查看: 5801|回复: 5
为什么我的LCD1602单片机程序显示日期时间错乱?
下面是代码。。。。。。。。只显示年或者月或者日这样单个是正常的,一起显示就不对了
  1. #include<reg52.h>
  2. #include <intrins.h>
  3. #include <math.h>
  4. #include <stdio.h>
  5. #include <1602.h>
  6. #include <24c02.h>
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9. uchar code word1[]={" Welcome........"};
  10. void second_display();
  11. void minute_display();
  12. void hour_display();
  13. void day_display();
  14. void month_display();
  15. void year_display();
  16. void init();
  17. void delay(uint z);
  18. void time();
  19. void display();
  20. void lcdready();
  21. uint s,min,h,d,m,y,i;
  22. uchar second[2];
  23. uchar minute[2];
  24. uchar hour[2];
  25. uchar day[2];
  26. uchar month[2];
  27. uchar year[4];
  28. sbit LE=P2^0;
  29. sbit DB=P0;
  30. void main()
  31. {
  32.         LCD_Initial();    //液晶初始化
  33.         GotoXY(0,0);
  34.         Print_slow(word1);
  35.         LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN);   //清屏
  36.         init();
  37.         while(1)
  38.         {
  39.
  40.         GotoXY(4,0);
  41.         Print("-");
  42.         GotoXY(7,0);
  43.         Print("-");
  44.         GotoXY(2,1);
  45.         Print(":");
  46.
  47.         GotoXY(5,1);
  48.         Print(":");
  49.         year_display();
  50.         month_display();
  51.         day_display();
  52.         hour_display();
  53.         minute_display();
  54.         second_display();
  55.         }
  56. }
  57. void delay(uint z)
  58. {
  59.         uint x,y;
  60.         for(x=z;x>0;x--)
  61.                 for(y=110;y>0;y--);
  62. }
  63. void year_display()
  64. {
  65.         LE=1;
  66.         year[0]=y/1000+'0';
  67.         year[1]=y%1000/100+'0';
  68.         year[2]=y%1000%100/10+'0';
  69.         year[3]=y%10+'0';
  70.         GotoXY(0,0);
  71.         Print(year);
  72.         delay(50);
  73.
  74.         LE=0;
  75. }
  76. void month_display()
  77. {
  78.         LE=1;
  79.         month[0]=m/10+'0';
  80.         month[1]=m%10+'0';
  81.         GotoXY(5,0);
  82.         Print(month);
  83.         delay(50);
  84.         LE=0;
  85. }
  86. void hour_display()
  87. {
  88.         LE=1;
  89.         hour[0]=h/10+'0';
  90.         hour[1]=h%10+'0';
  91.         GotoXY(0,1);
  92.         Print(hour);
  93.         delay(50);
  94.         LE=0;
  95. }
  96. void minute_display()
  97. {
  98.         LE=1;
  99.         minute[0]=min/10+'0';
  100.         minute[1]=min%10+'0';
  101.         GotoXY(3,1);
  102.         Print(minute);
  103.         delay(50);
  104.         LE=0;
  105. }
  106. void second_display()
  107. {
  108.         LE=1;
  109.         second[0]=s/10+'0';
  110.         second[1]=s%10+'0';
  111.         GotoXY(6,1);
  112.         Print(second);
  113.         delay(50);
  114.         LE=0;
  115. }
  116. void day_display()
  117. {
  118.         LE=1;
  119.         day[0]=d/10+'0';
  120.         day[1]=d%10+'0';
  121.         GotoXY(8,0);
  122.         Print(day);
  123.         delay(50);
  124.         LE=0;
  125. }
  126. void init()
  127. {
  128.         s=0;
  129.         min=0;
  130.         h=0;
  131.         d=1;
  132.         m=1;
  133.         y=2001;
  134.         i=0;
  135.         LE=0;
  136.         EA=1;
  137.         ET0=1;
  138.         TMOD=0x01;
  139.         TH0=(65536-50000)/256;
  140.         TL0=(65536-50000)%256;
  141.         TR0=1;
  142. }
  143. void T0_rpt() interrupt 1
  144. {
  145.         TH0=(65536-50000)/256;
  146.         TL0=(65536-50000)%256;
  147.         i++;
  148.         time();
  149. }
  150. void time()
  151. {
  152.         if(i==20)
  153.         {
  154.                 i=0;
  155.                 s++;
  156.                 if(s==60)
  157.                 {
  158.                         s=0;
  159.                         min++;
  160.                         if(min==60)
  161.                         {
  162.                                 min=0;
  163.                                 h++;
  164.                                 if(h==60)
  165.                                 {
  166.                                         h=0;
  167.                                         min=0;
  168.                                         s=0;
  169.                                         d++;
  170.                                         if(d==29)
  171.                                                 if((y%4!=0)&&(m==2))
  172.                                                 {
  173.                                                         d=1;
  174.                                                         m++;
  175.                                                         if(m==13)
  176.                                                         {
  177.        m=1;
  178.        y++;
  179.                                                         }
  180.                                                 }
  181.                                         if(d==30)
  182.                                                 if((y%4==0)&&(m==2))
  183.                                                 {
  184.                                                         d=1;
  185.                                                         m++;
  186.                                                         if(m==13)
  187.                                                         {
  188.        m=1;
  189.        y++;
  190.                                                         }
  191.                                                 }
  192.                                         if(d==31)
  193.                                                 if((m==4)||(m==6)||(m==9)||(m==11))
  194.                                                 {
  195.                                                         d=1;
  196.                                                         m++;
  197.                                                         if(m==13)
  198.                                                         {
  199.        m=1;
  200.        y++;
  201.                                                         }
  202.                                                 }
  203.                                         if(d==32)
  204.                                                 if((m==1)||(m==3)||(m==5)||(m==7)||(m==8)||(m==10)||(m==12))
  205.                                                 {
  206.                                                         d=1;
  207.                                                         m++;
  208.                                                         if(m==13)
  209.                                                         {
  210.        m=1;
  211.        y++;
  212.                                                         }
  213.                                                 }
  214.                                 }
  215.                         }
  216.                 }
  217.         }
  218. }
ID:192756 发表于 2017-5-7 11:19 | 只看该作者
没有看见你的print函数。你没有贴
ID:111634 发表于 2017-5-7 11:33 | 只看该作者
实例91  具有校正功能的时钟1302(LCD1602显示)
先Proteus仿真,确认有效。
实例91 带校正时钟1302(LCD1602显示).rar (52.68 KB, 下载次数: 20)
以上摘自张志良编著《80C51单片机仿真设计实例教程——基于Keil C和Proteus》清华大学出版社ISBN 978-7-302-41682-1,书中电路和程序设计有详细说明,程序语句条条有注解。
仿真电路和Hex文件能在清华出版社网站免费下载,程序源代码只能到书上看了。到图书馆借,或到新华书店翻阅,或到网上书店打折购买。
ID:197554 发表于 2017-5-7 13:00 | 只看该作者
你没有写显示函数  一起不行可能是显示指针有错误
ID:196174 发表于 2017-5-7 16:19 | 只看该作者
ghkjhk 发表于 2017-5-7 11:19
没有看见你的print函数。你没有贴
这个函数在1602.h的头文件里
//将字符输出到液晶显示
void Print(unsigned char *str)
    while(*str!='\0')
        LCD_Write(LCD_DATA,*str);
        str++;
ID:196174 发表于 2017-5-7 16:20 | 只看该作者
显示函数在1602.h的头文件里
//将字符输出到液晶显示
    while(*str!='\0')
        str++;
