查看: 4558|回复: 5
求助 单片机计时和定时再增加按键和跳转 功能,各位,急急急!
求助大神,现在这个单片机代码只实现了计时和定时功能,就key 0,1, 2三个有用,我现在想实现key3(功能待定键)按下,就跳转到自己设定规定时间,再按下key3又回到初始计时显示,当计时到规定时间,蜂鸣器一直响。只有按下key4整个程序重新开始。以下就是代码,求大家帮忙加点程序实现我这个功能,愿意送出我全部黑币,万分感谢!
#include<reg51.h>
#include"DS18B20.h"
void delayms(uint xms); // Ñóê±oˉêy
void beep();            // ·äÃùÆ÷Ïì
void display();        // êyÂë1üÏÔê¾¼Æêy
void key_scan();       // ¼üÅìé¨Ãè
void timer_init();   // ÖD¶Ï3õê¼»ˉ
sbit key0 = P1^0;   // μ÷êÔ¿ØÖư′¼ü
sbit key1 = P1^1;   // Ôö¼ó°′¼ü
sbit key2 = P1^2;   // ¼õD¡
sbit key3 = P1^3;   // 1|Äü′y¶¨
sbit buzzer = P1^4; // ·äÃùÆ÷¶Ë¿ú
uchar  tab[];
uchar code w[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20};    // êyÂë1üλѡ
// êyÂë1ü¶ÎÑ¡ 12òõ
uchar code table[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};   */
// 12ÑôêyÂë1ü¶ÎÂë±í
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
                        0x80,0x90,0x98,0x83,0xc6,0xa1,0x86,0x8e};
uchar count, set_place;  // count óÃóú¶¨ê±Æ÷1sÖD¶Ï  set_placeóÃóú¼ÆËã°′¼üμÄ′Îêy ±ãóúÑ¡Ôñμ÷½úÄÇ2¿·Öê±¼ä
uchar second = 0, minute = 0, hour = 0;   //3õê¼»ˉ ê±¼ä
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// ¼üÅìé¨Ãèoˉêy
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
            if(set_place == 1)  //°′ÏÂò»′Î Ôò¶¨ê±Æ÷ÖD¶Ï
                TR0 = 0;
            if(set_place == 4)  // °′ÏÂá½′Î ¶¨ê±Æ÷′óéÏ′Î×′쬻ָ′1¤×÷
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                while(!key1);   // °′¼üêí·Å
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                while(!key2);   // °′¼üêí·Å
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// êyÂë1üÏÔê¾ê±¼ä
void display()
    uchar j;
    P2 = 0x01;
    P0 = table[hour / 10];
    j = 60;
    while(j--);
    P2 = 0x02;
    P0 = table[hour % 10];
    j = 60;
    while(j--);
    P2 = 0x04;
    P0 = table[minute / 10];
    j = 60;
    while(j--);
    P2 = 0x08;
    P0 = table[minute % 10];
    j = 60;
    while(j--);
    P2 = 0x10;
    P0 = table[second / 10];
    j = 60;
    while(j--);
    P2 = 0x20;
    P0 = table[second % 10];
    j = 60;
    while(j--);
// ¶¨ê±Æ÷3õê¼»ˉ
void timer_init()
    TMOD = 0x01;    //¶¨ê±Æ÷T0 1¤×÷·½ê½1
    TH0 = (65536 - 45872) / 256;    // ×°3õÖμ 50ms
    TL0 = (65536 - 45872) % 256;
    EA = 1; //¿a·Å×üÖD¶Ï
    ET0 = 1;    //¿aÆô¶¨ê±Æ÷0ÖD¶Ï
    TR0 = 1;    //¿aÆô¶¨ê±Æ÷0
// 50msÖD¶Ï
void t0_timer() interrupt 1
    TH0 = (65536 - 45872) / 256;    // ×°3õÖμ ′Ëê±¾§ÕñÎa 11.0592MHz
    count++;
    if(count == 20) //1s ê±¼äμ½
        count = 0;
        second++;
        if(second == 60)    // ÃëÎa60 Çåáã ·Ö½øò»
            second = 0;
            minute++;
            if(minute == 60)    // ·ÖÎa60 Çåáã ê±½øò»
                minute = 0;
                hour++;
                if(hour == 24)  // ê±Îa 24 Çåáã
                    hour =0;
void delayms(uint xms)  // Ñóê±xms
    uchar i, j;
    for(i = xms; i > 0; i--)    // ¸Ä±äxmsμÄÖμ ¿éòÔμ÷½úÑóê±ê±¼ä
    for(j = 110; j > 0; j--);
ID:198696 发表于 2017-5-27 08:58 | 只看该作者
不好意思各位,源代码是这样!
