查看: 2299|回复: 1
STM32串口通信代码
ID:168039 发表于 2017-3-4 09:19 | 显示全部楼层 |阅读模式
//初始化IO 串口3
//bound:波特率
void uart3_init(u32 bound){
   //GPIO端口设置
         USART_InitTypeDefUSART_InitStructure;
         NVIC_InitTypeDefNVIC_InitStructure;
         //APB2改为APB1,因为USART3是连接到APB1(低速外设)上的设备
         RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);         //??USART2,GPIOA??
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);  //??USART2,GPIOA??    USART_DeInit(USART3);  //复位串口3
          //USART1_TX   PB.10
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //复用推挽输出
   GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化PB10
   //USART1_RX    PB.11
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
   GPIO_Init(GPIOB, &GPIO_InitStructure);  //初始化PB11
  //USART 初始化设置
         USART_InitStructure.USART_BaudRate= bound;//一般设置为9600;
         USART_InitStructure.USART_WordLength= USART_WordLength_8b;//字长为8位数据格式
         USART_InitStructure.USART_StopBits= USART_StopBits_1;//一个停止位
         USART_InitStructure.USART_Parity= USART_Parity_No;//无奇偶校验位
         USART_InitStructure.USART_HardwareFlowControl= USART_HardwareFlowControl_None;//无硬件数据流控制
         USART_InitStructure.USART_Mode= USART_Mode_Rx | USART_Mode_Tx;        //收发模式
   USART_Init(USART3, &USART_InitStructure); //初始化串口
  //Usart3 NVIC 配置
   NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;//抢占优先级3
         NVIC_InitStructure.NVIC_IRQChannelSubPriority= 0;            //子优先级3
         NVIC_InitStructure.NVIC_IRQChannelCmd= ENABLE;                    //IRQ通道使能
         NVIC_Init(&NVIC_InitStructure);    //根据指定的参数初始化VIC寄存器
   USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//开启中断
   USART_Cmd(USART3, ENABLE);                    //使能串口
ID:168039 发表于 2017-3-4 09:21 | 显示全部楼层
大家可以修改一下
