查看: 2430|回复: 1
求大神赐教这个显示程序是什么意思
ID:158420 发表于 2016-12-28 17:47 | 显示全部楼层 |阅读模式
#include "reg52.h"
unsigned char code dsp_code_ca[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned int tflag;
unsigned char dspflag;
unsigned char second;
unsigned char dflag;
void display(unsigned char d);
  TMOD |= 0x02;
  TH0 = 0x06;
  TL0 = 0x06;
  EA = 1;
  ET0 = 1;
  TR0 = 1;
    display(second);
//T0中断服务函数
void isr_t0(void) interrupt 1
  tflag++;
  dflag++;
  if(dflag == 16)
          dflag = 0;
        dspflag++;
        if(dspflag == 2)
          dspflag = 0;
  if(tflag == 4000)
    tflag = 0;
    second++;
    if(second == 60)
      second = 0;
ID:158420 发表于 2016-12-28 17:54 | 显示全部楼层
//显示程序 void display(unsigned char d) {   if((dspflag == 0) && (d/10 != 0))   {         P0 = 0xFF;     P2 |= 0xE0;     P2 &= 0x1F;          P0 = dsp_code_ca[d/10];     P2 |= 0xE0;     P2 &= 0x1F;     P0 = 0x40;     P2 |= 0xC0;     P2 &= 0x3F;   }    if(dspflag == 1)   {     P0 = 0xFF;         P2 |= 0xE0;     P2 &= 0x1F;          P0 = dsp_code_ca[d%10];      P2 |= 0xE0;     P2 &= 0x1F;     P0 = 0x80;     P2 |= 0xC0;     P2 &= 0x3F;   }   }
