查看: 3895|回复: 0
K20_Lab_Board_V4.2综合测试程序
k20综合测试程序
源程序:
  1. /*
  2. * main implementation: use this 'C' sample to create your own application
  3. *
  4. */
  5. #include "derivative.h" /* include peripheral declarations */
  6. #include "System.h" /* include peripheral declarations */
  7. #include "ADC.h" /* include peripheral declarations */
  8. #include "UART0.h" /* include peripheral declarations */
  9. #include "Beep.h" /* include peripheral declarations */
  10. //#include "LED.h"  /*LED configure*/
  11. #include "MMA8451Q.h"/*MMA8451Q */
  12. #include "PIT.h"
  13. unsigned int ADC_Result;
  14. unsigned char MMA8451_XYZ_CFG;
  15. unsigned char MMA8451_X_MSB,MMA8451_X_LSB;
  16. unsigned char MMA8451_Y_MSB,MMA8451_Y_LSB;
  17. unsigned char MMA8451_Z_MSB,MMA8451_Z_LSB;
  18. unsigned int temperature_value,photo_value,ADC_value;
  19. unsigned char show[6];
  20. extern unsigned char flag_measure;
  21. int main(void)
  22. {
  23.         LED_Init();
  24.         KEY_Init();
  25.         SMG_Init();
  26.         Beep_Init();
  27.         ADC_Init();
  28.         UART0_Init();
  29.         FTM2_Init();
  30.         PIT_init(0x01);  //1ms interval interrupt
  31.         MMA8451_Init();  //initial MMA8451 g sensor
  32.         EN_Init();
  33.
  34.         for(;;)
  35.         {
  36.                 //potentiometer control  beep
  37.                 ADC_channel_potentiometer();
  38.                 ADC_value=ADC1_TR_DATA();
  39.                 Beep_setup(ADC_value);
  40.                 if(flag_measure==1)
  41.                 {
  42.                         flag_measure=0;
  43.                     //temperature sensor
  44.                     ADC_channel_temperature();
  45.                     delayms(0x01);
  46.                     temperature_value=ADC1_TR_DATA();
  47.
  48.                     photo_value=ADC0_TR_DATA();
  49.
  50.                     //SMG show data store
  51.                     data_to_array(temperature_value,photo_value,show);
  52.                 }
  53.         }
  54.
  55.         return 0;
  56. }
全部资料下载地址(附带串口工具):
K20_Lab_Board_V4.2.zip (3.34 MB, 下载次数: 6)
