这是程序 照着书上写的 #include<reg52.h> #define uchar unsigned char #define uint unsigned int sbit dula=P2^6; sbit wela=P2^7; sbit led1=P1^0; uchar code table []={0xc0,0xf9,0xa4,0xb0, 0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83, 0xc6,0xa1,0x86,0x8e}; void delayms(uint); void display(uchar,uchar); uchar num,num1,num2,shi,ge; void main() {TMOD=0x11; TH0=(65536-45872)/256; TL0=(65536-45872)%256; TH1=(65536-45872)/256; TL1=(65536-45872)%256;
EA=1; ET0=1; ET1=1; TR0=1; TR1=1; while(1) {
display(shi,ge); } } void display (uchar shi,uchar ge) { dula=1 ; P0=table[shi]; dula=0; P0=0xff; wela=1; P0=0xfe; wela=0; delayms(5); dula=1; P0=table[ge]; dula=0; P0=0xff; wela=1; P0=0xfd; wela=0; delayms(5); } void delayms(uint xms) { uint i,j; for(i=xms;i>0;i--) for(j=110;j>0;j--); } void T0_time() interrupt 1 { TH0=(65536-45872)/256; TL0=(65536-45872)%256; num1++; if(num1==4) { num1=0; led1=~led1; } } void T1_time() interrupt 3
{ TH1=(65536-45872)/256; TL1=(65536-45872)%256; num2++; if(num2==20) { num2=0; num++; if(num==60)
num=0; shi=num/10; ge=num%10; } }
