查看: 59384|回复: 97
单片机用PID算法控制直流电机转速 源代码+仿真 成功版
ID:207635 发表于 2017-6-4 12:35 | 显示全部楼层 |阅读模式
使用51单片机用PID算法来控制直流电机的转速.带有3个按钮 切换电机转动方向,调节p,调节转速.测试已经成功
仿真原理图如下(proteus仿真工程文件可到本帖附件中下载):
  1. #include<reg52.h>
  2. #include"lcd1602.h"
  3. sfr T2MOD = 0x0c9;
  5. #define uint unsigned int
  6. sbit Q0 = P2^4;
  7. sbit Q1 = P2^5;
  8. sbit Q2 = P2^6;
  9. sbit Q3 = P2^7;
  10. sbit PWM                 = P1^7;
  11. sbit UP                         = P1^0;
  12. sbit DOWM                 = P1^1;
  13. sbit GORB                = P2^3; //换相
  14. sbit ADDSPEED         = P1^2;
  15. sbit SUBSPEED        = P1^3;
  16. uint tuint = 65535;
  17. uint tpwm = 1;        //pwm周期为10000us tpwm变量表示pwm高电平时间,也相当于占空比 (仿真时,频率高时,电机反应慢。在实物上要加大频率)
  18. uchar t1_flag = 0;
  19. uint pulse = 0;
  20. uint t0_flag = 0;
  21. uchar t2_flag = 0;
  22. bit t2_over = 0;
  23. bit Just_Get = 1;
  24. #define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //正转
  25. #define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //反转
  26. #define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //停止
  27. //禁止出现 Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然会烧掉mos管
  28. //************************ PID *************************************
  29. float now = 0,bef = 0,bbef = 0;         //本次采样值,上次采样值,上上次采样值
  30. float err_now,err_bef,err_bbef;                //当前偏差,上次偏差,上上次偏差
  31. float error_add = 0;                                //所有偏差之和
  32. float set = 25;                                                //设定值
  33. float kp = 25;
  34. float ki = 25;
  35. float kd = 0;
  36. //*****************************************************************
  37. void delayms(uint ms)//延时?个 ms
  38. {
  39.     uchar a,b,c;
  40.         while(ms--)
  41.         {
  42.           for(c=1;c>0;c--)
  43.         for(b=142;b>0;b--)
  44.             for(a=2;a>0;a--);
  45.         }
  46. }
  47. void timer_init()
  48. {
  49.         EA = 1;
  50.         ET0 = 1;
  51.         ET1 = 1;
  52.         ET2 = 1;
  53.
  54.         TMOD = 0x15; //定时器0 计数模式 定时器1模式1
  55.         T2MOD = 0x01;
  56.
  57.         TH0 = TL0 = 255;
  58.         TH2 = 0x3C;
  59.         TL2 = 0xB0;                //50MS
  60.
  61. }
  62. void timer1() interrupt 3
  63. {
  64.         if(t1_flag == 0)
  65.         {
  66.                 t1_flag = 1;
  67.                 PWM = 1;
  68.                 TH1 = (tuint - tpwm + 1)/256;
  69.                 TL1 = (tuint - tpwm + 1)%256;
  70.
  71.         }
  72.         else
  73.         {
  74.                 t1_flag = 0;
  75.                 PWM = 0;
  76.                 TH1 = (tuint - 10000 + tpwm + 1)/256;
  77.                 TL1 = (tuint - 10000 + tpwm + 1)%256;
  78.         }
  79. }
  80. void timer0() interrupt 1
  81. {
  82.         TH0 = TL0 = 255;
  83.         t0_flag++;
  84. }
  85. void timer2() interrupt 5
  86. {
  87.         TF2 = 0;
  88.         TH2 = 0x3C;
  89.         TL2 = 0xB0;                //50MS
  90.
  91.         t2_flag++;
  92.
  93.         if(t2_flag == 2)
  94.         {
  95.                 TR0 = 0;
  96.                 TR2 = 0;
  97.                 t2_flag = 0;
  98.                 t2_over = 1;        //表示100ms时间到
  99.         }
  100. }
  101. void GetPulse()
  102. {
  103.         t0_flag = 0;
  104.         t2_flag = 0;
  105.
