查看: 5795|回复: 0
一个使单片机输出视频的库TVout
ID:99607 发表于 2015-12-19 23:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        一个开源库,使得单片机可以输出视频,可以参考这个(由于是google code 项目,因此不好查看,特地记录如下):
TVout Library
TVout is a completely interrupt driven library that will output either NTSC or PAL composite.
Hardware Connections
Connect an RCA plug to the arduino according to the following schematic. A 75 OHM resistor may be needed between VID and GND on the RCA plug for a very small subset ofTVs
SYNC is on OCR1A and AUDIO is on OCR2A
