查看: 15123|回复: 9
STM32 ADC规则组注入组多通道多次采集 DMA传输 KEIL
stm32单片机源程序:
  1. //通过串口实时打印KEY3 KEY4电压值。
  2. //每个通道采集50次
  3. #include "pbdata.h"
  4. void RCC_Configuration(void);
  5. void GPIO_Configuration(void);
  6. void NVIC_Configuration(void);
  7. void USART_Configuration(void);
  8. void ADC1_Configuration(void);
  9. void DMA_Configuration(void);
  10. vu16 AD_Value[N][M];        //用来存放ADC转换结果,也是DMA的目标地址 define a N line and M row array
  11. vu16 filterAD[M+1];                        //滤波后AD值
  12. vu16 MM;
  13. int fputc(int ch,FILE *f)
  14. {
  15.         USART_SendData(USART1,(u8)ch);
  16.         while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
  17.         return ch;
  18. }
  19. int main(void)
  20. {
  21.         RCC_Configuration();
  22.         GPIO_Configuration();
  23.         USART_Configuration();
  24.         NVIC_Configuration();
  25.         ADC1_Configuration();
  26.         DMA_Configuration();
  27.
  28.         while(1)
  29.         {
  30.                 delay_ms(10);                //延时,防止第一次上电或复位时,ADC没有转换完成
  31.                 filter();
  32.                 printf("key3=%f\r\n",filterAD[0]*3.3/4095);
  33.                 printf("key4=%f\r\n",filterAD[1]*3.3/4095);
  34.                 printf("pot =%f\r\n",filterAD[2]*3.3/4095);
  35.                 printf("\r\n");
  36.                 delay_ms(1000);
  37.         }
  38. }
  39. void filter(void)
  40. {
  41.         vu32 sum=0;                //必须初始化为0,否则初值将保持上次调用值。
  42.         vu8 i=0,j=0;
  43.         for(i=0;i<M;i++)                //M row
  44.         {
  45.                 for(j=0;j<N;j++)        //N line
  46.                 {
  47.                         sum+=AD_Value[j][i];
  48.                 }
  49.                 filterAD[i]=sum/N;
  50.                 sum=0;
  51.         }
  52. }
  53. void RCC_Configuration(void)
  54. {
  55.   SystemInit();//72m
  56.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);        //GPIOA
  57.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);        //USART
  58.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);                //AFIO
  59.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);        //GPIOC
  60.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);                //ADC
  61.         RCC_ADCCLKConfig(RCC_PCLK2_Div6);                                                //12M  最大14M
  62.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);                 //使能DMA传输
  63. }
  64. void GPIO_Configuration(void)
  65. {
  66.   GPIO_InitTypeDef GPIO_InitStructure;
  67.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX
  68.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  69.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  70.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  71.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
  72.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  73.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  74.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3;//ADin: POT K3 K4
  75.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;                //模拟输入
  76.         GPIO_Init(GPIOC,&GPIO_InitStructure);
  77.
  78. }
  79. void NVIC_Configuration(void)
  80. {
  81.   NVIC_InitTypeDef NVIC_InitStructure;
  82.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  83.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  84.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  85.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  86.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  87.         NVIC_Init(&NVIC_InitStructure);
  88.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//中断向量
  89.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;        //1
  90.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                        //0
  91.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  92.         NVIC_Init(&NVIC_InitStructure);
  93.
  94.         NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;//中断向量
  95.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;        //1
  96.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                        //0
  97.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  98.         NVIC_Init(&NVIC_InitStructure);
  99.
  100. }
  101. void USART_Configuration(void)
  102. {
  103.     USART_InitTypeDef  USART_InitStructure;
  104.         USART_InitStructure.USART_BaudRate=9600;
  105.         USART_InitStructure.USART_WordLength=USART_WordLength_8b;
  106.         USART_InitStructure.USART_StopBits=USART_StopBits_1;
  107.         USART_InitStructure.USART_Parity=USART_Parity_No;
  108.         USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
  109.         USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
  110.         USART_Init(USART1,&USART_InitStructure);
  111.         USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
  112.         USART_Cmd(USART1,ENABLE);
  113.         USART_ClearFlag(USART1,USART_FLAG_TC);
  114. }
  115. void ADC1_Configuration(void)
  116. {
  117.         ADC_InitTypeDef  ADC_InitStructure;
  118.         ADC_DeInit(ADC1);        //将外设 ADC1 的全部寄存器重设为缺省值
  119.         ADC_StructInit(&ADC_InitStructure);
  120.
