设计的基本功能如下: a) 4*4矩阵键盘电路,用于输入与控制工作电路。 b) 液晶显示模块电路,显示当前工作状态。 c) 交通灯模块电路,用于模拟当前路口红绿灯工作状态。 d) 继电器模块电路,闯红灯抓拍功能(灯泡模拟)实现。 系统工作流程如下: a) 电路启动后,按照预先设定的红灯值设定进行运行,东西方向为绿灯,南北方向为红灯,且南北方向的闯红灯抓拍电路工作。 b) 在矩阵键盘输入设定的倒计时值,按下确定键,液晶显示模块相应改变,并通过串口通信,发送到工作单片机上。 c) 工作单片机收到控制单片机发送的数值后,黄灯闪烁3次,按照设定的倒计时时间运行。
- #include <reg51.h>
- #include <LM016L.h>
- uchar Dtime_H, Dtime_L;
- uchar Ttime_H = 0,Ttime_L = 0;
- uchar send_t;
- uchar key;
- uchar out = 0;
- uchar cnt = 0;
- uchar code key_code[]={0xEE, 0xDE, 0xBE, 0x7E, 0xED, 0xDD, 0xBD,
- 0x7D, 0xEB, 0xDB, 0xBB, 0x7B, 0xE7, 0xD7, 0xB7, 0x77};
- uchar LED_VALUE[10]={0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90};
- uchar tab_1[] = {0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
- uchar rdkey(){
- uchar scan1, scan2, keycode, j;
- P1 = 0x0F;
- scan1 = P1;
- if((scan1&0x0F)!=0x0F){
- delay(30);
- scan1 = P1;
- P1 = 0XF0;
- scan2 = P1;
- keycode = scan1 | scan2;
- for(j = 0;j <=15;j++){
- if(keycode == key_code[j]){
- key = j;
- return(key);
- else P1 = 0xFF;
- return (16);
- void exit_int0() interrupt 0{
- rdkey();
- out = 1;
- void Lcd(){
- LcdInitiate(); //调用LCD初始化函数
- WriteAddress(0x00); //将显示地址指定为第1行第0列
- WriteData('D');
- WriteData('e');
- WriteData('l');
- WriteData('a');
- WriteData('y');
- WriteData(':');
- WriteData(Dtime_H);
- WriteData(Dtime_L);
- WriteData('S');
- WriteAddress(0x40);
- WriteData('E');
- WriteData('n');
- WriteData('t');
- WriteData('e');
- WriteData('r');
- WriteData(':');
- delay(10);
- void send(){
- ES = 1;
- SBUF = send_t;
- while(TI == 0);
- TI = 0;
- ES = 0;
- void main(){
- IT0 = 1;
- IP = 0x01;
- P1 = 0x0F;
- EA = 1;
- EX0 = 1;
- TCON = 0x40;
- SCON = 0x50; //方式1 8位
- TMOD = 0x20; //定时器1 方式2
- TH1 = 0xFD;
- TL1 = 0xFD;
- Dtime_H = tab_1[0];
- Dtime_L = tab_1[5];
- Lcd();
- while(1){
- P1 = 0x0F;
- if(out == 1 && key < 10){
- cnt++;
- if(cnt > 1)
- Ttime_H = Ttime_L;
- Ttime_L = key;
- WriteData(tab_1[Ttime_L]);
- out = 0;
- }else if(out == 1 && key > 10){
- if(key == 11){ //清除
- Lcd();
- out = 0;
- cnt = 0;
- Ttime_H = 0;
- }else if(key == 15){ //确认
- Dtime_H = tab_1[Ttime_H];
- Dtime_L = tab_1[Ttime_L];
- out = 0;
- cnt = 0;
- send_t = Ttime_H*10 + Ttime_L;
- send();//send message
- Lcd();
- }else if(key == 13){ //初始化
- Ttime_H = 0;
- WriteData(tab_1[Ttime_H]);
- Ttime_L = 5;
- out = 0;
- cnt = 2;
- //send message
traffic light.rar
(37.96 KB, 下载次数: 36)
