查看: 2624|回复: 0
家庭温控使用的资料 源码
仅供参考哈
家庭温控使用的资料 源码,谢谢支持
完整代码下载:
UltrasonicR Success!.zip (63.69 KB, 下载次数: 11)
源程序:
  1. #define uint unsigned int
  3. #define GPIO_LED P2                //将P2口另外取名为GPIO_LED
  4. #include"lcd.h"
  5. #include<reg51.h>
  6. #include<intrins.h>
  7. #include<stdio.h>
  8. sbit io=P0^3;
  9. sbit rs=P2^6;
  10. sbit rw=P2^5;
  11. sbit lcden=P2^7;
  12. sbit key1=P1^4;                          //位操作
  13. sbit key2=P1^5;
  14. sbit key3=P1^6;
  15. sbit key4=P1^7;
  16. sbit key5=P3^5;
  17. sbit Trig=P2^1;
  18. sbit Beep=P2^1;
  19. sbit Echo = P2^0;                                  //////////////////////******************************************//////////////////////
  20. int menu=0;
  21. unsigned long TN=26;
  22. unsigned long TE=26;
  23. unsigned char menu1[]="#1 Warning Tem";
  24. unsigned char menu2[]="#2 WarningTeEdit";
  25. unsigned char menu3[]="#3 Music";
  26. unsigned char menu4[]="#4 UltrasonicR";
  27. unsigned char menu5[]="#5 More funtions";
  28. unsigned char Wt[]="HereisWarningTem";
  29. unsigned char Et[]="Original:";
  30. unsigned char Et1[]="Edit:";
  31. unsigned char open1[]="Hello,everyone";
  32. unsigned char open2[]="Welcom to here";
  33. unsigned char table[]="Hello,everyone";
  34. unsigned char table1[]="Welcom to here";
  35. unsigned char music[]="Laurel Blossom";
  36. unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','C'};
  37. static unsigned char DisNum = 0; //显示用指针
  38.        unsigned int  time=0;
  39.            unsigned long S=0;
  40.            unsigned long Wtnow=26;
  41.            unsigned long wedit=26;
  42.            bit      flag =0;
  43. void DisplayOneChar(uchar, uchar, uchar);
  44. unsigned char disbuff[4]           ={ 0,0,0,0,};
  45. unsigned char DST[]="The Distance";
  46. void Delay50ms(unsigned int c)   //误差 0us
  47. {
  48.     unsigned char a,b;
  49.     for(;c>0;c--)
  50.         for(b=38;b>0;b--)
  51.             for(a=130;a>0;a--);
  52.                         }
  53. void Delay10ms(void)   //误差 0us
  54. {
  55.     unsigned char a,b,c;
  56.     for(c=1;c>0;c--)
  57.         for(b=38;b>0;b--)
  58.             for(a=130;a>0;a--);
  59. }        ///////////////////////////////////////////////////////
  60. ///////////////////////////////////////////////////////////////////////////////////////////////
  61. void Conut(void)
  62.         {        //time=100*S/1.7
  63.          time=TH0*256+TL0;
  64.          TH0=0;
  65.          TL0=0;
  66.
  67.          S=(time*1.7)/100;     //算出来是CM
  68.         if((S>=700)||flag==1) //超出测量范围显示“-”
  69.          {
  70.           flag=0;
  71.
  72.           DisplayOneChar(0, 1, ASCII[11]);
  73.           DisplayOneChar(1, 1, ASCII[10]);        //显示点
  74.           DisplayOneChar(2, 1, ASCII[11]);
  75.           DisplayOneChar(3, 1, ASCII[11]);
  76.           DisplayOneChar(4, 1, ASCII[12]);        //显示M
  77.          }
  78.          else
  79.          {
  80.           disbuff[0]=S%1000/100;
  81.           disbuff[1]=S%1000%100/10;
  82.           disbuff[2]=S%1000%10 %10;
  83.           DisplayOneChar(0, 1, ASCII[disbuff[0]]);
  84.           DisplayOneChar(1, 1, ASCII[10]);        //显示点
  85.           DisplayOneChar(2, 1, ASCII[disbuff[1]]);
  86.           DisplayOneChar(3, 1, ASCII[disbuff[2]]);
  87.           DisplayOneChar(4, 1, 'M');        //显示M
  88.
  89.         }
  90. }
  91. void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
  92.   {
  93.     flag=1;                                                         //中断溢出标志
  94.   }
  95. void  StartModule()                          //启动模块
  96.   {
  97.
