表于 2016-11-15 13:52 | 只看该作者
应该是不一致的
ID:81808 发表于 2016-11-15 23:19 | 只看该作者
第一个,  send(a / 10 + '0');   a = (r_buf[1] - ...
第一个,是数字与ASCII转换;第二个,分一次发送,改善的是120的16进制,就是0x78,二进制是_0111_1000
ID:147040 发表于 2016-11-16 00:05 来自触屏版 | 只看该作者
恩,感谢感谢,又学到了!
ID:148258 发表于 2016-11-16 15:07 | 只看该作者
当然可以了
ID:153758 发表于 2016-12-10 19:53 来自触屏版 | 只看该作者
用$当数据头,可是在keil里输入$,编译会出错。
