查看: 2369|回复: 1
电阻电容电感芯片主程序
ID:197177 发表于 2017-5-6 09:03 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
*********STC89C51**********
**********12MHz晶振********/
#include "reg51.h"
#define uint8 unsigned char
#define uint16 unsigned int
uint16 cnt2ms;    //10ms计数器
uint8 cnt1s;    //1秒计数器
//电阻--------------------------------
#define        Z1 13910053.00
#define        Z2 3685279.00
float RZ=0;
unsigned long   RX=0;
unsigned long   RX2=0;
unsigned long   RX3=0;
unsigned long   RX4=0;
unsigned long   RX5=0;
unsigned long   RX6=0;
unsigned long   RX7=0;
unsigned long   RX8=0;
unsigned long   RX9=0;
//电感--------------------------------
float LZ=0;
#define        C1 0.05
//电容--------------------------------
float CZ=0;
float CX=0;
unsigned char I=0;
long tom;
unsigned int Pulsecnt=0;    //脉冲个数
unsigned int Pulsenum;    //脉冲个数
uint8 start=0;    //
uint16 PulseTime;    //10ms计数器
uint16 Pulse;    //10ms计数器
bit flag=0;
uint8 CH=0;    //
unsigned long x;
unsigned char LED_s=0;
/********************************按键*****************************************/
sbit    K1=P1^0;
sbit    K2=P1^1;
sbit    K3=P1^2;
sbit    DIP=P0^7;
sbit    L1=P1^3;
sbit    L10=P1^4;
sbit    L100=P1^5;
sbit    A0=P2^0;
sbit    A1=P2^1;
sbit    RED=P2^4;
sbit    GRE=P2^3;
sbit    YEW=P2^2;
unsigned char temp[7];
/********************************0    1    2    3    4    5    6    7    8    9    H   L    */
unsigned char code dispcode[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x89,0xC7};
//数码管位选
sbit B4   = P2^7;
sbit B1   = P3^7;
sbit B2   = P2^5;
sbit B3   = P2^6;
/****延时******/
void delay_1ms(uint x)
uint j;
uchar i;
for(j=0;j<x;j++)
for(i=0;i<120;i++);
void Key_SM(void){
        if(K1==0){
             delay_1ms(5);
            if(K1==0){
                YEW=1;RED=1;GRE=0;
                GRE=0;
                //----电感档-------
                A0=0;
                A1=0;
                CH=2;//电感档
                while(K1==0){}
        if(K2==0){
             delay_1ms(5);
            if(K2==0){
                 YEW=1;GRE=1;
                RED=0;
               //----电阻档-------
                A0=1;
                A1=0;
                CH=1;//电阻档
                while(K2==0){}
       if(K3==0){
             delay_1ms(5);
            if(K3==0){
               YEW=0;GRE=1;RED=1;
               //----电容档-------
                A0=0;
                A1=1;
                CH=3;//电容挡
               while(K3==0){}
//--------------------主程序--------------------------------
      TMOD=0x51;         //设置定时器0,方式1:16位定时器
      TH1=0;
      TL1=0;
      TH0=(65536-2000)/256; //设定定时周期
      TL0=(65536-2000)%256;
      TR0=1;
      TR1=1;
      ET1=1;
      ET0=1;
      EA=1;
//----电阻档-------
                //----电阻档-------
                A0=1;
                A1=0;
