核辐射检测仪程序(盖格计数器)及效果图
51黑ss
2016-3-30 22:50
核辐射检测仪程序(盖格计数器)及效果图
这是我自己想的一种方法,利用盖格计数器来技术每秒射线次数来检测辐射强度。
本系列文章:
盖格剂检测核辐射:
http://www.51hei.com/bbs/dpj-47401-1.html
盖格管检测电路:
http://www.51hei.com/bbs/dpj-47429-1.html
//main.c
#include"config.h"
#include"5110.h"
#include"h1838.h"
#include"iic.h"
#include"ta.h"
int main( void )
extern_16m();
h1838_init();
LCD5110_init();
LCD_init();
DS1302_Reset();
LCD_clear();
init_TA();
__bis_SR_register(GIE);
Red_Code();
//5110.h
#define res1 P1OUT|=BIT0; //复位,0复位
#define res0 P1OUT&=~BIT0;
#define sce1 P1OUT|=BIT1; //片选
#define sce0 P1OUT&=~BIT1; //片选
#define dc1 P1OUT|=BIT2; //1写数据,0写指令
#define dc0 P1OUT&=~BIT2;
#define sdin1 P1OUT|=BIT3; //数据改为P1.7口
#define sdin0 P1OUT&=~BIT3;
#define sclk1 P1OUT|=BIT4; //时钟
#define sclk0 P1OUT&=~BIT4;
#define led1 P1OUT&=~BIT5;
#define led0 P1OUT&=~BIT5;
unsigned const zimu[]={
0xF0,0x08,0x08,0x18,0xE0,0x00,0x1F,0x20,0x20,0x30,0x0F,0x00,/*"0",0*/
0x00,0x10,0xF8,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,/*"1",1*/
0x70,0x08,0x08,0x08,0xF0,0x00,0x30,0x2C,0x22,0x21,0x30,0x00,/*"2",2*/
0x30,0x08,0x88,0x88,0x70,0x00,0x18,0x20,0x20,0x31,0x1E,0x00,/*"3",3*/
0x00,0x80,0x60,0xF0,0x00,0x00,0x06,0x05,0x24,0x3F,0x24,0x04,/*"4",4*/
0xF8,0x08,0x88,0x88,0x08,0x00,0x19,0x21,0x20,0x31,0x1F,0x00,/*"5",5*/
0xE0,0x18,0x88,0x98,0x00,0x00,0x0F,0x31,0x20,0x20,0x1F,0x00,/*"6",6*/
0x38,0x08,0x08,0xE8,0x18,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,/*"7",7*/
0x70,0x88,0x08,0x88,0x70,0x00,0x1E,0x21,0x21,0x21,0x1E,0x00,/*"8",8*/
0xF0,0x08,0x08,0x18,0xE0,0x00,0x01,0x32,0x22,0x31,0x0F,0x00,/*"9",9*/
0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,/*":",10*/
0x80,0x80,0x80,0x80,0x00,0x00,0x3F,0x00,0x3F,0x00,0x3F,0x00,/*"m",11*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x3D,0x26,0x22,0x3F,0x20,/*"a",12*/
0x80,0x80,0x00,0x00,0x80,0x80,0x00,0x07,0x38,0x1C,0x03,0x00,/*"v",13*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,/*".",14*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",15*/
0xF0,0x98,0x60,0xE0,0x38,0x00,0x00,0x31,0x0E,0x1F,0x33,0x0C,/*"%",16*/
0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x33,0x00,0x00,0x00,/*"!",17*/
unsigned const hanzi[]=
0x00,0x00,0xF0,0x90,0x90,0xFE,0x90,0x90,0x90,0xF0,0x00,0x00,0x00,0x00,0x0F,0x04,
0x04,0x7F,0x44,0x44,0x44,0x47,0x78,0x00,/*"电",0*/
0x00,0x00,0xFC,0x04,0x04,0x04,0xFC,0x04,0x04,0x84,0x04,0x00,0x00,0x38,0x47,0x41,
0x41,0x41,0x3F,0x41,0x45,0x58,0x20,0x00,/*"压",1*/
0x00,0x40,0x8C,0x70,0xC8,0x68,0x5A,0x44,0x68,0xC8,0x00,0x00,0x00,0x38,0x0F,0x40,
0x3E,0x01,0x3E,0x01,0x3E,0x41,0x70,0x00,/*"流",2*/
0x00,0x40,0xC4,0x40,0x40,0xBC,0x84,0x84,0xBC,0xC0,0x20,0x00,0x00,0x00,0x0F,0x98,
0x88,0x43,0x2C,0x18,0x26,0x61,0x40,0x00,/*"设",3*/
0x00,0x30,0x90,0x90,0x90,0x8A,0x94,0x90,0x90,0x70,0x10,0x00,0x00,0x40,0x30,0x1E,
0x20,0x3B,0x44,0x44,0x44,0x44,0x40,0x00,/*"定",4*/