  98.           Trig=1;                                             //启动一次模块
  99.           _nop_();
  100.           _nop_();
  101.           _nop_();
  102.           _nop_();
  103.           _nop_();
  104.           _nop_();
  105.           _nop_();
  106.           _nop_();
  107.           _nop_();
  108.           _nop_();
  109.           _nop_();
  110.           _nop_();
  111.           _nop_();
  112.           _nop_();
  113.           _nop_();
  114.           _nop_();
  115.           _nop_();
  116.           _nop_();
  117.           _nop_();
  118.           _nop_();
  119.           _nop_();
  120.           Trig=0;
  121.   }
  122.        ///////////////////////////////////////////////////////////        ////
  123.        ///////////////////////////////////////////////////////////////////
  124. void delayms(unsigned int ms)
  125. {
  126.         unsigned char i=100,j;
  127.         for(;ms;ms--)
  128.         {
  129.                 while(--i)
  130.                 {
  131.                         j=10;
  132.                         while(--j);
  133.                 }
  134.         }
  135. }
  136. unsigned char n=0;  //n为节拍常数变量
  137. unsigned char code music_tab[] ={
  138. 0x18, 0x30, 0x1C , 0x10, //格式为: 频率常数, 节拍常数, 频率常数, 节拍常数,
  139. 0x20, 0x40, 0x1C , 0x10,
  140. 0x18, 0x10, 0x20 , 0x10,
  141. 0x1C, 0x10, 0x18 , 0x40,
  142. 0x1C, 0x20, 0x20 , 0x20,
  143. 0x1C, 0x20, 0x18 , 0x20,
  144. 0x20, 0x80, 0xFF , 0x20,
  145. 0x30, 0x1C, 0x10 , 0x18,
  146. 0x20, 0x15, 0x20 , 0x1C,
  147. 0x20, 0x20, 0x20 , 0x26,
  148. 0x40, 0x20, 0x20 , 0x2B,
  149. 0x20, 0x26, 0x20 , 0x20,
  150. 0x20, 0x30, 0x80 , 0xFF,
  151. 0x20, 0x20, 0x1C , 0x10,
  152. 0x18, 0x10, 0x20 , 0x20,
  153. 0x26, 0x20, 0x2B , 0x20,
  154. 0x30, 0x20, 0x2B , 0x40,
  155. 0x20, 0x20, 0x1C , 0x10,
  156. 0x18, 0x10, 0x20 , 0x20,
  157. 0x26, 0x20, 0x2B , 0x20,
  158. 0x30, 0x20, 0x2B , 0x40,
  159. 0x20, 0x30, 0x1C , 0x10,
  160. 0x18, 0x20, 0x15 , 0x20,
  161. 0x1C, 0x20, 0x20 , 0x20,
  162. 0x26, 0x40, 0x20 , 0x20,
  163. 0x2B, 0x20, 0x26 , 0x20,
  164. 0x20, 0x20, 0x30 , 0x80,
  165. 0x20, 0x30, 0x1C , 0x10,
  166. 0x20, 0x10, 0x1C , 0x10,
  167. 0x20, 0x20, 0x26 , 0x20,
  168. 0x2B, 0x20, 0x30 , 0x20,
  169. 0x2B, 0x40, 0x20 , 0x15,
  170. 0x1F, 0x05, 0x20 , 0x10,
  171. 0x1C, 0x10, 0x20 , 0x20,
  172. 0x26, 0x20, 0x2B , 0x20,
  173. 0x30, 0x20, 0x2B , 0x40,
  174. 0x20, 0x30, 0x1C , 0x10,
  175. 0x18, 0x20, 0x15 , 0x20,
  176. 0x1C, 0x20, 0x20 , 0x20,
  177. 0x26, 0x40, 0x20 , 0x20,
  178. 0x2B, 0x20, 0x26 , 0x20,
  179. 0x20, 0x20, 0x30 , 0x30,
  180. 0x20, 0x30, 0x1C , 0x10,
  181. 0x18, 0x40, 0x1C , 0x20,
  182. 0x20, 0x20, 0x26 , 0x40,
  183. 0x13, 0x60, 0x18 , 0x20,
  184. 0x15, 0x40, 0x13 , 0x40,
  185. 0x18, 0x80, 0x00
  186. };
  187.
  188. void int0()  interrupt 1   //采用中断0 控制节拍
  189. {  TH0=0xd8;
  190.    TL0=0xef;
  191.    n--;
  192. }
  193.
  194. void delay (unsigned char m)   //控制频率延时
  195. {
  196. unsigned i=3*m;
  197. while(--i);
  198. }
  199.