#include<reg51.h>
#include"DS18B20.h"
void delayms(uint xms); // 延时函数
void beep();            // 蜂鸣器响
void display();        //数码管显示计数
void key_scan();       // 键盘扫描
void timer_init();   // 中断初始化ˉ
sbit key0 = P1^0;   // 调试控制按键
sbit key1 = P1^1;   // 增加控制
sbit key2 = P1^2;   // 减小控制
sbit key3 = P1^3;   // 功能待定
sbit buzzer = P1^4; // 蜂鸣器端口
uchar  tab[];
uchar code w[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20};    //数码管位选
// 数码管段选 共阴
//共阳数码管段码表
uchar count, set_place;  // count 用于定时器1s中断 set_place 用于计算按键的次数 便于选择调节那部分时间
uchar second = 0, minute = 0, hour = 0;   //初始化时间
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 键盘扫描函数
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
            if(set_place == 1)  //按下一次 则定时器中断
                TR0 = 0;
            if(set_place == 4)  // 按下两次 定时器从上次状态恢复工作
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                while(!key1);   // 按键释放
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                while(!key2);   // 按键释放
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 数码管显示时间
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定时器初始化
void timer_init()
    TMOD = 0x01;    //定时器T0 工作方式1
    TH0 = (65536 - 45872) / 256;    // 装初值 50ms
    EA = 1; //开放总中断
    ET0 = 1;    //开启定时器中段
    TR0 = 1;    //开启定时器0
// 50ms中断
    TH0 = (65536 - 45872) / 256;    //装初值 此时晶振为11.0592MHz
    count++;
    if(count == 20) //1s 时间到
        count = 0;
        second++;
        if(second == 60)    // 秒为60 清零 分进一
            second = 0;
            minute++;
            if(minute == 60)    // 分为60 清零 时进一
                minute = 0;
                hour++;
                if(hour == 24)  // 时为24清零
                    hour =0;
void delayms(uint xms)  //延时xms
    uchar i, j;
    for(i = xms; i > 0; i--)    // 改变xms的值 可以调节延时时间
cjjcjj1 发表于 2017-5-26 23:16
你这仅有的点注释,还是乱码
不好意思是这样!
#include<reg51.h>
#include"DS18B20.h"
uchar  tab[];
// 数码管段选 共阴
//共阳数码管段码表
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 键盘扫描函数
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
                TR0 = 0;
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 数码管显示时间
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定时器初始化
void timer_init()
    EA = 1; //开放总中断
    ET0 = 1;    //开启定时器中段
    TR0 = 1;    //开启定时器0
// 50ms中断
    count++;
        count = 0;
        second++;
            second = 0;
            minute++;
                minute = 0;
                hour++;
                    hour =0;
    uchar i, j;
ID:198696 发表于 2017-5-27 08:57 | 只看该作者
不倒翁.WZT 发表于 2017-5-26 16:54
你的软件设定还有问题,注解部分还是乱码,解决方法:点击Edit、点击Colors&Fonts、点击8051:Editor C Fil ...
不好意思是这样!
#include<reg51.h>
#include"DS18B20.h"
uchar  tab[];
// 数码管段选 共阴
//共阳数码管段码表
    timer_init();
    for(; ;)
       key_scan();
        display();
void beep()
    buzzer = 1;
    delayms(2);
    buzzer = 0;
    delayms(2);
// 键盘扫描函数
void key_scan()
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            set_place++;
            while(!key0);
            beep();
                TR0 = 0;
               set_place = 0;
                TR0 = 1;
    if(set_place != 0)
        if(key1 == 0)
            delayms(5);
            if(key1 == 0)
                beep();
                if(set_place == 1)
                    second++;
                    if(second == 60)
                        second = 0;
                if(set_place == 2)
                    minute++;
                    if(minute == 60)
                        minute = 0;
                if(set_place == 3)
                    hour++;
                    if(hour == 24)
                        hour = 0;
    if(set_place != 0)
     if(key2 == 0)
            delayms(5);
            if(key2 == 0)
                 beep();
                if(set_place == 1)
                    second--;
                    if(second == -1)
                        second = 59;
                if(set_place == 2)
                    minute--;
                    if(minute == -1)
                        minute = 59;
                if(set_place == 3)
                    hour--;
                    if(hour == -1)
                        hour = 23;
// 数码管显示时间
void display()
    uchar j;
    P2 = 0x01;
    j = 60;
    while(j--);
    P2 = 0x02;
    j = 60;
    while(j--);
    P2 = 0x04;
    j = 60;
    while(j--);
    P2 = 0x08;
    j = 60;
    while(j--);
    P2 = 0x10;
    j = 60;
    while(j--);
    P2 = 0x20;
    j = 60;
    while(j--);
// 定时器初始化
void timer_init()
    EA = 1; //开放总中断
    ET0 = 1;    //开启定时器中段
    TR0 = 1;    //开启定时器0
// 50ms中断
    count++;
        count = 0;
        second++;
            second = 0;
            minute++;
                minute = 0;
                hour++;
                    hour =0;
    uchar i, j;
ID:82765 发表于 2017-5-26 23:16 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:149988 发表于 2017-5-26 16:54 | 只看该作者
RE: 求助 单片机计时和定时再增加按键和跳转 功能,各位,急急急!
你的软件设定还有问题,注解部分还是乱码,解决方法:点击Edit、点击Colors&Fonts、点击8051:Editor C Files、右侧列表中点击Text、将右侧选项Use Color in Comments前勾选去掉,再试试,正确了在进行编程,否则别人看不懂你做了些什么,就不会帮你修改程序。
