查看: 2680|回复: 2
新手求教---数码管动态显示闪烁问题
ID:88716 发表于 2015-8-22 11:37 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint unsigned int
sbit we=P2^7;
sbit du=P2^6;
sbit S2=P3^0;
sbit S3=P3^1;
sbit S4=P3^2;
sbit S5=P3^3;
uchar count;
uint timer_count;
uchar code leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x00  //自定义
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void timer_init()
        TMOD=0x01;
        TH0=0x4b;
        TL0=0xfd;
        TR0=1;
void display(uint i)
        char ge,shi,bai,qian;
        qian=i/1000;
        bai=i%1000/100;
        shi=i%1000%100/10;
        ge=i%1000%100%10;
        du=1;
        P0=leddata[qian];
        du=0;
        P0=0xff;
        we=1;
        P0=0xfe;
        we=0;
        delay(1);
        du=1;
        P0=leddata[bai];
        du=0;
        P0=0xff;
        we=1;
        P0=0xfd;
        we=0;
        delay(1);
        du=1;
        P0=leddata[shi];
        du=0;
        P0=0xff;
        we=1;
        P0=0xfb;
        we=0;
        delay(1);
        du=1;
        P0=leddata[ge];
        du=0;
        P0=0xff;
        we=1;
        P0=0xf7;
        we=0;
        delay(1);
        timer_init();
                if(TF0==1)
                        TF0=0;
                        TH0=0x4b;
                        TL0=0xfd;
                        count++;
                if(count==2)
                        count=0;
                        timer_count++;
                        if(timer_count>=9999)
                        timer_count=0;
                        display(timer_count);
这是从0开始到9999,每次增加1程序,为什么前三位出现闪烁现象,怎么改延迟时间都没用,求帮忙看看
ID:79908 发表于 2015-8-22 19:29 | 显示全部楼层
        timer_init();
void timer0() interrupt 1
        TH0 = 0x4b;
        TL0 = 0xfd;
        count++;
        if(count==2)
        {                               count = 0;
                timer_count++;
                if(timer_count>=10000)
                        timer_count = 0;
你试一试,主函数里就一个显示函数!
ID:88716 发表于 2015-8-26 17:39 | 显示全部楼层
最后我通过将display(timer_count);拿出IF语句外就解决了呢