  200. void delayms1(unsigned char a)  //豪秒延时子程序
  201. {
  202.   while(--a);                  //采用while(--a) 不要采用while(a--); 各位可编译一下看看汇编结果就知道了!
  203. }
  204. void keyscan()    //按键扫描
  205. {
  206. if(key1==0)
  207. {
  208.   Delay10ms();//防抖
  209.   if(key1==0)
  210.   {
  211.    menu=1;
  212.    while(!key1); //等待按键释放
  213.   }
  214. }
  215. if(key2==0)
  216. {
  217.   Delay10ms();//防抖
  218.   if(key2==0)
  219.   {
  220.           switch(menu)
  221.           {
  222.           case 1:menu=2;break;
  223.           case 2:menu=3;break;
  224.           case 3:menu=4;break;
  225.           case 4:menu=5;break;
  226.           case 5:menu=1;break;
  227.       case 11:TE--;break;
  228.           }
  229.          while(!key2); //等待按键释放
  230.   }
  231. }
  232. if(key3==0)
  233. {
  234.
  235.   Delay10ms();//防抖
  236.   if(key3==0)
  237. {
  238. switch(menu)
  239. {
  240. case 1:menu=5;break;
  241. case 2:menu=1;break;
  242. case 3:menu=2;break;
  243. case 4:menu=3;break;
  244. case 5:menu=4;break;
  245. case 11:TE++;break;
  246. }
  247.   while(!key3); //等待按键释放
  248. }
  249. }
  250. if(key4==0)
  251. {
  252. Delay10ms();//防抖
  253.   if(key4==0)
  254.   {
  255.    switch(menu)
  256. {
  257. case 1:menu=10;break;
  258. case 2:menu=11;break;
  259. case 3:menu=12;break;
  260. case 4:menu=13;break;
  261. case 11:TN=TE;break;
  262. }
  263.    while(!key4); //等待按键释放
  264.   }
  265. }
  266. if(key5==0)
  267. {
  268.   Delay10ms();//防抖
  269.   if(key5==0)
  270.   {
  271.   switch(menu)
  272. {
  273. case 10:menu=1;break;
  274. case 11:menu=2;break;
  275. case 12:menu=3;break;
  276. case 13:menu=4;break;
  277. default:menu=0;
  278. }
  279.         while(!key5); //等待按键释放
  280.   }
  281. }
  282. }
  283.
  284. void music_p()
  285. { unsigned char p,m;   //m为频率常数变量
  286.   unsigned char i=0;
  287.   TMOD&=0x0f;
  288.   TMOD|=0x01;
  289.   TH0=0xd8;TL0=0xef;
  290.   IE=0x82;
  291. play:
  292.    while(menu==12)
  293.     {
  294.     a: p=music_tab[i];
  295.        if(p==0x00)       { i=0, delayms1(1000); goto play;}     //如果碰到结束符,延时1秒,回到开始再来一遍
  296.        else if(p==0xff)  { i=i+1;delayms1(100),TR0=0; goto a;}  //若碰到休止符,延时100ms,继续取下一音符
  297.             else         {m=music_tab[i++], n=music_tab[i++];}  //取频率常数 和 节拍常数
  298.              TR0=1;                                             //开定时器1
  299.            while(n!=0) Beep=~Beep,delay(m);                         //等待节拍完成, 通过P1口输出音频(可多声道哦!)
  300.        TR0=0;                                       //关定时器1
  301.
  302.         keyscan();
  303.   }
  304. }
  305. void led()
  306. {
  307.         unsigned char n;
  308.         GPIO_LED=0xfe;                        //1111_1110
  309.         while(menu==0)
  310.         {
  311.                 for(n=0;n<7;n++)                                                          //左移7次,这样子就会到达最左边
  312.                 {
  313.                         GPIO_LED=_crol_(GPIO_LED,1);                          //将GPIO_LED左移一位
  314.                     Delay50ms(10);                                                         //延时
  315.                 }
  316.                 for(n=0;n<7;n++)                                                         //右移7次,这样子就会到达最右边
  317.                 {
  318.                         GPIO_LED=_cror_(GPIO_LED,1);                                        //将GPIO_LED右移一位
  319.                         Delay50ms(10);
  320.                 }
  321.
  322.         keyscan();
  323.         }
  324. }
  325. void main()
  326. {
  327.     TMOD=0x01;                   //设T0为方式1,GATE=1;
  328.          TH0=0;
  329.          TL0=0;
  330.          ET0=1;             //允许T0中断
  331.          EA=1;                           //开启总中断
  332.          while(1)
  333.          {
  334.                   StartModule();
  335.              while(!Echo);                //当RX为零时等待
  336.              TR0=1;                            //开启计数
  337.              while(Echo);                        //当RX为1计数并等待
  338.              TR0=0;                                //关闭计数
  339.
