专注电子技术学习与研究
ST7920控制芯片的带字库12864液晶驱动程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2010年09月14日   【字体:大 中 小】
/***测试OK,我的是12864-15型引脚。并口驱动****/-
#include "reg52.h"-
#include <intrins.h>-
#define LCD12864_IOP0-
#define LINE10-
#define LINE21-
#define HIGH1-
#define LOW 0-
#defineCLERADISPLAYLCD12864_command(0x01);-
code unsigned char gImage_test[1024] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04}  ;
sbit LCD12864_EN=P2^7;
sbit LCD12864_DIN=P2^6;
sbit LCD12864_CLK=P2^5;
void LCD12864_busy(void);-
void LCD12864_command(unsigned char command);-
void LCD12864_data(unsigned char dat);-
void LCD12864_address(unsigned char row,unsigned char line);-
void LCD12864_char(unsigned char dat);-
void LCD12864_string(unsigned char row,unsigned char line,unsigned char *s);-
void LCD12864_picture(unsigned char *gImage);-
void LCD12864_init(void);-
void Mcu_init(void)-
LCD12864_init();-
CLERADISPLAY  -
CLERADISPLAY  -
LCD12864_init();-
void Delay(void)-
unsigned char i;-
    unsigned int j;-
for(i=0;i<200;i++)-
for(j=1000;j>0;j--);-
void main(void)-
Mcu_init();-
LCD12864_picture((unsigned char*)gImage_test); -
Delay();Delay();-
CLERADISPLAY  -
while(1)-
LCD12864_string(1,1," LCD12864-15  "); -
LCD12864_string(1,2,"中文显示测试实验"); -
LCD12864_string(1,3," 少占鱼  ");-
LCD12864_string(1,4,"    2010-1-26  ");-
void LCD12864_DELAY(unsigned int a)-
for(;a>0;a--) -
_nop_();-
void LCD12864_busy(void)-
    bit BF = 0;-
    LCD12864_EN=0; -
    LCD12864_DIN=0;-
    LCD12864_CLK=1;-
    LCD12864_IO=0xff;//单片机读数据之前必须先置高位-
    do-
    LCD12864_EN=1;-
        BF=LCD12864_IO&0x80;-
        LCD12864_EN=0;-
    } while(BF);-
//          写入命令-
void LCD12864_command(unsigned char command)-
    LCD12864_busy();-
    LCD12864_EN=0;-
    LCD12864_DIN=0;-
    LCD12864_CLK=0;  -
    LCD12864_EN=1;-
    LCD12864_IO=command;-
    LCD12864_EN=0;-
//          写入一字节数据-
void LCD12864_data(unsigned char dat)-
    LCD12864_busy();-
    LCD12864_EN=0;-
    LCD12864_DIN=1;-
    LCD12864_CLK=0;-
    LCD12864_EN=1;-
    LCD12864_IO=dat;-
    LCD12864_EN=0;-
-//读数据函数
unsigned char LCD12864_ReadData()
  unsigned char read_data;
   LCD12864_busy();
    LCD12864_IO=0xff;
 LCD12864_RS=1;
 LCD12864_RW=1;
 LCD12864_EN=0;
 LCD12864_EN=1;
 read_data=LCD12864_IO;
    LCD12864_EN=0;
 return(read_data);
void LCD12864_char(unsigned char dat)-
if((dat>=0)&&(dat<=9))-
    dat|=0x30;-
    LCD12864_data(dat);-
//          设置显示位置    X(1~8),Y(1~4)-
void LCD12864_address(unsigned char line,unsigned char row)-
    switch(row) -
        case 1:LCD12864_command(0x7f + line);-
        break;-
        case 2:LCD12864_command(0x8f + line);-
        break;-
        case 3:LCD12864_command(0x87 + line);-
        break;-
        case 4:LCD12864_command(0x97 + line);-
        default:-
        break;-
//          在指定位置显示字符串-
void LCD12864_string(unsigned char row,unsigned char line,unsigned char *s)-
    unsigned char LCD12864_temp; -
    LCD12864_address(row,line); -
    LCD12864_temp=*s;-
    while(LCD12864_temp != 0x00) -
        LCD12864_data(LCD12864_temp);-
        LCD12864_temp=*(++s);-
//          绘制一幅图片-
void LCD12864_picture(unsigned char *gImage) -
    unsigned char X = 0x80,Y = 0x80;-
    unsigned char i,j;-
    for(i=0;i<64;i++) -
        for(j=0;j<16;j++) -
            LCD12864_command(0x34);-
            LCD12864_command(Y);-
            LCD12864_command(X);-
            LCD12864_data(*(gImage+i*16+j));      //  low 8 bits-
            LCD12864_data(*(gImage+i*16+j+1));    //  high 8 bits-
            LCD12864_command(0x36);-
            X++;-
            j++;-
        Y++; -
        if(Y>0x9f) -
            Y=0x80; -
        X=0x80+((i+1)/32)*8; -