  106.         TH0 = TL0 = 255;
  107.         TH2 = 0x3C;
  108.         TL2 = 0xB0;                //50MS
  109.
  110.         TR0 = 1;
  111.         TR2 = 1;
  112. }
  113. int PID()        //增量式PID
  114. {
  115.         int change;
  116.         err_now = set - now;
  117.         err_bef = set - bef;
  118.         err_bbef = set - bbef;
  119.
  120.         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  121.
  122. /*
  123.         if(set >= now)
  124.         {
  125.                 if(set - now > 1)
  126.                         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  127.                 else
  128.                         change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  129.         }
  130.         else if(now > set)
  131.         {
  132.                 if(now - set > 1)
  133.                         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  134.                 else
  135.                         change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  136.
  137.         }
  138. */
  139.
  140.         //change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
  141.         //change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
  142.         if(change > 0)
  143.         {
  144.                 printchar(1,10,'+');
  145.                 printuint(1,11,4,change);
  146.
  147.         }
  148.         else if(change < 0)
  149.         {
  150.                 printchar(1,10,'-');
  151.                 printuint(1,11,4,-change);
  152.         }
  153.         else if(change == 0)
  154.         {
  155.                 printchar(1,10,' ');
  156.                 printword(1,11," 0  ");
  157.         }
  158.
  159.         return(change);
  160. }
  161. int PID2()                //位置式PID
  162. {
  163.
  164.         int num = 0;
  165.         static num_bef = 0;
  166.
  167.         err_now = set - now;
  168.         err_bef = set - bef;
  169.
  170.         error_add = error_add + err_now;  //误差累加。一旦误差为0则error_add的值不变,PID输出值不变
  171.         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  172.
  173. /*
  174.         if(set - now >= 0)
  175.         {
  176.                 if(set - now > 1)
  177.                         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  178.                 else
  179.                         num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
  180.         }
  181.         else
  182.         {
  183.                 if(now - set > 1)
  184.                         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  185.                 else
  186.                         num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
  187.
  188.         }
  189.         */
  190.
  191.         if(num > num_bef)
  192.         {
  193.                 printchar(1,10,'+');
  194.                 printuint(1,11,4,num - num_bef);
  195.         }
  196.         else if(num < num_bef)
  197.         {
  198.                 printchar(1,10,'-');
  199.                 printuint(1,11,4,num_bef - num);
  200.         }
  201.         else
  202.         {
  203.                 printchar(1,10,' ');
  204.                 printuint(1,11,4,0);
  205.         }
  206.
  207.         num_bef = num;
  208.
  209.         return((uint)num);
  210. }
  211. void main()
  212. {
  213.
  214.         lcd_init();
  215.         timer_init();
  216.         TH1 = TL1 = 255;
  217.
  218.         printword(0,0,"P:");                //比例系数
  219.         printword(0,5,"S:");                //设定值
  220.         printword(1,0,"TPWM:");                //当前占空比
  221.         printword(0,10,"PS:");                //当前电机反馈的每秒脉冲数
  222.
  223.         while(1)
  224.         {
  225.                 if(GORB == 1)
  226.                 {        ZZ;                }
  227.                 else
  228.                 {        FZ;                }
  229.
  230.                 if(ADDSPEED == 0)
  231.                         set++;
  232.                 if(SUBSPEED == 0)
  233.                         set--;
  234.
  235.                 if(Just_Get == 1)
  236.                 {
  237.                         Just_Get = 0;
  238.                         GetPulse();
  239.                 }
  240.                 else if(t2_over == 1)
  241.                 {
  242.                         t2_over = 0;
  243.                         Just_Get = 1;
  244.                         pulse = t0_flag;
  245.                         bbef = bef;
  246. ……………………
  247. …………限于本文篇幅 余下代码请从51黑下载附件…………
PID算法控制电机转速.rar (100.25 KB, 下载次数: 1239)
参与人数 5黑币 +43 收起 理由
dww465757120 + 30 很给力!
