查看: 6163|回复: 10
求大神帮我把流水灯定时与蜂鸣器程序改正确,大体不变
20黑币
  1. #include<reg52.h>
  2. #include<present.h>
  3. sbit Buzz=P3^7;
  4. uchar flag=16,sign=1;
  5. uchar time=0;                 //流水灯定时
  6. uint *pf=Happy_Birthday;
  7. uint *p=Happy_Birthday;
  8. void init_devices(void)
  9. {
  10.         TMOD=0x11;
  11.         TH1=0x71;
  12.         TL1=0x48;        //40ms的定时
  13.         TH0=0x00;
  14.         TL0=0x00;        //初始化
  15.         IT1=1;
  16.         EA=1;
  17.         EX1=1;
  18.         ET0=1;
  19.         ET1=1;
  20. }
  21. void int1() interrupt 2 using 0
  22. {
  23.         sign++;        //下一曲
  24.         switch(sign)
  25.         {        case 1:TR0=1;pf=Happy_Birthday;flag=16;break;
  26.                 case 2:pf=Legend;flag=8;break;
  27.                 case 3:pf=Childhood;flag=8;break;
  28.                 case 4:TR0=0;sign=0;Buzz=1;break;//停唱Buzz=1,三极管关断,防止大电流
  29.                 default :pf=Happy_Birthday;flag=16;break;
  30.         }
  31.     p=pf;
  32. }
  33. //定时器0产生频率
  34. void timer0() interrupt 1 using 1
  35. {
  36.         uint temp=65536-*p;
  37.         TH0=(uchar)(temp>>8);
  38.         TL0=(uchar)temp;
  39.         if(*p) Buzz^=1;
  40.         else Buzz=1;        //Buzz=1,三极管关断,防止大电流
  41. }
  42. //定时器1产生40ms延时
  43. void timer1() interrupt 3 using 2
  44. {
  45.         TH1=0x71;
  46.         TL1=0x48;        //40ms的定时
  47.
  48.         if(flag==0)
  49.         {
  50.                 flag=*(p+1);
  51.                 if(flag==0)
  52.                 {
  53.                         p=pf;
  54.                         flag=*(p+1);
  55.                 }
  56.                 else
  57.                 {        p++;
  58.                         p++;
  59.                 }
  60.         }
  61.         else flag--;
  62.         time++;                //流水灯定时
  63.         if(time%5==0)
  64.         {  switch(time)
  65.            {case 5:P0=0x01;break;
  66.             case 10:P0=0x02;break;
  67.                   case 15:P0=0x04;break;
  68.                 case 20:P0=0x08;break;
  69.             case 25:P0=0x10;break;
  70.                   case 30:P0=0x20;break;
  71.                 case 35:P0=0x40;break;
  72.                 case 40:P0=0x80;time=0;break;
  73.                 default :time=0;break;
  74.            }
  75.         }
  76. }
  77. void delay(uint i)
  78. {
  79.         while(i--);
  80. }
  81. void word(uchar *ps)         //显示单个字符
  82. {        uchar i,j;
  83.         uchar _bit=0X80;
  84.         for(i=0;i<200;i++)
  85.         {
  86.                 for(j=0;j<8;j++)
  87.                 {  P1=0xff;
  88.                    P2=~_bit;
  89.                    P1=*(ps+j);
  90.                    delay(100);
  91.                    _bit>>=1;
  92.                 }
  93.                 _bit=0X80;
  94.         }
  95. }
  96. void display(uchar *ps)         //显示移动字符
  97. {        uchar i,j;
  98.         uchar _bit=0X80;
  99.         while(*(ps+8)!=0xaa)
  100.         {
  101.                 for(i=0;i<20;i++)
  102.                 {
  103.                                 for(j=0;j<8;j++)
  104.                                 {  P1=0xff;
  105.                                    P2=~_bit;
  106.                                    P1=*(ps+j);
  107.                                    delay(100);
  108.                                    _bit>>=1;
  109.                                 }
  110.                         _bit=0x80;
  111.                 }
  112.                 ps++;
  113.         }
  114. }
  115. void main()
  116. {        uchar i;
  117.         init_devices();
  118.         for(i=0;i<6;i++) word(figure[i]);
  119.         word(arrow);
  120.         word(arrow);
  121.         TR0=1;
  122.         TR1=1;
  123.         while(1)
  124.         {
  125.                 display(str1);
  126.                 display(str1);
  127.                 display(str2);
  128.         }
  129. }
ID:151348 发表于 2017-3-20 21:28 | 只看该作者
这样的问题最好把你的程序和仿真文件都传上来,不然也没人愿意花时间去帮你改
ID:157662 发表于 2017-3-20 23:03 | 只看该作者
不能上传C文件和仿真文件
不能上传C文件和仿真文件
ID:175877 发表于 2017-3-21 00:43 | 只看该作者
没有上拉吧
ID:151348 发表于 2017-3-21 08:46 | 只看该作者
1130555300 发表于 2017-3-20 23:03
不能上传C文件和仿真文件
打包上传
ID:157662 发表于 2017-3-21 09:14 | 只看该作者
是程序问题,
ID:157662 发表于 2017-3-21 12:26 | 只看该作者
是程序问题
ID:176808 发表于 2017-3-21 14:50 | 只看该作者
#include<reg52.h>
02.#include<present.h>
03.