    LCD12864_command(0x30);-
//          初始化设置-
void LCD12864_init(void)-
    CLERADISPLAY    //  clear DDRAM-
    LCD12864_command(0x30);     //  8 bits unsigned interface,basic instrument-
    LCD12864_command(0x02);     //  cursor return-
    LCD12864_command(0x0c);     //  display,cursor on-
    LCD12864_command(0x03);   -
    LCD12864_command(0x06);-
0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 上半屏行坐标,表示的是多少列
0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 下半屏行坐标,每组8列,每列16位,共128位,
0x80
0x81
0x82
0x83
0x9f    //列坐标,共32个,表示的是行数 ,分两个半屏,每个32行,共64行
         //Y坐标 只是用来确定具体坐标,在哪一行
   功能:图形模式下,显示(X,Y)点
        输入:X(0~127) Y(0~63) 相对屏幕坐标
        输出:无
点亮某一点的操作步骤: 1.求出水平坐标X对应的地址和是哪一位  0x80-----0x8f  (范围0-15) X/16求地址 X%16求该地址哪一位
         2.求垂直坐标Y对应的地址和上下半屏  0x80------0x9f(范围0-63) Y本身就是8位地址,Y=63-Y ,Y--(0-31)
         3.写入行列地址(Y是行X是列),0x80+Y  ,0X80+X/16
                       4.读要显示的数据 DAT
                       5.区分上下半屏(X%16<=7&&X%16>=0是上半屏)写入数据每一位 DAT|0x80 ;DAT<<1
             注意:这个函数显示某一点时,可能会把上次显示的处于同一地址的其他位的点擦掉,所以先保存所有数据,最后显示,就连贯起来了
//------------------清整个GDRAM空间----------------------------
void clrgdram()
    unsigned char x,y ;
    for(y=0;y<64;y++)
    for(x=0;x<16;x++)
       LCD12864_command(y+0x80);
       LCD12864_command(x+0x80);
      LCD12864_data(0x00);
/*******8==========================================================================
功能:图形模式下,显示(X,Y)点
输入:X(0~127) Y(0~63)
输出:无
0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 上半屏行坐标,表示的是多少列,X地址
0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 下半屏行坐标,X地址 (水平地址 )
0x80  (垂直地址)
0x81
0x82
0x83
void LCD12864_Drawpoint(uchar X,uchar Y)
     uchar i= 0, j = 0,ok=0;
     uchar temp1 = 0x00,temp2 = 0x00;
     LCD12864_command(0x34);  //8位,扩充指令,绘图关
     LCD12864_command(0x36);  //8位,扩充指令,绘图开
     i = X/16;  //计算出X字节地址(0X80-0X8F)
     j = X%16;  //计算出该字节的具体位(0-15)
     //Y = 63 - Y;
   if(Y>=0 && Y<=31)//判断上下半屏
        ok=1;
   else if(Y>=32 && Y<=63)//下半屏
       Y = Y - 32;//Y只有0-31共32个 地址
       i = i + 8;//X地址进入下半屏 (0X88-0X8F)
    ok=1;
   if(ok)
     //读数据操作
        LCD12864_command(0x80+Y);   //第一步:设置Y坐标,读数据先写地址,写GDRAM时先写垂直地址(0X80-0X9F)
        LCD12864_command(0x80+i);  //第二步:设置X坐标
        LCD12864_ReadData();    //第三步:空读取一次
        temp1 =LCD12864_ReadData();    //第四步:读取高字节,先读高字节
        temp2 =LCD12864_ReadData();   //第五步:读取低字节
          //图形模式下的写数据操作
         if(j>=0 && j<=7)   //判断是高字节
         LCD12864_data(temp1|(0x80>>j));  //第三步:写高字节数据
         LCD12864_data(temp2);      //第四步:写低字节数据
         else if(j>7 && j<=15)   //判断是低字节
              j = j - 8;
            LCD12864_data(temp1);
            LCD12864_data(temp2|(0x80>>j));  //改变字节里的位
//画线
//画水平线
void LCD12864_LineX(unsigned char X0, unsigned char X1, unsigned char Y)
 unsigned char Temp ;
 if( X0 > X1 )
 Temp = X1 ;    //交换X0 X1值
 X1 = X0 ;     //大数存入X1
 X0 = Temp;   //小数存入X0
for( ; X0 <= X1 ; X0++ )
LCD12864_Drawpoint(X0,Y);
//画垂直线
void LCD12864_LineY( unsigned char X, unsigned char Y0, unsigned char Y1)
if( Y0 > Y1 )//交换大小值
Temp = Y1 ;
Y1 = Y0 ;
Y0 = Temp ;
for(; Y0 <= Y1 ; Y0++)
LCD12864_Drawpoint( X, Y0) ;
/**************画图************************/
  void LCD12864_DrawPicture( unsigned char code *pic)
    unsigned char i, j, k ;
        LCD12864_command(0x34);//开扩充指令
        LCD12864_command(0x36);//开绘图功能
for( i = 0 ; i < 2 ; i++ )//分上下两屏写
for( j = 0 ; j < 32 ; j++)//垂直地址递加 ,行扫方式
  LCD12864_command( 0x80 + j ) ;//写Y坐标(Y的范围: 0X80-0X9F )
if( i == 0 ) //写X坐标
LCD12864_command(0x80);//上半屏
LCD12864_command(0x88);//下半屏开始地址
for( k = 0 ; k < 16 ; k++ ) //写一整行数据
 LCD12864_data( *pic++ );//前面只写入首地址,后面依次写入数据,地址会自动递增
LCD12864_command( 0x30);//恢复到一般模式
【关闭窗口】
相关文章
