查看: 4187|回复: 0
0-99计数器的Verilog源程序
ID:371976 发表于 2018-7-15 15:08 | 显示全部楼层 |阅读模式
module Counter0_99(clk_50M,clr,cn,low_seg,high_seg);
        input clk_50M,clr;
        output cn;
        output [7:0] low_seg;
        output [7:0] high_seg;
        wire cn;
        wire [7:0] low_seg;
        wire [7:0] high_seg;
        wire clk_1Hz;
        wire [3:0] high,low;
        clk_div1Hz A1(.clk_50M(clk_50M),.clk_1Hz(clk_1Hz));
        Twobits_count A2(.clk_1Hz(clk_1Hz),.clr(clr),.high(high),.low(low),.cn(cn));
        decoder1 A3(.high(high),.high_seg(high_seg));
        decoder2 A4(.low(low),.low_seg(low_seg));
endmodule
