查看: 3422|回复: 1
单片机频率检测加PWM调速 lcd1602显示
51单片机频率采集+lcd1602+按键控制PWM
  1. #include<reg52.h>
  2. #include "lcd1602.h"
  3. #define uchar unsigned char//宏定义
  4. #define uint unsigned int//宏定义
  5. sbit ji=P2^1;
  6. sbit jia_key=P3^2;
  7. sbit jian_key=P3^3;
  8. uchar sw,w,q,b,s,g,num=0,gao_num=1;di_num=3;
  9. void timer_init ();
  10. void delay (unsigned int a);
  11. unsigned long fre; //频率
  12. unsigned char time;                //时间
  13. unsigned long count=0;           //计数
  14. void delay(uint z) //延时子程序
  15. {
  16.   uint x,y;
  17.   for(x = z;x > 0;x--)
  18.      for(y = 125;y > 0;y--);
  19. }
  20. /***********************************************************/
  21. /**************************************************/
  22. void timer_init (void)                         //定时器初始化
  23. {
  24.    TMOD = 0x06; //计数器0工作 工作方式2,自动重装初值
  25.    TH0 = 0;           //计数器初值为0
  26.    TL0 = 0;
  27.    TR0 = 1;           //计数器开始计数
  28.    ET0 = 1;           //打开计数器0中断
  29.    RCAP2H = (65536 - 62500) / 256;        //在程序初始化的时候给RCAP2H和RCAP2L赋值
  30.    RCAP2L = (65536 - 62500) % 256;         //TH2与TL2将会在中断产生时断使TH2 = RCAP2H,TL2 = RCAP2L.
  31.    TH2 = RCAP2H;  //12M晶振喜爱每次中断 62.5ms
  32.    TL2 = RCAP2L;
  33.    ET2 = 1;         //打开定时器2中断
  34.    TR2 = 1;        //定时器2开始计时
  35.    EA = 1;        //打开总中断
  36.
  37. }
  38. void timer2 (void) interrupt 5        //定时器2中断62.5ms         服务函
  39. {
  40.         time++;
  41. TF2 = 0; //定时器2的中断标志位TF2不能由硬件清零,所有要在中断服务程序中将其清零
  42.         if (time == 16)        //定时1s时间到
  43.         {
  44.         time = 0; //计时清零
  45.         EA = 0;          //关闭中断
  46. fre =((long)count*256 + TL0); //count*256强制转换为long型,否则将不产生进位
  47.         TL0 = 0;  //清零计数器0计数
  48.         TH0 = 0;
  49.         count = 0;        //清零计数器计数
  50.         EA = 1;          //打开中断
  51.
  52.         }
  53. }
  54. /****************************************************/
  55. void timer0 (void) interrupt 1 //计数器0中断
  56. {
  57.    count++;
  58. }
  59. /*****************************************************/
  60. void display_frequency(unsigned long fre)
  61. {
  62.
  63.         unsigned char bai,shi,ge,xiao,xiaoo;
  64.
  65.         bai=fre/10000;
  66.         shi=fre%10000/1000;
  67.         ge=fre%1000/100;
  68.         xiao=fre%100/10;
  69.         xiaoo=fre%10;
  70.         LCD1602_write_com(0x80+7);          //??????????2??9? ???????1??+8??
  71.         LCD1602_write_data(0x30+bai);                   //bai????2??8? ???????,
  72.         LCD1602_write_com(0x80+8);
  73.         LCD1602_write_data(0x30+shi);                  //??????,?????1 ??shi?????
  74.         LCD1602_write_com(0x80+9);
  75.         LCD1602_write_data(0x30+ge);                  //ge???shi?
  76.         LCD1602_write_com(0x80+10);
  77.         LCD1602_write_data(0x30+xiao);
  78.         LCD1602_write_com(0x80+11);
  79.         LCD1602_write_data(0x30+xiaoo);
  80.         LCD1602_write_com(0x80+12);
  81.         LCD1602_write_word("hz");
  82. }
  83. void key()
  84. {
  85.    if(jia_key==0)
  86. {
  87.    delay(5);
  88.     if(jia_key==0)
  89.   {
  90.     num++;
  91.     if(num==4)
  92.      num=3;
  93.       while(jia_key==0);
  94. }
  95. }
  96. if(jian_key==0)
  97. {
  98.   delay(5);
  99.     if(jian_key==0)
  100. {
  101.      if(num!=0)
  102.      num--;
  103.      else
  104.      num=0;
  105. while(jian_key==0);
  106. }
  107. }
  108. }
  109. void dispose()
  110. {
  111. switch(num)
  112. {
  113. case 0:gao_num=1;di_num=3;break;
  114. case 1:gao_num=2;di_num=2;break;
  115. case 2:gao_num=3;di_num=1;break;
  116. case 3:gao_num=4;di_num=0;break;
  117. }
  118. }
  119. void qudong()
  120. {
  121.    uchar i;
  122.      if(di_num!=0)
  123. {
  124. for(i=0;i<di_num;i++)
  125. {
  126.      ji=0;
  127.            display_frequency(fre);
  128. //        delay(2);
  129. }
  130. }
  131. for(i=0;i<gao_num;i++)
  132. {
  133. ji=1;
  134. display_frequency(fre);
  135. //                delay(2);
  136. }
  137. }
  138.
  139. void main ()
  140. {
  141.   timer_init ();//定时/计数器初始化
  142.   Init_LCD1602();
  143.
  144.   while (1)
  145.   {
  146. //     ji=0;
  147. //                        display_frequency(fre);
  148.                 key();
  149.    dispose();
  150.                 qudong();
  151.   }
  152.
  153. }
51单片机.rar (866.53 KB, 下载次数: 22)
原理图1.rar (31.96 KB, 下载次数: 17)
收藏收藏1 分享淘帖 顶顶 踩踩
ID:639666 发表于 2019-11-11 14:29 | 只看该作者
很好的程序,谢谢你。