  340.          S=((TH0*256+TL0)*1.7)/100;
  341.          TH0=0;
  342.          TL0=0;
  343.          delayms(10);
  344.          if(S<=40)
  345.          {
  346.   keyscan();
  347.   if(menu==0)
  348.   {          InitLcd1602();
  349.         LcdShowStr(0,0,table);
  350.         LcdShowStr(0,1,table1);
  351.          keyscan();
  352.          keyscan();
  353.   }
  354. if(menu==1)
  355. {
  356.         LcdShowStr(0,0,menu1);
  357.         LcdShowStr(0,1,menu2);
  358.         //显示菜单1 2栏
  359. }
  360. if(menu==2)
  361. {
  362.         LcdShowStr(0,0,menu2);
  363.         LcdShowStr(0,1,menu3);
  364.
  365.         //显示菜单2 3栏
  366. }
  367. if(menu==3)
  368. {
  369.         LcdShowStr(0,0,menu3);
  370.         LcdShowStr(0,1,menu4);
  371.         //显示菜单3 4栏
  372. }
  373. if(menu==4)
  374. {
  375.         LcdShowStr(0,0,menu4);
  376.         LcdShowStr(0,1,menu5);
  377. }
  378. if(menu==5)
  379. {          InitLcd1602();
  380.         LcdShowStr(0,0,menu5);
  381.         LcdShowStr(0,1,menu1);
  382. }
  383.     if(menu==10)
  384.    {           InitLcd1602();
  385.       LcdShowStr(0,0,Wt);
  386.           disbuff[0]=TN%1000/100;
  387.           disbuff[1]=TN%1000%100/10;
  388.           disbuff[2]=TN%1000%10 %10;
  389.           DisplayOneChar(8, 1, ASCII[disbuff[0]]);
  390.           DisplayOneChar(9, 1, ASCII[disbuff[1]]);
  391.           DisplayOneChar(10, 1, ASCII[disbuff[2]]);
  392.           DisplayOneChar(11, 1, 0xdf);        //??M
  393.           DisplayOneChar(12, 1, ASCII[12]);        //显示C
  394.    }
  395.         if(menu==11)
  396.     {          InitLcd1602();
  397.       LcdShowStr(0,0,Et);
  398.            LcdShowStr(0,1,Et1);
  399.           disbuff[0]=TN%1000/100;
  400.           disbuff[1]=TN%1000%100/10;
  401.           disbuff[2]=TN%1000%10 %10;
  402.           DisplayOneChar(10, 0, ASCII[disbuff[0]]);
  403.           DisplayOneChar(11, 0, ASCII[disbuff[1]]);
  404.           DisplayOneChar(12, 0, ASCII[disbuff[2]]);
  405.           DisplayOneChar(13, 0, 0xdf);        //??M
  406.           DisplayOneChar(14, 0, ASCII[12]);        //显示C
  407.           disbuff[0]=TE%1000/100;
  408.           disbuff[1]=TE%1000%100/10;
  409.           disbuff[2]=TE%1000%10 %10;
  410.           DisplayOneChar(10, 1, ASCII[disbuff[0]]);
  411.           DisplayOneChar(11, 1, ASCII[disbuff[1]]);
  412.           DisplayOneChar(12, 1, ASCII[disbuff[2]]);
  413.           DisplayOneChar(13, 1, 0xdf);        //??M
  414.           DisplayOneChar(14, 1, ASCII[12]);        //显示C
  415.     }
  416. if(menu==12)
  417. {                InitLcd1602();
  418.         LcdShowStr(0,0,music);
  419.         music_p();
  420. }
  421. if(menu==13)   //////////////////////////////////////////////////////////////////////////////////////
  422. {
  423.         InitLcd1602();
  424.         LcdShowStr(0,0,DST);
  425.         while(menu==13)
  426.         {
  427.              LcdShowStr(0,0,DST);
  428.                  StartModule();
  429.              while(!Echo);                //当RX为零时等待
  430.              TR0=1;                            //开启计数
  431.              while(Echo);                        //当RX为1计数并等待
  432.              TR0=0;                                //关闭计数
  433.          Conut();                        //计算
  434.                  keyscan();
  435.                  delayms(70);
  436.                                 ///////////////////////////////////////////////////////////////////////////////////
  437. }
  438. }
  439. }
  440. if(S>40)
  441. …………限于本文篇幅 余下代码请从51黑下载附件…………
