查看: 2512|回复: 0
蓝牙遥控小车程序
ID:191600 发表于 2017-4-22 13:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<AT89x51.H>
#define A_left_moto_go  {P2_0 = 1,P2_1 = 0;}   //左前轮向前
#define A_left_moto_back {P2_0 = 0,P2_1 = 1;}   //左前轮向后
#define A_left_moto_stop {P2_0 = 0,P2_1 = 0;}    //左前轮停止
#define B_left_moto_go {P2_2 = 1,P2_3 = 0;}  //
#define B_left_moto_back {P2_2 = 0,P2_3 = 1;} //
#define B_left_moto_stop {P2_2 = 0,P2_3 = 0;}   //
#define A_right_moto_go {P1_0 = 1,P1_1 = 0;}  //右前轮向前
#define A_right_moto_back {P1_0 = 0,P1_1 = 1;}  //右前轮向后
#define A_right_moto_stop {P1_0 = 0,P1_1 = 0;}
#define B_right_moto_go {P1_2 = 1,P1_3 = 0;}  //
#define B_right_moto_back {P1_2 = 0,P1_3 = 1;}
#define B_right_moto_stop {P1_2 = 0,P1_3 = 0;}
#define uint    unsigned int                          //??????????
#define uchar   unsigned char                         //??????????
sbit BZ=P3^7;
a=0;
void delay(uchar z)//??????????
int i,j;//??????
for(i=10;i>0;i--)
for(j=z;j>0;j--);//???z???j
void uart_init()
  TMOD = 0x20;
  PCON = 0x00;
  SCON = 0x50;
  TH1 = 0xFd;  //????? 9600
  TL1 = 0xFd;
  TR1 = 1;     //?????1
  ES = 1;      //?????
  EA = 1;      //????
  BZ=1;
void run()
         A_left_moto_go;
         A_right_moto_go;
         B_left_moto_go;
         B_right_moto_go;
void back_run()
         A_left_moto_back;
         A_right_moto_back;
         B_left_moto_back;
         B_right_moto_back;
void stop_run()
         A_left_moto_stop;
         A_right_moto_stop;
         B_left_moto_stop;
         B_right_moto_stop;
void left_run()
         A_left_moto_back;
         A_right_moto_go;
         B_left_moto_back;
         B_right_moto_go;
void right_run()
         A_left_moto_go;
         A_right_moto_back;
         B_left_moto_go;
         B_right_moto_back;
void uart() interrupt 4
if(RI==1)
RI=0;
a=SBUF;
//P0=0XFF;
uart_init();
  if(BZ==0)   stop_run();
  if(a==0x00) stop_run();
  if(a==0x3f) run();
  if(a==0x4f) back_run();
  if(a==0x1f) left_run();
  if(a==0x2f) right_run();
  if(a==0x5f) left_run();
  if(a==0x6f) right_run();
  if(a==0x7f) left_run();
  if(a==0x8f) right_run();
