查看: 2637|回复: 0
求解,怎样在程序中使k2可以起停程序
ID:154324 发表于 2016-12-14 21:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
sbit K1=P3^2;
sbit beep=P3^7;
sbit K2 = P1^0;
uchar i;
uchar song_Index=0,Tone_Index=0;
uchar*song_Tone,*song_Time;
const LED_tab[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0xFF};
uint code Tone_tab[]={62018,62401,62491,62895,63184,63441,63506,63773,63965,64137,64215,64360,64488,64603,64654,64751,64836,64876,64948,65012,65067,65535};
uchar code song1_Tone[]={11,9,11,14,12,14,12,11,11,7,8,9,8,7,8,11,9,11,14,13,12,14,11,11,7,8,9,6,7, 12,14,14,13,12,13,14,12,13,14,12,12,11,10,7,8,11,9,11,14,13,12,14,11,11,8,9,10,6,7,0xff};
uchar code song1_Time[]={4,2,2,8,4,2,2,8,4,2,2,4,2,2,12,4,2,2,4,2,4,4,8,4,2,2,4,2,12,4,4,8,4,2,2,8,2,2,2,2,2,2,2,2,16, 4,2,2,4,2,4,4,8,4,2,2,4,2,12,0xff};
uchar code song2_Tone[]={ 7,8,9,7,7,8,9,7,9,10,11,9,10,11, 11,12,11,10,9,7,11,12,11,10,9,7,7,4,7,7,4,7,0Xff};
uchar code song2_Time[]={4,4,4,4,4,4,4,4,4,4,8,4,4,8,2,2,2,2,4,4,2,2,2,2,4,4,4,4,8,4,4,8,0xff};
uchar code song3_Tone[]={ 7,7,7,8,9,9,9,9,10,11,12,12,11,10,9,11,11,8,9,7, 7,7,7,8,11,9,9,9,10,11,12,12,11,10,9,11,11,8,9,7,0xff};
uchar code song3_Time[]={ 2,2,2,2,4,2,2,2,2,4,2,2,2,2,4,2,2,2,2,4, 2,2,2,2,4,2,2,2,2,4,2,2,2,2,4,2,2,2,2,5,0Xff};
void delayms(uint ms)  {    uchar a;   while(ms--)
for(a=230;a>0;a--);
void int0() interrupt 0
  delayms(100);
   if(INT0==0)
   {TR0=0;   song_Index++;
   if(song_Index==1)
   song_Tone=song2_Tone;
   song_Time=song2_Time;
   if(song_Index==2)
   song_Tone=song3_Tone;
   song_Time=song3_Time;}
   if(song_Index==3)
   song_Tone=song1_Tone;
   song_Time=song1_Time;
   song_Index=0;
   TR0=1;
    i=0;
        void Timer0() interrupt 1
        TH0=Tone_tab[Tone_Index]/256;
         TL0=Tone_tab[Tone_Index]%256;
          beep=~beep;
     void display(void)
           {P0=LED_tab[song_Index];
     void int_init(void)
                TMOD=0x01;
                ET0=1;
                EX0=1;
                IT0=1;
                EA=1;
                TR0=0;
                void main (void)
                 int_init();
                 display();
                 Tone_Index=song_Tone[i];
                 if(Tone_Index==0xFF)
                 i=0;
                 TR0=0;
                 TR0=1;
                 delayms(song_Time[Tone_Index]*60);
                 TR0=0;
                 i++;