我请你x + 2 赞一个!
stu + 1 很给力!
lm1720755472 + 5 学习到知识
杜辅翼 + 5 很给力!
ID:1 发表于 2017-6-4 16:33 | 显示全部楼层
好资料,51黑有你更精彩!!!
ID:177855 发表于 2017-6-4 17:39 | 显示全部楼层
不懂,下来慢慢学
ID:226086 发表于 2017-8-9 14:09 | 显示全部楼层
很好,学习一下!
ID:122686 发表于 2017-9-3 14:24 | 显示全部楼层
不错加油
ID:239382 发表于 2017-10-15 00:21 | 显示全部楼层
棒棒哒
ID:210141 发表于 2017-10-15 11:27 来自触屏版 | 显示全部楼层
慢慢学习一下
ID:239623 发表于 2017-10-15 14:21 | 显示全部楼层
nice   好大拇指
ID:239382 发表于 2017-10-15 22:22 | 显示全部楼层
请问lcd显示屏上的p值是什么用途呢?
ID:125901 发表于 2017-10-17 01:00 来自触屏版 | 显示全部楼层
努力学习学习
ID:243861 发表于 2017-10-29 15:49 | 显示全部楼层
P值是什么
ID:252056 发表于 2017-11-21 20:55 | 显示全部楼层
谢谢分享    好
ID:262605 发表于 2017-12-17 11:50 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
ID:262605 发表于 2017-12-17 11:53 | 显示全部楼层
谢谢分享
ID:262605 发表于 2017-12-17 14:23 | 显示全部楼层
看看
谢谢分享
ID:262988 发表于 2017-12-18 10:11 | 显示全部楼层
正在做直流电机控制,学习下
ID:262988 发表于 2017-12-18 10:12 | 显示全部楼层
额,没币,下起不了
ID:44165 发表于 2018-3-13 23:22 | 显示全部楼层
好资料,51黑有你更精彩!!!
ID:302760 发表于 2018-4-6 18:13 | 显示全部楼层
学习一下
ID:250045 发表于 2018-4-12 11:54 | 显示全部楼层
很好的资料,刚好最近在做这个。
ID:311523 发表于 2018-4-19 11:04 | 显示全部楼层
谢谢分享
ID:324603 发表于 2018-5-7 22:01 | 显示全部楼层
谢谢分享
ID:326595 发表于 2018-5-10 10:35 | 显示全部楼层
非常感谢,新手入门,很有用
ID:336452 发表于 2018-5-23 14:24 | 显示全部楼层
谢谢楼主
ID:197331 发表于 2018-6-6 18:47 | 显示全部楼层
不错,值得学习
ID:344257 发表于 2018-6-6 21:09 | 显示全部楼层
这个源代码直接放到keil里面编译,是有警告的啊?
ID:356219 发表于 2018-6-21 17:04 | 显示全部楼层
谢谢哈哈
ID:358826 发表于 2018-6-25 21:12 | 显示全部楼层
下来慢慢学
ID:293560 发表于 2018-7-13 10:53 | 显示全部楼层
pid入坑中
ID:370696 发表于 2018-7-13 11:55 | 显示全部楼层
谢谢分享
ID:371038 发表于 2018-7-13 17:06 | 显示全部楼层
非常好
ID:371504 发表于 2018-7-14 15:09 | 显示全部楼层
值得学习
ID:339697 发表于 2018-8-19 07:49 | 显示全部楼层
很想试试看
ID:398044 发表于 2018-9-14 17:14 | 显示全部楼层
很想试试看
ID:402275 发表于 2018-10-10 17:43 | 显示全部楼层
感谢大佬
ID:405059 发表于 2018-10-13 09:46 | 显示全部楼层
第一次用PID算法来控制,文件里位置式和增量式都涉及到了,很详细
ID:432291 发表于 2018-11-24 11:50 | 显示全部楼层
正好,试着做做
ID:452353 发表于 2018-12-22 21:47 | 显示全部楼层
谢谢楼主分享
ID:452376 发表于 2018-12-22 22:24 | 显示全部楼层
努力学习亚
ID:450877 发表于 2018-12-22 22:28 | 显示全部楼层
好帖子,试试做
