查看: 3005|回复: 0
stm8对电机调速程序
ID:206568 发表于 2017-6-1 16:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"canshu.h"
uint t;
uchar time2_2h=4,time2_2l=4;
void TIM2_Init()
TIM2_CCMR2 = TIM2_CCMR2 | 0x70;// Output modePWM2.
                                //通道2被设置成比较输出方式
                                // OC2M = 111,为PWM模式2,
                                // 向上计数时,若计数器小于比较值,为无效电平
                                // 即当计数器在0到比较值时,输出为1,否则为0
TIM2_CCMR1 = TIM2_CCMR1 | 0x70;
TIM2_CCMR3 = TIM2_CCMR3 | 0x70;
TIM2_CCER1 = TIM2_CCER1 | 0x33;// CC polarity low,enable PWMoutput      */
                                // CC2P = 1,低电平为有效电平
                                // CC2E = 1,开启输出引脚
TIM2_CCER2 = TIM2_CCER2 | 0x03;
//初始化自动装载寄存器,决定PWM方波的频率,Fpwm=16000000/1000=16kHZ
  TIM2_ARRH = 16000/255;
  TIM2_ARRL = 16000%255;
   TIM2_CCR1H =time2_2h;
  TIM2_CCR1L = time2_2l=4;
//初始化比较寄存器,决定PWM方波的占空比
  TIM2_CCR2H =1000/255;
  TIM2_CCR2L =1000%255;
  TIM2_CCR3H = 1000/255;
  TIM2_CCR3L = 1000%255;
//初始化时钟分频器为1,即计数器的时钟频率为Fmaster=4MHZ
  TIM2_PSCR =0x00;//因为用了继电器,所以哟分频,可到0x08,256分频
//启动计数
TIM2_CR1 = TIM2_CR1 | 0x01;
//外部中断触发
void exit_init()
   PC_DDR&=~0x04;
   PC_CR1|=0x04;
   PC_CR2|=0x04;
   EXTI_CR1|= 0x10;
#pragma vector=0x07 // 这里很关键!看下面说明。
__interrupt void EXTI_PC1(void)
  asm("sim");
  switch(EXTI_CR1)
  case 0x10:EXTI_CR1=0x20;exit_flag=1;break;
  case 0x20:EXTI_CR1=0x10;exit_flag=2;break;
  default :exit_flag=0;break;
if(exit_flag==2)
    t++;
   exit_flag=0;
   if(t%10==0)
      ulong chaju;
      now_nus=TIM4_CNTR;
      now_ms=cishu;
     chaju_ms=now_ms-last_ms;
   if(cishu_flag==1)
     cishu_flag=0;
     chaju_ms=30000+now_ms-last_ms;
      chaju_nus=now_nus-last_nus;
      chaju=chaju_ms*250+chaju_nus;
      now_rads=(1250000/chaju);
      last_nus=now_nus;
      last_ms=now_ms;
      last_rads[rads_flag++]=now_rads;
      if(rads_flag==10)
        rads_flag=0;
    pid_error=now_rads-last_radss;
    pid_error1=last_radss-last_radsss;
     last_radsss=last_radss;
     last_radss =now_rads;
   asm("rim");
#pragma vector=TIM2_OVR_UIF_vector
     __interrupt void TIM3_OVF_IRQHandler(void)
         TIM2_SR1 = 0x00;
         ds1820_flag=1;
//定时器2产生60s的中断
void TIM2_time()
     TIM2_EGR=0x01; //手动产生更新事件,重新初始化计数器,并允许产生一个更新事件
    //设置定时器初值
    TIM2_CNTRH=0; //不能使用TIM3_CNTR直接设值,
    TIM2_CNTRL=0;
    //设定自动重装寄存器值
    //这里得注意不能使用TIM2_ARR的方式进行设值,TIM2是十六位的。
    //如TIM2_ARR=0xFA,实际上是赋给高字节了,TIM2_ARRH=0xFA,而不是想象中的赋给低字节。
    TIM2_ARRH=0x72; //488hz 488 /29280  = 60s (1S)
    TIM2_ARRL=0x60; //0x007d   意味着每产生一次中断时间为60S
    TIM2_PSCR=0x0f; //预分频32275
    TIM2_IER=0x01; //中断允许位使能
    TIM2_CR1=0x01; //使能计时器