04.sbit Buzz=P3^7;
05.
06.uchar flag=16,sign=1;
07.uchar time=0;                 //流水灯定时
08.uint *pf=Happy_Birthday;
09.uint *p=Happy_Birthday;
10.
11.void init_devices(void)
12.{
13.        TMOD=0x11;
14.        TH1=0x71;
15.        TL1=0x48;        //40ms的定时
16.        TH0=0x00;
17.        TL0=0x00;        //初始化
18.        IT1=1;
19.        EA=1;
20.        EX1=1;
21.        ET0=1;
22.        ET1=1;
23.}
24.
25.void int1() interrupt 2 using 0
26.{
27.        sign++;        //下一曲
28.        switch(sign)
29.        {        case 1:TR0=1;pf=Happy_Birthday;flag=16;break;
30.                case 2:pf=Legend;flag=8;break;
31.                case 3:pf=Childhood;flag=8;break;
32.                case 4:TR0=0;sign=0;Buzz=1;break;//停唱Buzz=1,三极管关断,防止大电流
33.                default :pf=Happy_Birthday;flag=16;break;
34.        }
35.    p=pf;
36.}
37.
38.//定时器0产生频率
39.void timer0() interrupt 1 using 1
40.{
41.        uint temp=65536-*p;
42.        TH0=(uchar)(temp>>8);
43.        TL0=(uchar)temp;
44.        if(*p) Buzz^=1;
45.        else Buzz=1;        //Buzz=1,三极管关断,防止大电流
46.
47.}
48.
49.//定时器1产生40ms延时
50.void timer1() interrupt 3 using 2
51.{
52.        TH1=0x71;
53.        TL1=0x48;        //40ms的定时
54.
55.        if(flag==0)
56.        {
57.                flag=*(p+1);
58.                if(flag==0)
59.                {
60.                        p=pf;
61.                        flag=*(p+1);
62.                }
63.                else
64.                {        p++;
65.                        p++;
66.                }
67.        }
68.        else flag--;
69.        time++;                //流水灯定时
70.        if(time%5==0)
71.        {  switch(time)
72.           {case 5:P0=0x01;break;
73.            case 10:P0=0x02;break;
74.                  case 15:P0=0x04;break;
75.                case 20:P0=0x08;break;
76.            case 25:P0=0x10;break;
77.                  case 30:P0=0x20;break;
78.                case 35:P0=0x40;break;
79.                case 40:P0=0x80;time=0;break;
80.                default :time=0;break;
81.           }
82.        }
83.}
84.
85.void delay(uint i)
86.{
87.        while(i--);
88.}
89.void word(uchar *ps)         //显示单个字符
90.{        uchar i,j;
91.        uchar _bit=0X80;
92.        for(i=0;i<200;i++)
93.        {
94.                for(j=0;j<8;j++)
95.                {  P1=0xff;
96.                   P2=~_bit;
97.                   P1=*(ps+j);
98.                   delay(100);
99.                   _bit>>=1;
100.                }
101.                _bit=0X80;
102.        }
103.}
104.void display(uchar *ps)         //显示移动字符
105.{        uchar i,j;
106.        uchar _bit=0X80;
107.        while(*(ps+8)!=0xaa)
108.        {
109.                for(i=0;i<20;i++)
110.                {
111.                                for(j=0;j<8;j++)
112.                                {  P1=0xff;
113.                                   P2=~_bit;
114.                                   P1=*(ps+j);
115.                                   delay(100);
116.                                   _bit>>=1;
117.                                }
118.                        _bit=0x80;
119.                }
120.                ps++;
121.        }
122.}
123.
124.void main()
125.{        uchar i;
126.        init_devices();
127.        for(i=0;i<6;i++) word(figure[i]);
128.        word(arrow);
129.        word(arrow);
130.        TR0=1;
131.        TR1=1;
132.        while(1)
133.        {
134.                display(str1);
135.                display(str1);
136.                display(str2);
137.        }
138.}
ID:157662 发表于 2017-3-21 18:27 | 只看该作者
好像没有变吧
ID:157662 发表于 2017-3-21 18:28 | 只看该作者
已经上传了,帮我看一下吧