0x00,0x40,0xC4,0x00,0x00,0xFC,0xA4,0x7C,0xA4,0xA4,0xFC,0x00,0x00,0x00,0x3F,0x18,
0x3C,0x03,0x1F,0x12,0x1E,0x40,0x7F,0x00,/*"调",5*/
0x00,0x20,0x58,0xFE,0xD8,0x74,0x28,0x7E,0xC8,0x38,0x08,0x00,0x00,0x42,0x45,0x7B,
0x44,0x7F,0x52,0x55,0x54,0x43,0x42,0x00,/*"整",6*/
0x00,0x18,0x28,0x08,0x68,0xDE,0x48,0x28,0x48,0x38,0x00,0x00,0x00,0x02,0x11,0x10,
0x13,0x7E,0x12,0x13,0x11,0x11,0x08,0x00,/*"率",7*/
void LCD5110_init()
P1DIR|=0X3F;
P1OUT&=~0X20;
LCD_write_byte: 使用SPI接口写数据到LCD
输入参数:dt:写入的数据;
command :写数据/命令选择;
编写日期:20080918
void LCD_write_byte(unsigned char dt, unsigned char command)
unsigned char i;
sce0;
if(command==1)
{dc1; }
else {dc0;}
for(i=0;i<8;i++)
if(dt&0x80)
{sdin1;}
{sdin0;}
dt=dt<<1;
sclk0;
sclk1;
dc1;
sce1;
sdin1;
LCD_init: 3310LCD初始化
编写日期:20080918
void LCD_init(void)
res0;
// delay_ms(1);
res1;
LCD_write_byte(0x21,0);//初始化Lcd,功能设定使用扩充指令
LCD_write_byte(0xd0,0);//设定液晶偏置电压
LCD_write_byte(0x20,0);//使用基本指令
LCD_write_byte(0x0C,0);//设定显示模式,正常显示
LCD_set_XY: 设置LCD坐标函数
输入参数:X:0-83 Y:0-5
编写日期:20080918
void LCD_set_XY(unsigned char X, unsigned char Y)
LCD_write_byte(0x40 | Y, 0);// column
LCD_write_byte(0x80 | X, 0);// row
LCD_clear: LCD清屏函数
编写日期:20080918
void LCD_clear(void)
unsigned char t;
unsigned char k;
LCD_set_XY(0,0);
for(t=0;t<6;t++)
for(k=0;k<84;k++)
LCD_write_byte(0x00,1);
LCD_write_shu: 显示8(宽)*16(高)点阵列数字字母符号等半角类
输入参数:c:显示的字符;
编写日期:20080918
void LCD_write_shu(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
unsigned char i;
LCD_set_XY(row*6, page);// 列,页
for(i=0; i<6;i++)
LCD_write_byte(zimu[c*12+i],1);
LCD_set_XY(row*6, page+1);// 列,页
for(i=6; i<12;i++)
LCD_write_hanzi: 显示12(宽)*16(高)点阵列汉字等半角类
输入参数:c:显示的字符;
编写日期:20080918
void LCD_write_hanzi(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
unsigned char i;
for(i=0; i<12;i++)
LCD_write_byte(hanzi[c*24+i],1);
for(i=12; i<24;i++)
// config.h
#include <msp430.h>
#define ulong unsigned long
#define CPU_F ((double)16000000) //外部高频晶振8MHZ
//#define CPU_F ((double)32768) //外部低频晶振32.768KHZ
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define KEY_0 0x16 //键0
#define KEY_1 0x0C //键1
#define KEY_2 0x18 //键2
#define KEY_3 0x5E //键3
#define KEY_4 0x08 //键4
#define KEY_5 0x1C //键5
#define KEY_6 0x5A //键6
#define KEY_7 0x42 //键7
#define KEY_8 0x52 //键8
#define KEY_9 0x4A //键9
#define prex 0x44 //电源
#define nex 0x40 //模式
#define play_pause 0x43 //静音
#define ch_ 0x45 //模式
#define ch 0x46
#define cha 0x47 //模式
#define __ 0x07
#define _a 0x15
#define eq 0x09
#define _100a 0x19
#define _200a 0x0d
#define power 0x12 //power
#define up 0x1b //up
#define down 0x1a //down
#define left 0x04 //left
#define right 0x06 //right
#define ok 0x05 //0k
void extern_16m()
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
if (CALBC1_1MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_16MHZ;
DCOCTL = CALDCO_16MHZ; // Load 8MHz constants
//h1838.h