                CH=1;//电阻档
    YEW=1;GRE=1;RED=0;
     Key_SM();
    if(flag==1){
        flag=0;
        x=Pulsenum*65536+TH1*256+TL1;//计算1s内的脉冲个数,频率=脉冲个数
if(CH==1){
      RZ=(Z1/x);//测量1K到1000K
        RX=RZ-1000;
        RX=RX>>1;//RX/2
        RX=RX*10;//数值扩大10倍
   if(RX>=10109){//减去1K阻值
        RX=RX-10109;
    }else{RX=0;}
    if(x==0){RX=0;RX2=0;RX3=0;RX4=0;RX5=0;RX6=0;RX7=0;RX8=0;RX9=0;}//无脉冲后所有的数字归零
  if(RX>9999999){RX=9999999; }//RX大于9999999,则RX=9999999
              RX2=(RX+RX3+RX4+RX5+RX6+RX7+RX8+RX9)>>3;//求平均提高精度
RX9=RX8;RX8=RX7;RX7=RX6;RX6=RX5;RX5=RX4;RX4=RX3;RX3=RX;//数值往后移动 保存上一次的阻值
//RX2=RX2/10;
if(RX2<=9999){RX2=RX2;L1=1;L10=1;L100=1;}
if(RX2<=99999&&RX2>9999){RX2=RX2/10;L1=0;L10=1;L100=1;}
if(RX2<=999999&&RX2>99999){RX2=RX2/100;L1=1;L10=0;L100=1;}
if(RX2>999999){RX2=RX2/1000;L1=1;L10=1;L100=0;}
    tom=RX2;
    temp[0] = tom/1000;
    tom = tom%1000;
    temp[1] = tom/100;
    tom = tom%100;
    temp[2] = tom/10;
    tom = tom%10;
    temp[3] = tom;
if(CH==2){
        LZ=(x*37*C1)/1000000;
        LZ=LZ*x;
        LZ=1000000/LZ;
    if(x==0)LZ=0;
  if(LZ>999999)LZ=999999; //限制最高值
         //更新电感值显示
if(LZ<=9999){LZ=LZ;L1=1;L10=1;L100=1;}
if(LZ<=99999&&LZ>9999){LZ=LZ/10;L1=0;L10=1;L100=1;}
if(LZ<=999999&&LZ>99999){LZ=LZ/100;L1=1;L10=0;L100=1;}
if(LZ>999999){LZ=LZ/1000;L1=1;L10=1;L100=0;}
    tom=LZ;
    temp[0] = tom/1000;
    tom = tom%1000;
    temp[1] = tom/100;
    tom = tom%100;
    temp[2] = tom/10;
    tom = tom%10;
    temp[3] = tom;
if(CH==3){
       CZ=6600000/x;
    if(x==0||x>30500)CZ=0;
  if(CZ>999999)CZ=999999;  //限制最高值
         //更新电容值显示
if(CZ<=9999){CZ=CZ;L1=1;L10=1;L100=1;}
if(CZ<=99999&&CZ>9999){CZ=CZ/10;L1=0;L10=1;L100=1;}
if(CZ<=999999&&CZ>99999){CZ=CZ/100;L1=1;L10=0;L100=1;}
if(CZ>999999){LZ=CZ/1000;L1=1;L10=1;L100=0;}
    tom=CZ;
    temp[0] = tom/1000;
    tom = tom%1000;
    temp[1] = tom/100;
    tom = tom%100;
    temp[2] = tom/10;
    tom = tom%10;
    temp[3] = tom;
         cnt2ms=0;
         Pulsenum=0;
         TH1=0;
         TL1=0;
         TR1=1;
* 函 数 名: Exti0_interrupt
* 函数功能: /T0引脚下降沿进入中断
* 入口参数: 无
* 返    回: 无
void T1_interrupt(void) interrupt 3 using 0
  Pulsenum++;    //保存测得脉搏值
函数功能:定时器/计数器1中断处理
入口参数:null
返    回:null
备    注:null
void Timer0IntProc() interrupt 1 using 0 //2ms
    cnt2ms++;
I++;
//数码管扫描
if(I==1){B2=1;B3=1;B4=1;B1=0;
         P0=dispcode[temp[0]];DIP=1;
if(I==2){B1=1;B3=1;B4=1;B2=0;
         P0=dispcode[temp[1]];DIP=1;
if(I==3){B1=1;B2=1;B4=1;B3=0;
         P0=dispcode[temp[2]];
   if(CH==1){DIP=0;}
if(I==4){B1=1;B2=1;B3=1;B4=0;I=0;DIP=1;
         P0=dispcode[temp[3]];
    if(cnt2ms==497)    //1s计时到
        TR1=0;
        cnt2ms = 0;
        flag=1;
ID:493238 发表于 2020-4-23 23:25 | 只看该作者
        LZ=LZ*x;
        LZ=1000000/LZ;
    if(x==0)LZ=0;
这几行代码是什么意思呢
