查看: 2858|回复: 0
AT24CXX程序
ID:75926 发表于 2015-4-3 01:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//EEPROM程序,AT24CXX,适用于51单片机
//sbit sda=P2^0;
//sbit scl=P2^1;
void delay()
unsigned char shu;
for(shu=2;shu>0;shu--);
void start()  //开始信号
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()   //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons()  //应答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
  temp=temp<<1;
  scl=0;
     delay();
  sda=CY;
  delay();
  scl=1;
  delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
  scl=1;
  delay();
  k=(k<<1)|sda;
  scl=0;
  delay();
return k;
void delay1(uchar x)
uchar a,b;
for(a=x;a>0;a--)
  for(b=100;b>0;b--);
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
收藏收藏1 分享淘帖 顶 踩
