查看: 57506|回复: 26
altium designer 原理图复制出错问题 InvalidParameter at AdvSch.dll, Base Addre...
ID:70976 发表于 2014-12-25 01:10 | 显示全部楼层 |阅读模式
InvalidParameter at 2510219C.
AdvSch.dll, Base Address: 24C80000.
Exception Occurred In Copy
使用AD14在复制的时候偶尔会出现这样的一个问题
然后会出先复制出错的情况,也有人说这是破解版的一个通病
使用用“剪切-粘贴”,还会报错,但可以粘贴成功。
ID:73167 发表于 2015-2-2 20:45 | 显示全部楼层
同问
ID:74817 发表于 2015-3-18 22:59 | 显示全部楼层
出现上述怎样解决
ID:75918 发表于 2015-4-1 21:25 | 显示全部楼层
这个问题难道就无解了吗
ID:76631 发表于 2015-4-10 22:15 | 显示全部楼层
我也出现这样的问题,怎么解决?
ID:77133 发表于 2015-4-16 11:03 | 显示全部楼层
刚刚解决这个问题:
先看看能不能添加本地打印机,要是无法添加打印机,在桌面选中“我的电脑”,鼠标右键选择“管理”;
在“管理”窗口中,选取“服务和应用程序”扩展项目下的“服务”选项,在右侧出现系统服务列表中找到“Print Spooler”服务,双击进入“Print Spooler”服务设置;
在“Print Spooler”服务设置窗口中,将“启动类型”设置为“自动”,点击“启动”按钮;
此时系统会尝试启动该服务;
当服务启动成功后,“服务状态”会显示为“已启动”,重新进行添加或是使用打印机的其它操作。
如果复制还出错:
添加本地打印机:开始》》设备和打印机》》添加打印机》》创建新端口》》下一步》》输入test》》厂商选Microsoft,打印机选Microsoft XPS Document Writer
        转载来自百度altuim吧   庆州123
ID:83463 发表于 2015-6-19 20:44 | 显示全部楼层
下载一个虚拟打印机,给个网址可以下载http://www.cr173.com/soft/32263.html
参与人数 1黑币 +5 收起 理由
tangquan + 5 很给力!
ID:85181 发表于 2015-7-9 11:32 | 显示全部楼层
I had this issue with AD13 and AD14 after reinstalling and in SAFE MODE just in case it was some other program interfering. Well it turn out that this issue was related to the spooler service being turned off. I have a habit of turning off features on my computer that i do not use, and since i dont have a printer attached to my machine... i stoped the spooler service. So make sure that it is running first before you run altium.
go to start -> run -> type "cmd"
in the command prompt window type:
net start spooler
You should see this:
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Re-open Altium and you should be good.
Why in the world AD needs the spooler service turned on to do a simple copy paste operation is beyond me.
ID:85199 发表于 2015-7-9 15:02 | 显示全部楼层
牛人,照你的方法下了打印机安装上就好了
ID:87339 发表于 2015-7-31 13:34 | 显示全部楼层
我也出现了这个问题,我先试试上面的方法
ID:87879 发表于 2015-8-7 20:04 | 显示全部楼层
为什么会出现这种问题呢?是不是清理软件搞的鬼
ID:113663 发表于 2016-4-12 10:04 | 显示全部楼层
liuyufengdq 发表于 2015-4-16 11:03
**** 作者被禁止或删除 内容自动屏蔽 ****
太感谢楼主了,现在好啦
ID:123002 发表于 2016-5-24 22:47 | 显示全部楼层
谢谢分享。
ID:149871 发表于 2016-11-24 09:18 | 显示全部楼层
谢谢啊  好人一生平安
ID:150909 发表于 2016-11-29 09:20 | 显示全部楼层
我也遇到过
ID:152226 发表于 2016-12-5 10:09 | 显示全部楼层
我也 要
ID:143559 发表于 2017-1-19 10:17 | 显示全部楼层
O(∩_∩)O谢谢
ID:169623 发表于 2017-3-10 13:55 | 显示全部楼层
感谢大神  弄好了
ID:198323 发表于 2018-6-27 09:06 | 显示全部楼层
我安装了 怎么不行,是还需要其他操作吗
ID:389771 发表于 2018-8-24 20:33 | 显示全部楼层
万分感谢,已解决
ID:382973 发表于 2018-11-13 11:19 | 显示全部楼层
牛逼  赞赞啊
ID:339180 发表于 2019-2-26 13:49 | 显示全部楼层
大神,解决了,谢谢
ID:34556 发表于 2019-3-13 10:06 | 显示全部楼层
非常给力
ID:575820 发表于 2019-7-1 17:05 | 显示全部楼层
牛逼啊兄嘚
ID:529775 发表于 2019-7-7 10:27 | 显示全部楼层
感谢,复制没问题了
ID:475783 发表于 2019-7-7 10:36 | 显示全部楼层
牛人,这都可以
ID:247810 发表于 2019-7-17 21:55 | 显示全部楼层
谢谢 分享
