查看: 3034|回复: 0
单片机开发板附带键盘检测源程序
ID:189450 发表于 2017-4-17 11:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. uchar code table[] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07,
  5.                      0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
  6. void delay1ms(uchar x)
  7. {
  8.         uint i,j;
  9.         for(i = x;i > 0;i --)
  10.                 for(j = 110;j > 0;j --);
  11. }
  12. void display(uchar num)
  13. {
  14.         P0 = ~table[num];
  15. }
  16. /*
  17. *键盘扫描程序
  18. */
  19. void keyscanf()
  20. {
  21.         uchar temp, key;
  22.         P2 = 0Xef;
  23.         temp = P2;
  24.         temp = temp & 0x0f;
  25.         if(temp != 0x0f)
  26.         {
  27.                 delay1ms(5);//去抖动
  28.                 temp=P2;
  29.                 temp = temp & 0x0f;
  30.                 if(temp != 0x0f)
  31.                 {
  32.                         temp = P2;
  33.                         switch(temp)//此时按键已经定位到第一行了
  34.                         {
  35.                                 case 0xe7: key = 0; break;//此时代表第一行的第一个按键按下,即11101110
  36.                                 case 0xeb: key = 1; break;
  37.                                 case 0xed: key = 2; break;
  38.                                 case 0xee: key = 3; break;
  39.                         }
  40.                         while(temp != 0x0f)//按键松开
  41.                         {
  42.                                 temp = P2;
  43.                                 temp = temp & 0x0f;
  44.                         }
  45.                         display(key);
  46.                 }
  47.         }
  48.         P2 = 0Xdf;
  49.         temp = P2;
  50.         temp = temp & 0x0f;
  51.         if(temp != 0x0f)
  52.         {
  53.                 delay1ms(5);//去抖动
  54.                 temp = P2;
  55.                 temp = temp & 0x0f;
  56.                 if(temp != 0x0f)
  57.                 {
  58.                         temp = P2;
  59.                         switch(temp)//此时按键已经定位到第er行了
  60.                         {
  61.                                 case 0xd7: key = 4; break;//此时代表第一行的第一个按键按下,即11011110
  62.                                 case 0xdb: key = 5; break;
  63.                                 case 0xdd: key = 6; break;
  64.                                 case 0xde: key = 7; break;
  65.                         }
  66.                         while(temp != 0x0f)//按键松开
  67.                         {
  68.                                 temp = P2;
  69.                                 temp = temp & 0x0f;
  70.                         }
  71.                         display(key);
  72.                 }
  73.         }
  74.         P2 = 0Xbf;
  75.         temp = P2;
  76.         temp = temp & 0x0f;
  77.         if(temp != 0x0f)
  78.         {
  79.                 delay1ms(5);//去抖动
  80.                 temp=P2;
  81.                 temp = temp & 0x0f;
  82.                 if(temp != 0x0f)
  83.                 {
  84.                         temp = P2;
  85.                         switch(temp)//此时按键已经定位到第san行了
  86.                         {
  87.                                 case 0xb7: key = 8; break;//此时代表第一行的第一个按键按下,即10111110
  88.                                 case 0xbb: key = 9; break;
  89.                                 case 0xbd: key = 10; break;
  90.                                 case 0xbe: key = 11; break;
  91.                         }
  92.                         while(temp != 0x0f)//按键松开
  93.                         {
  94.                                 temp = P2;
  95.                                 temp = temp & 0x0f;
  96.                         }
  97.                         display(key);
  98.                 }
  99.         }
  100.         P2 = 0X7f;
  101.         temp = P2;
  102.         temp = temp & 0x0f;
  103.         if(temp != 0x0f)
  104.         {
  105.                 delay1ms(5);//去抖动
  106.                 temp=P2;
  107.                 temp = temp & 0x0f;
  108.                 if(temp != 0x0f)
  109.                 {
  110.                         temp = P2;
  111.                         switch(temp)//
  112.                         {
  113.                                 case 0x77: key = 12; break;//此时代表第一行的第一个按键按下,即01111110
  114.                                 case 0x7b: key = 13; break;
  115.                                 case 0x7d: key = 14; break;
  116.                                 case 0x7f: key = 15; break;
  117.                         }
  118.                         while(temp != 0x0f)//按键松开
  119.                         {
  120.                                 temp = P2;
  121.                                 temp = temp & 0x0f;
  122.                         }
  123.                         display(key);
  124.                 }
  125.         }
  126. }
  127. void main()
  128. {
  129.         P0 = 0xff;
  130.         while(1)
  131.         {
  132.                 keyscanf();
  133.         }
  134. }
数码管显示字.zip
39.64 KB, 下载次数: 8, 下载积分: 黑币 -5
