查看: 5142|回复: 2
单片机TLC5615可调直流电源仿真及源程序
给51黑电子论坛的朋友分享一个51单片机+TLC5615数模转换器实现的可调直流稳压电源.
键盘使用说明:
1:按下 MODE 键,在键盘和旋钮之间切换
键盘模式
1:按下 SET 键
2:按下 0--9.99之间的电压值
3:按下 ENTER 键
旋钮模式
1:调节可调电阻,电压随之改变
下面是TLC5615可调直流稳压电源的仿真原理图:
所有资料包含仿真工程文件和源码下载:
可调直流电源键盘输入.zip (141.99 KB, 下载次数: 144)
部分源程序预览:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include "timer.h"
  4. #include "key.h"
  5. #include "lcd.h"
  6. #include "global.h"
  7. #include "adcdac.h"
  8. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  9. #define vout 1
  10. #define vset 0
  11. #define vmode
  12. #define MODE_B 1
  13. #define MODE_A 0
  14. bit workmode;
  15. //sbit KEY1 = P3^6;
  16. //sbit KEY2 = P3^7;
  17. /*
  18. typedef struct
  19. {
  20.         union {uint I; uchar C[2];}tempval1;
  21.         union {uint I; uchar C[2];}tempval2;
  22. }sData;
  23. sData D;   */
  24. void Delayms(uint ms)
  25. {
  26.         uchar i;
  27.         while(ms--)
  28.         {
  29.                  for(i=0;i<120;i++);
  30.         }
  31. }
  32. void main()
  33. {
  34.         uchar B;
  35.         uchar temp;
  36.         uint d,v;
  37.         Initialize_LCD();
  38.         InitTimer();
  39.         Delayms(10);
  40.         v = 0x0100;
  41.         StartTimer(0);
  42.         B = 0;
  43.         workmode = MODE_A;
  44.         while(1)
  45.         {
  46.                 KEYPORT = 0xf0;
  47.                 if(KEYPORT != 0xf0)
  48.                 {
  49.                         temp = Keys_Scan();
  50.                         keyhandle(temp);
  51.                 }
  52.                 if(workmode==MODE_A)
  53.                 {
  54.                          d = Get_AD_Result(vset);
  55.                         d &=0x00FF;
  56.                         Set_DAC(d*4);
  57.                         d = d*1000.0/255;
  58.                         strcpy(Display_Buffer1 , "SetVoltage:");
  59.                         if(d/1000)
  60.                         {
  61.                                 Display_Buffer1[11]=d/1000+'0';
  62.                                 Display_Buffer1[12]=d/100%10+'0';
  63.                                 Display_Buffer1[13]='.';
  64.                                 Display_Buffer1[14]=d/10%10+'0';
  65.                                 Display_Buffer1[15]=d%10+'0';
  66.                         }
  67.                         else
  68.                         {
  69.                                 Display_Buffer1[11]=d/100%10+'0';
  70.                                 Display_Buffer1[12]='.';
  71.                                 Display_Buffer1[13]=d/10%10+'0';
  72.                                 Display_Buffer1[14]=d%10+'0';
  73.                                 Display_Buffer1[15]=' ';
  74.                         }
  75.                         d = Get_AD_Result(vout);
  76.                         d &=0x00FF;
  77.                         d = d*1000.0/255;
  78.                         strcpy(Display_Buffer0 , "OutVoltage:");
  79.                         if(d/1000)
  80.                         {
  81.                                 Display_Buffer0[11]=d/1000+'0';
  82.                                 Display_Buffer0[12]=d/100%10+'0';
  83.                                 Display_Buffer0[13]='.';
  84.                                 Display_Buffer0[14]=d/10%10+'0';
  85.                                 Display_Buffer0[15]=d%10+'0';
  86.                         }
  87.                         else
  88.                         {
  89.                                 Display_Buffer0[11]=d/100%10+'0';
  90.                                 Display_Buffer0[12]='.';
  91.                                 Display_Buffer0[13]=d/10%10+'0';
  92.                                 Display_Buffer0[14]=d%10+'0';
  93.                                 Display_Buffer0[15]=' ';
  94.                         }
  95.                         DisplayUpdate();
  96.                 }
  97.                 else
  98.                 {
  99.                         if((updateflag)&&(!setenable))
  100.                         {
  101.                                  d = Get_AD_Result(vout);
  102.                                 d &=0x00FF;
  103.                                 d = d*1000.0/255;
  104.                                 if(d/1000)
  105.                                 {
  106.                                         Display_Buffer0[11]=d/1000+'0';
  107.                                         Display_Buffer0[12]=d/100%10+'0';
  108.                                         Display_Buffer0[13]='.';
  109.                                         Display_Buffer0[14]=d/10%10+'0';
  110.                                         Display_Buffer0[15]=d%10+'0';
  111.                                 }
  112.                                 else
  113.                                 {
  114.                                         Display_Buffer0[11]=d/100%10+'0';
  115.                                         Display_Buffer0[12]='.';
  116.                                         Display_Buffer0[13]=d/10%10+'0';
  117.                                         Display_Buffer0[14]=d%10+'0';
  118.                                         Display_Buffer0[15]=' ';
  119.                                 }
  120.                                 DisplayUpdate();
  121.                         }
  122.                 }
  123.
  124.         }
  125. }
收藏收藏3 分享淘帖 顶 踩
ID:726307 发表于 2020-4-13 00:20 | 只看该作者
运行很成功
ID:230975 发表于 2020-4-13 11:10 | 只看该作者
谢谢楼主分享