  121.         ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;                        //ADC1 ADC2工作在独立模式
  122.         ADC_InitStructure.ADC_ScanConvMode=ENABLE;                                                //工作在单通道模式(还是扫描模式:多通道模式)
  123.         ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;                        //模数转换工作在单次模式(还是连续模式)
  124.         ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动
  125.         ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;        //ADC数据右对齐
  126.         ADC_InitStructure.ADC_NbrOfChannel=M;        //顺序进行转换的通道数
  127.         ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  128.
  129.         //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
  130.         //ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
  131.
  132.         ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_239Cycles5);//选择ADC1通道12-PC2 KEY3
  133.         ADC_RegularChannelConfig(ADC1,ADC_Channel_13,2,ADC_SampleTime_239Cycles5);//选择ADC1通道13-PC3 KEY4
  134. //        ADC_RegularChannelConfig(ADC1,ADC_Channel_10,3,ADC_SampleTime_239Cycles5);//选择ADC1通道10-PC0 POT
  135.
  136.         ADC_InjectedSequencerLengthConfig(ADC1,1);//设置注入组通道的转换序列长度
  137.         //设置指定 ADC 的注入组通道,设置它们的转化顺序和采样时间
  138.         ADC_InjectedChannelConfig(ADC1, ADC_Channel_10, 1,ADC_SampleTime_239Cycles5);        //
  139.         ADC_SetInjectedOffset(ADC1,ADC_InjectedChannel_1,0);
  140.         ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);                 //选择定时器 1 的 TRGO 作为注入转换外部触发
  141.         ADC_AutoInjectedConvCmd(ADC1, ENABLE);                        //规则组转换完成自动转换注入组,适合做ADC通道的扩展。
  142.
  143. //        ADC_ExternalTrigInjectedConvCmd(ADC1,ENABLE);        //使用外部触发转换时使能。
  144. //        ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE);                        //规则组中断使能
  145.         ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);                //注入组中断使能
  146.         ADC_ClearFlag(ADC1, ADC_FLAG_JEOC);                                  //注入组转换结束标志位 清零 防止第一次转换时出错。
  147.
  148.         ADC_DMACmd(ADC1, ENABLE);                                // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
  149.         ADC_Cmd(ADC1, ENABLE);                                         //使能指定的ADC1
  150.
  151.         ADC_ResetCalibration(ADC1);        //重置校准器
  152.         while(ADC_GetResetCalibrationStatus(ADC1));                //获取校准状态
  153.         ADC_StartCalibration(ADC1);        //开始指定ADC的校准状态
  154.         while(ADC_GetCalibrationStatus(ADC1));                                //获取指定ADC的校准程序
  155.
  156.         ADC_SoftwareStartConvCmd(ADC1,ENABLE);                                //使能软件启动规则组转换功能
  157. //        ADC_SoftwareStartInjectedConvCmd(ADC1,ENABLE);        //使能ADCx 软件启动注入组转换功能 启动转换
  158. }
  159. void DMA_Configuration(void)
  160. {
  161.         DMA_InitTypeDef DMA_InitStructure;
  162.         DMA_DeInit(DMA1_Channel1);        //将DMA的通道1寄存器重设为缺省值
  163.         DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR;                 //DMA外设ADC基地址
  164.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;                                 //DMA内存基地址
  165.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;                                                 //内存作为数据传输的目的地 外设作为数据传输的来源
  166.         DMA_InitStructure.DMA_BufferSize = M*N;        //DMA通道的DMA缓存的大小
  167.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
  168.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                         //内存地址寄存器递增
  169.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外设数据宽度为16位
  170.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;                                 //内存数据宽度为16位
  171.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //工作在循环缓存模式,当传输完一次后,重新接着传送,永不停息。
  172.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  173. …………限于本文篇幅 余下代码请从51黑下载附件…………
完整代码下载:
4 规则组转换 (DMA 多通道多次采集) - 副本.7z (191.63 KB, 下载次数: 205)
ID:227422 发表于 2017-11-5 13:32 | 只看该作者
下载下来看看
ID:57193 发表于 2017-11-27 19:30 | 只看该作者
谢谢分享好东西!
ID:68875 发表于 2018-7-28 18:14 | 只看该作者
good job
ID:228731 发表于 2018-8-8 15:16 | 只看该作者
厉害了 学习学习!
ID:391660 发表于 2018-8-30 16:43 | 只看该作者
谢谢分享好东西!
ID:486650 发表于 2019-3-8 08:35 | 只看该作者
谢谢分享好东西!
ID:547509 发表于 2019-5-26 15:41 | 只看该作者
谢谢分享
ID:384489 发表于 2019-7-1 17:27 | 只看该作者
正在学习多通道ADC,感谢分享…
ID:561888 发表于 2019-9-3 17:50 | 只看该作者
好东东学习了!