#define IR_DIR_IN P2DIR&=~BIT0//红外接收头P1.0设置为输入,
#define RED_R (P2IN&BIT0)//红外接收头输入值
void h1838_init()
IR_DIR_IN;
uchar KEY_VAL;
uchar key_code[4],code_value;
void Key_Icode(uchar dat)
switch(dat) //第3个字节是数据,第4个字节是反码
{ //为了更稳定,可以加上第4个字节数据的判断
case KEY_0:KEY_VAL=0;LCD_write_shu(0,0,0); break;
case KEY_1:KEY_VAL=1; LCD_write_shu(0,0,1); break;
case KEY_2:KEY_VAL=2; LCD_write_shu(0,0,2); break;
case KEY_3:KEY_VAL=3; LCD_write_shu(0,0,3); break;
case KEY_4:KEY_VAL=4; LCD_write_shu(0,0,4); break;
case KEY_5:KEY_VAL=5; LCD_write_shu(0,0,5); break;
case KEY_6:KEY_VAL=6; LCD_write_shu(0,0,6);break;
case KEY_7:KEY_VAL=7; LCD_write_shu(0,0,7); break;
case KEY_8:KEY_VAL=8; LCD_write_shu(0,0,8); break;
case KEY_9:KEY_VAL=9; LCD_write_shu(0,0,9); break;
case prex:break;
case nex :break;
case play_pause:break;
case ch_: break;
case ch: break;
case cha:break;
case eq: break;
case _a:;break;
case __:break;
case _100a:break;
case _200a:break;
case power:break;
case up: break;
case down:break;
case left:break;
case right:break;
case ok:break;
default:KEY_VAL=' ';break;
void Red_Code()
uchar i,j,k = 0;
for(i = 0;i < 19;i++)
delay_us(400); //延时400us
if(RED_R) //9ms内有高电平,则判断为干扰,退出处理程序
return;
while(!RED_R); //等待9ms低电平过去
for(i=0;i<5;i++) //是否连发码
delay_us(500);
if(!RED_R)
return;
while(RED_R); //等待4.5ms高电平过去
for(i = 0;i < 4;i++) //接收4个字节的数据
for(j = 0;j < 8;j++) //每个字节的数据8位
while(!RED_R); //等待变高电平
while(RED_R) //计算高电平时间
delay_us(100);
k++;
if(k >22) //高电平时间过长,则退出处理程序
return;
code_value>>=1; //接受一位数据
if(k >= 7)
code_value|=0x80; //高电平时间大于0.56,则为数据1
k = 0; //计时清零
key_code[i]=code_value; //四个字节的数据
Key_Icode(key_code[2]); //调用赋值函数
// Display_Key(KEY_VAL); //显示按键值
// delay_ms(50);
//ta.h
uchar t1;
void init_TA()
TACCR0 = 50000; //25ms中断一次
TACTL = TASSEL_2 + MC_1+ID_3; // SMCLK, upmode,8分频,
TACCTL0 = CCIE; // TACCR0 interrupt enabled
#pragma vector=TIMER0_A0_VECTOR
__interrupt void TIMERA0_ISR() // the interrupt source is CC0
if(++t1>=40)
t1=0;
DS1302_GetData_dis();
//iic.h
///时钟模块
#define DS1302_DIR P2DIR
#define DS1302_IN P2IN
#define DS1302_OUT P2OUT
#define DS1302_RST BIT6
#define DS1302_SCLK BIT4
#define DS1302_SDI BIT5 //定义MSP320的端口
#define DS1302_RST_LO P1OUT &= ~DS1302_RST
#define DS1302_RST_HI P1OUT |= DS1302_RST
#define DS1302_SCLK_LO DS1302_OUT&= ~DS1302_SCLK
#define DS1302_SCLK_HI DS1302_OUT |= DS1302_SCLK
#define DS1302_SDI_LO DS1302_OUT &= ~DS1302_SDI
#define DS1302_SDI_HI DS1302_OUT |= DS1302_SDI
void DS1302_Reset(void);
void DS1302_WriteOneByte(unsigned char w_dat);
void DS1302_WriteData(unsigned char addr,unsigned char w_dat);
void DS1302_SettingData(void);
void DS1302_GetData(unsigned char *str);
unsigned char DS1302_ReadOneByte(void);
unsigned char DS1302_ReadData(unsigned char addr);
unsigned char Setting_Time[7]={ //bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0
0x15, //--------十位-------|-------个位--------|年份(当前07年)
