查看: 2892|回复: 3
如何使用STC15f系列单片机的两个定时器来播放音乐,求可用的源代码
ID:220121 发表于 2017-7-31 18:45 | 显示全部楼层 |阅读模式
一个定时器用于控制音调
一个用于控制节拍
中间不使用delay延时
网上找了好久没找到
ID:82765 发表于 2017-7-31 22:01 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
ID:164602 发表于 2017-8-1 08:08 | 显示全部楼层
我这个程序是STC89C52RC的,你可以试试,应该可以直接用的。#include <reg51.h>
sbit voice=P1^5;//蜂鸣器
unsigned char code sound[]={0xff,
0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,0x26,0x10,//两只蝴蝶
0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,
0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0x80,
0x40,0x80,0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,
0x26,0x10,0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,
0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x30,0x20,0x2b,0xc0,
0x2b,0x10,0x30,0xc0,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,0x26,0x20,
0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0xc0,0x26,0x20,
0x20,0x20,0x20,0x80,0xff,0x20,0x20,0x20,0x1c,0x20,0x20,0x20,0x26,0xc0,
0x2b,0x20,0x2b,0x20,0x2b,0x60,0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,
0x39,0x20,0x39,0x20,0x30,0x20,0x30,0x20,0x30,0xc0,0xff,0x40,0xff,0x40,
0xff,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,0x18,0x20,0x19,0x20,0x19,0x20,
0x1c,0x20,0x26,0x20,0x2b,0x20,0x2b,0x20,0x26,0x20,0x26,0x80,0xff,0x20,
0x26,0x20,0x26,0x20,0x20,0x20,0x1c,0x40,0x1c,0x40,0xff,0x20,0x39,0x20,
0x26,0x20,0x2b,0x20,0x2b,0xc0,0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x20,
0x20,0x40,0xff,0x20,0x18,0x40,0x19,0x20,0x1c,0x20,0x1c,0x10,0x19,0x10,
0x26,0x40,0xff,0x20,0x1c,0x20,0x1c,0x20,0x19,0x20,0x1c,0x20,0x20,0x20,
0x26,0x20,0x2b,0x20,0xff,0x20,0x26,0x20,0x2b,0x20,0x26,0x20,0x20,0x80,
0x26,0x20,0x2b,0x20,0xff,0x20,0x40,0x40,0x39,0x20,0x30,0xc0,0xff,0xc0,
0x00
};//音乐数据,0xff为起始数据,0x00为终止数据,以后数据两两一组,前者为音阶,后者为节拍
unsigned char zdjs=0,jp;
void del(yj);
void main(void)
        unsigned int dpjs=0;
        unsigned char yj;
        TMOD=0x01;
        IE=0x82;
        TH0=0xd8;
        TL0=0xf0;
        TR0=1;
                zdjs=0;
                dpjs++;
                yj=sound[dpjs];
                dpjs++;
                jp=sound[dpjs];
                while(zdjs!=jp)
                        if(yj!=0xff)
                                if(yj!=0)
                                        voice=!voice;
                                        del(yj);
                                        dpjs=0;
                                        break;
                                voice=1;
                                del(jp);
time0() interrupt 1  using 1//定时器中断,记录时间
        TH0=0xd8;
        TL0=0xf0;
        zdjs++;
void del(yj)
        unsigned char yj2=2;
        while(yj!=0)
                while(yj2!=0)
                        yj2--;
                yj2=2;
                yj--;
只用了一个定时器。
ID:111634 发表于 2017-8-1 10:58 | 显示全部楼层
实例75  定时器控制播放生日快乐歌
Proteus仿真一下,确认有效。
实例75 定时器控制播放生日快乐歌.rar (26.96 KB, 下载次数: 15)
