查看: 4604|回复: 2
热敏电阻温度计仿真加单片机源码
ID:180102 发表于 2017-6-3 16:22 | 显示全部楼层 |阅读模式
热敏电阻温度计仿真原理图:
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. //
  5. unsigned char code dispbitcode[]=
  6. {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  7. //
  8. //
  9. unsigned char code LEDcode[]=
  10. {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40};
  11. //
  12. //
  13. unsigned char dispbuf[8]={10,10,10,10,10,10,0,0};
  14. //
  15. unsigned char dispcount;
  16. unsigned int uiResult;
  17. bit sflag;
  18. sbit START=P3^1;
  19. sbit OE=P3^0;
  20. sbit EOC=P3^2;
  21. sbit P17=P1^7;
  22. //
  23. void delay(uint z)           //延时函数,约1ms
  24. {
  25.         uint x,y;
  26.         for(x=z;x>0;x--)
  27.                 for(y=110;y>0;y--);
  28. }
  29. void Display()
  30. {for(dispcount=0;dispcount<5;dispcount++)
  31. {P2=0xff;
  32. P1=LEDcode[dispbuf[dispcount]];
  33. if(dispcount==3)
  34. {P17=1;}
  35. P2=dispbitcode[dispcount];
  36. delay(1);
  37. P2=0xff;
  38. }
  39. }
  40. //
  41. void ADC0809()
  42. {
  43.         unsigned char i;
  44.         unsigned long y;
  45. //        START=0;
  46.         START=1;
  47.         START=0;
  48. P0=0Xff;
  49. //EOC=1;
  50. while(EOC==0);
  51. OE=1;
  52. uiResult=P0;
  53. OE=0;
  54. y=uiResult;
  55. uiResult=(y*2516)/128;
  56. if(uiResult<2732)
  57. { uiResult=2732-uiResult;sflag=1;}
  58. else
  59. { uiResult=uiResult-2732;sflag=0;}
  60. i=4;
  61. dispbuf[1]=0;
  62. dispbuf[2]=0;
  63. dispbuf[3]=0;
  64. dispbuf[4]=0;
  65. if(sflag==1)
  66. { dispbuf[0]=11;}
  67. else
  68. { dispbuf[0]=10;}
  69. dispbuf[5]=10;
  70. dispbuf[6]=10;
  71. dispbuf[7]=10;
  72. while(uiResult/10)
  73. {dispbuf[i]=uiResult%10;
  74. uiResult=uiResult/10;
  75. i--;
  76. }
  77. dispbuf[i]=uiResult;
  78. }
  79. //
  80. void main(void)
  81. {
  82. ……………………
  83. …………限于本文篇幅 余下代码请从51黑下载附件…………
热敏电阻温度计.zip (111.31 KB, 下载次数: 28)
ID:207522 发表于 2017-6-3 22:22 | 显示全部楼层
感谢分享,谢谢有你!!
ID:185678 发表于 2017-9-17 00:11 | 显示全部楼层
垃圾,数值都不变的