0x03, // |-----个位-----|星期(当前周日)
0x09, // |十位|-------个位--------|月份(当前07月)
0x23, // |--十位---|-------个位--------|日期(当前01号)
0x9, //-12H| |--十位---|-------个位--------|小时(当前18点)
0x05, // |-----十位-----|-------个位--------|分钟(当前20分)
0x20 // |-----十位-----|-------个位--------|秒钟(当前30秒)
unsigned char ReadingData[7]; //读出来的数据,同SettingData定义与格式
void main(void) {
DS1302_Reset();
//DS1302_SettingData();
while(1){
DS1302_GetData(ReadingData);
_NOP();
//DS1302复位
void DS1302_Reset(void) {
P1DIR |= DS1302_RST;
P2DIR |= DS1302_SCLK;
DS1302_SCLK_LO;
DS1302_RST_LO;
//delay_us(10);
DS1302_SCLK_HI;
//向DS1302写入一个字节
void DS1302_WriteOneByte(unsigned char w_dat) {
unsigned char temp;
DS1302_RST_HI;
DS1302_DIR |= DS1302_SDI;
for(temp=8;temp>0;temp--) {
DS1302_SDI_LO;
if(w_dat&BIT0) DS1302_SDI_HI;
DS1302_SCLK_LO;
// delay_us(10);
DS1302_SCLK_HI;
// delay_us(10);
w_dat >>=1;
//从DS1302中读取一个字节
unsigned char DS1302_ReadOneByte(void) {
unsigned char temp,rdata;
rdata = 0x00;
DS1302_RST_HI;
DS1302_DIR &= ~DS1302_SDI;
for(temp=0;temp<8;temp++){rdata >>= 1;//将移位放到前面,否则读不到最高一位
DS1302_SCLK_HI;
// delay_us(10);
DS1302_SCLK_LO;
// delay_us(10);
if((DS1302_IN&DS1302_SDI)==DS1302_SDI)
rdata |= BIT7;
//rdata >>= 1;
return(rdata);
//向DS1302中写入地址后写入数据
void DS1302_WriteData(unsigned char addr,unsigned char w_dat) {
DS1302_RST_LO;
DS1302_SCLK_LO;
DS1302_RST_HI;
DS1302_WriteOneByte(addr); //写入地址
DS1302_WriteOneByte(w_dat); //写入数据
DS1302_SCLK_HI;
DS1302_RST_LO;
//向DS1302写入地址后,从DS1302中读取数据
unsigned char DS1302_ReadData(unsigned char addr) {
unsigned char r_dat;
DS1302_RST_LO;
DS1302_SCLK_LO;
DS1302_RST_HI;
r_dat = DS1302_ReadOneByte(); //读出数据
DS1302_SCLK_LO;
DS1302_RST_LO;
return(r_dat);
//按照SettingData的设置设置DS1302的时间
void DS1302_SettingData(void) {
unsigned char temp;
unsigned char addr = 0x8C;
DS1302_WriteData(0x8E,0x00); //写入控制命令,禁用写保护
for(temp=0;temp<7;temp++) {
DS1302_WriteData(addr,Setting_Time[temp]);
addr -= 2;
DS1302_WriteData(0x8E,0x80); //写入控制命令,启用写保护
//读取DS1302时间到ReadingData中
void DS1302_GetData(unsigned char *str) {
unsigned char temp;
unsigned char addr = 0x8D;
str[temp] = DS1302_ReadData(addr);//年
addr -= 2;
void DS1302_GetData_dis()
LCD_write_shu(0,2,Setting_Time[0]/16);
LCD_write_shu(1,2,Setting_Time[0]%16);
LCD_write_shu(2,2,10);
LCD_write_shu(3,2,Setting_Time[2]/16);
LCD_write_shu(4,2,Setting_Time[2]%16);
LCD_write_shu(5,2,10);
LCD_write_shu(6,2,Setting_Time[3]/16);
LCD_write_shu(7,2,Setting_Time[3]%16);
// LCD_write_shu(8,2,10);
LCD_write_shu(9,2,Setting_Time[1]/16);
LCD_write_shu(10,2,Setting_Time[1]%16);
LCD_write_shu(0,4,Setting_Time[4]/16);
LCD_write_shu(1,4,Setting_Time[4]%16);
LCD_write_shu(2,4,10);
LCD_write_shu(3,4,Setting_Time[5]/16);
LCD_write_shu(4,4,Setting_Time[5]%16);
LCD_write_shu(5,4,10);
LCD_write_shu(6,4,Setting_Time[6]/16);
LCD_write_shu(7,4,Setting_Time[6]%16);
jiangqdcs
2020-4-26 22:33
大神,你这个好像没有检测的函数啊
