查看: 5650|回复: 7
gps解析程序
ID:190341 发表于 2017-4-17 10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
gps解析程序
ID:190341 发表于 2017-4-17 10:39 | 只看该作者
#include "main.h"
#include "uart.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
//定义变量
//主函数
        unsigned char i = 0;
        Uart_Init();
        Delay_ms(10);
        UartPrintf("Welcome to use!");
        UartPrintf("ILoveMCU.taobao.com");
        clrStruct();        //清空缓存数组
                parseGpsBuffer();
                printGpsBuffer();
void errorLog(int num)
        while (1)
                  UartPrintf("ERROR");
                UartPrintASCII(num+0x30);
                UartPrintf("\r\n");
void parseGpsBuffer()
        char *subString;
        char *subStringNext;
        char i = 0;
        if (Save_Data.isGetData)
                Save_Data.isGetData = false;
                UartPrintf("**************\r\n");
                UartPrintf(Save_Data.GPS_Buffer);
                for (i = 0 ; i <= 6 ; i++)
                        if (i == 0)
                                if ((subString = strstr(Save_Data.GPS_Buffer, ",")) == NULL)
                                        errorLog(1);        //解析错误
                                subString++;
                                if ((subStringNext = strstr(subString, ",")) != NULL)
                                        char usefullBuffer[2];
                                        switch(i)
                                                case 1:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break;        //获取UTC时间
                                                case 2:memcpy(usefullBuffer, subString, subStringNext - subString);break;        //获取UTC时间
                                                case 3:memcpy(Save_Data.latitude, subString, subStringNext - subString);break;        //获取纬度信息
                                                case 4:memcpy(Save_Data.N_S, subString, subStringNext - subString);break;        //获取N/S
                                                case 5:memcpy(Save_Data.longitude, subString, subStringNext - subString);break;        //获取经度信息
                                                case 6:memcpy(Save_Data.E_W, subString, subStringNext - subString);break;        //获取E/W
                                                default:break;
                                        subString = subStringNext;
                                        Save_Data.isParseData = true;
                                        if(usefullBuffer[0] == 'A')
                                                Save_Data.isUsefull = true;
                                        else if(usefullBuffer[0] == 'V')
                                                Save_Data.isUsefull = false;
                                        errorLog(2);        //解析错误
void printGpsBuffer()
        if (Save_Data.isParseData)
                Save_Data.isParseData = false;
                UartPrintf("Save_Data.UTCTime = ");
                UartPrintf(Save_Data.UTCTime);
                UartPrintf("\r\n");
                if(Save_Data.isUsefull)
                        UartPrintf("Save_Data.latitude = ");
                        UartPrintf(Save_Data.latitude);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.N_S = ");
                        UartPrintf(Save_Data.N_S);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.longitude = ");
                        UartPrintf(Save_Data.longitude);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.E_W = ");
                        UartPrintf(Save_Data.E_W);
                        UartPrintf("\r\n");
                        UartPrintf("GPS DATA is not usefull!\r\n");
//MS延时函数
void Delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
ID:190341 发表于 2017-4-17 10:40 | 只看该作者
#include "uart.h"
char idata gpsRxBuffer[gpsRxBufferLength];
unsigned char RX_Count = 0;
_SaveData Save_Data;
void Uart_Init()
        SCON = 0X50;  //UART方式1;8位UART
        REN  = 1;     //允许串行口接收数据
        PCON = 0x00;  //SMOD=0;波特率不加倍
        TMOD = 0x20;  //T1方式2,用于产生波特率
        TH1  = 0xFD;  //装初值
        TL1  = 0xFD;
        TR1  = 1;     //启动定时器1
        EA   = 1;     //打开全局中断控制
        ES   = 1;     //打开串行口中断
void UartPrintf(unsigned char *p)                                //发送字符串
        while(*p)
                 SBUF=*(p++);
                while(TI==0)
                TI=0;
void UartPrintASCII(unsigned char c)                                //发送一个字符
    TI=0;
    SBUF=c;
    while(TI==0);
    TI=0;
void RECEIVE_DATA(void) interrupt 4 using 3
        unsigned char temp = 0;
        char i = 0;
        ES=0;
        temp = SBUF;
        RI = 0;
        if(temp == '$')
                RX_Count = 0;
        if(RX_Count <= 5)
           gpsRxBuffer[RX_Count++] = temp;
        else if(gpsRxBuffer[0] == '$' &gpsRxBuffer[4] == 'M' && gpsRxBuffer[5] == 'C')                        //确定是否收到"GPRMC/GNRMC"这一帧数据
                if(temp == '\n')
                        memset(Save_Data.GPS_Buffer, 0, GPS_Buffer_Length);      //清空
                        memcpy(Save_Data.GPS_Buffer, gpsRxBuffer, RX_Count);         //保存数据
                        Save_Data.isGetData = true;
                        RX_Count = 0;
                        memset(gpsRxBuffer, 0, gpsRxBufferLength);      //清空
                if(RX_Count >= 75)
                        RX_Count = 75;
                        gpsRxBuffer[RX_Count] = '\0';//添加结束符
        ES=1;
void clrStruct()
        memset(Save_Data.UTCTime, 0, UTCTime_Length);
        memset(Save_Data.latitude, 0, latitude_Length);
        memset(Save_Data.N_S, 0, N_S_Length);
        memset(Save_Data.longitude, 0, longitude_Length);
        memset(Save_Data.E_W, 0, E_W_Length);
#ifndef __GPS_H__
#define __GPS_H__
#include <reg52.h>
#include "main.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define false 0
#define true 1
//定义数组长度
#define GPS_Buffer_Length 80
#define UTCTime_Length 11
#define latitude_Length 11
#define N_S_Length 2
#define longitude_Length 12
#define E_W_Length 2
typedef struct SaveData
        char GPS_Buffer[GPS_Buffer_Length];
        char isGetData;                //是否获取到GPS数据
        char isParseData;        //是否解析完成
        char UTCTime[UTCTime_Length];                //UTC时间
        char latitude[latitude_Length];                //纬度
        char N_S[N_S_Length];                //N/S
        char longitude[longitude_Length];                //经度
        char E_W[E_W_Length];                //E/W
        char isUsefull;                //定位信息是否有效
} xdata _SaveData;
//函数或者变量声明
extern void Uart_Init();
extern void UartPrintf(unsigned char *p);
extern void UartPrintASCII(unsigned char c);
extern void clrStruct();
#define gpsRxBufferLength  76
extern char idata gpsRxBuffer[gpsRxBufferLength];
extern unsigned char RX_Count;
extern _SaveData Save_Data;
#endif
#ifndef __MAIN_H__
#define __MAIN_H__
#include <reg52.h>
//函数或者变量声明
extern void Delay_ms(unsigned int n);
extern void printGpsBuffer();
extern void parseGpsBuffer();
extern void errorLog(int num);
#endif
ID:192967 发表于 2017-4-24 10:43 | 只看该作者
北斗的解析程序可以用这个吗?
ID:194482 发表于 2017-4-28 20:32 | 只看该作者
虽然不太懂、直觉上就觉得不可以。
一台设备同时受到gps、北斗信号,怎么输出定位信息。
ID:553238 发表于 2019-7-23 18:59 | 只看该作者
我也在看这个程序 你看懂他了吗?
