查看: 6517|回复: 4
STM32规则组ADC转换(DMA 多通道单次采集)源程序
ID:198180 发表于 2017-5-8 16:04 | 显示全部楼层 |阅读模式
STM32规则组转换 (DMA 多通道单次采集)
stm32单片机源程序:
  1. //通过串口实时打印KEY3 KEY4电压值。
  2. //每个通道采集一次
  3. #include "pbdata.h"
  4. void RCC_Configuration(void);
  5. void GPIO_Configuration(void);
  6. void NVIC_Configuration(void);
  7. void USART_Configuration(void);
  8. void ADC1_Configuration(void);
  9. void DMA_Configuration(void);
  10. vu16 AD_Value[M];        //用来存放ADC转换结果,也是DMA的目标地址
  11. int fputc(int ch,FILE *f)
  12. {
  13.         USART_SendData(USART1,(u8)ch);
  14.         while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
  15.         return ch;
  16. }
  17. int main(void)
  18. {
  19.         RCC_Configuration();
  20.         GPIO_Configuration();
  21.         USART_Configuration();
  22.         NVIC_Configuration();
  23.         ADC1_Configuration();
  24.         DMA_Configuration();
  25.
  26.         while(1)
  27.         {
  28.                 printf("AD_Value[0]=%f\r\n",AD_Value[0]*3.3/4095);
  29.                 printf("AD_Value[1]=%f\r\n",AD_Value[1]*3.3/4095);
  30.                 printf("AD_Value[2]=%f\r\n",AD_Value[2]*3.3/4095);
  31.                 delay_ms(1000);
  32.
  33.
  34. //                printf("value[%d]=\t%d\r\n",i,value[i]);
  35.         }
  36. }
  37. void RCC_Configuration(void)
  38. {
  39.     SystemInit();//72m
  40.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);        //GPIOA
  41.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);        //USART
  42.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);                //AFIO
  43.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);        //GPIOC
  44.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);                //ADC
  45.         RCC_ADCCLKConfig(RCC_PCLK2_Div6);                                                //12M  最大14M
  46.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);                 //使能DMA传输
  47. }
  48. void GPIO_Configuration(void)
  49. {
  50.     GPIO_InitTypeDef GPIO_InitStructure;
  51.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX
  52.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  53.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  54.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  55.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
  56.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  57.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  58.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3;//ADin: POT K3 K4
  59.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;                //模拟输入
  60.         GPIO_Init(GPIOC,&GPIO_InitStructure);
  61.
  62.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1;//ADin: sensor1 sensor2  VOC
  63.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;                //模拟输入
  64.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  65. }
  66. void NVIC_Configuration(void)
  67. {
  68.            NVIC_InitTypeDef NVIC_InitStructure;
  69.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  70.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  71.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  72.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  73.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  74.         NVIC_Init(&NVIC_InitStructure);
  75.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//中断向量
  76.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;        //1
  77.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                        //0
  78.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  79.         NVIC_Init(&NVIC_InitStructure);
  80.
  81. }
  82. void USART_Configuration(void)
  83. {
  84.     USART_InitTypeDef  USART_InitStructure;
  85.         USART_InitStructure.USART_BaudRate=9600;
  86.         USART_InitStructure.USART_WordLength=USART_WordLength_8b;
  87.         USART_InitStructure.USART_StopBits=USART_StopBits_1;
  88.         USART_InitStructure.USART_Parity=USART_Parity_No;
  89.         USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
  90.         USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
  91.         USART_Init(USART1,&USART_InitStructure);
  92.         USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
  93.         USART_Cmd(USART1,ENABLE);
  94.         USART_ClearFlag(USART1,USART_FLAG_TC);
  95. }
  96. void ADC1_Configuration(void)
  97. {
  98.         ADC_InitTypeDef  ADC_InitStructure;
  99.         ADC_DeInit(ADC1);                                                //将外设 ADC1 的全部寄存器重设为缺省值
  100.
  101.         ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;                //ADC1 ADC2工作在独立模式
  102.         ADC_InitStructure.ADC_ScanConvMode=ENABLE;                                //工作在单通道模式(还是扫描模式:多通道模式)
  103.         ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;                //模数转换工作在单次模式(还是连续模式)
  104.         ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动
  105.         ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;        //ADC数据右对齐
  106.         ADC_InitStructure.ADC_NbrOfChannel=M;                //顺序进行转换的通道数
  107.         ADC_Init(ADC1, &ADC_InitStructure);                 //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  108.
  109.         //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
  110.         //ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
  111. //        ADC_RegularChannelConfig(ADC1,ADC_Channel_0, 1,ADC_SampleTime_239Cycles5);//选择ADC1通道0 -PA0 SENSOR1
  112. //        ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 2,ADC_SampleTime_239Cycles5);//选择ADC1通道1 -PA1 SENSOR2
  113.         ADC_RegularChannelConfig(ADC1,ADC_Channel_10,3,ADC_SampleTime_239Cycles5);//选择ADC1通道10-PC0 POT
  114.         ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_239Cycles5);//选择ADC1通道12-PC2 KEY3
  115.         ADC_RegularChannelConfig(ADC1,ADC_Channel_13,2,ADC_SampleTime_239Cycles5);//选择ADC1通道13-PC3 KEY4
  116. //
  117.         ADC_DMACmd(ADC1, ENABLE);                                // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
  118.         ADC_Cmd(ADC1, ENABLE);                                         //使能指定的ADC1
  119.
  120.         ADC_ResetCalibration(ADC1);        //重置校准器
  121.         while(ADC_GetResetCalibrationStatus(ADC1));//获取校准状态
  122.         ADC_StartCalibration(ADC1);//开始指定ADC的校准状态
  123.         while(ADC_GetCalibrationStatus(ADC1));        //获取指定ADC的校准程序
  124.
  125. //        ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE);        //中断使能
  126.         ADC_SoftwareStartConvCmd(ADC1,ENABLE);//使能软件启动功能
  127. }
  128. void DMA_Configuration(void)
  129. {
  130.         DMA_InitTypeDef DMA_InitStructure;
  131.         DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值
  132.         DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外设ADC基地址
  133.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA内存基地址
  134.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //内存作为数据传输的目的地 外设作为数据传输的来源
  135.         DMA_InitStructure.DMA_BufferSize = M; //DMA通道的DMA缓存的大小
  136.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
  137.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
  138.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //数据宽度为16位
  139.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16位
  140.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循环缓存模式,当传输完一次后,重新接着传送,永不停息。
  141.         DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
  142.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
  143.         DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道
  144.         DMA_Cmd(DMA1_Channel1, ENABLE); //启动DMA通道
  145.
  146. …………限于本文篇幅 余下代码请从51黑下载附件…………
完整代码下载:
3 规则组转换 (DMA 多通道单次采集).7z (189.76 KB, 下载次数: 87)
ID:228193 发表于 2017-8-17 22:41 | 显示全部楼层
奇迹挑了好久没跳出来,过来看看。
ID:379581 发表于 2018-9-6 17:05 | 显示全部楼层
受益匪浅,但是如果遇见了,两个通道都要采集ADC1和ADC2,同时通道数不一样,比如ADC1有8通道,ADC2只有2个通道的情况,DMA又该如何配置呢
ID:547509 发表于 2019-5-29 11:23 | 显示全部楼层
这里这样设置,不是单次吧?
ID:248814 发表于 2019-5-29 17:37 | 显示全部楼层
谢谢楼主,资料非常好用, 很不错66666
