专注电子技术学习与研究
7219芯片驱动LED的电子时钟
作者:佚名   来源:本站原创   点击数:…  更新时间:2010年09月14日   【字体:大 中 小】
/***************时钟采用定时中断方式,50MS一次******完整可用,硬件实验通过**********************/
#include <REG51.H>
#include <stdio.h>
#include <intrins.h>
//common part
#define  HIGH     1
#define  LOW      0
#define  TRUE      1
#define  FALSE      0
#define  ZERO      0
#define  MSB       0x80
#define  LSB       0x01
//max7219 part
#define REG_NO_OP 0x00 // 定义空操作
#define DIG_1 0x01 // 定义数码管1
#define DIG_2 0x02 // 定义数码管2
#define DIG_3 0x03 // 定义数码管3
#define DIG_4 0x04 // 定义数码管4
#define DIG_5 0x05 // 定义数码管5
#define DIG_6 0x06 // 定义数码管6
#define DIG_7 0x07 // 定义数码管7
#define DIG_8 0x08 // 定义数码管8
#define  DECODE_MODE   0x09
#define  INTENSITY     0x0A
#define  SCAN_LIMIT    0x0B
#define  SHUT_DOWN     0x0C
#define  DISPLAY_TEST  0x0F
uchar  deda,sec,min,hour,week=1;
//change this part at different board
sbit LOAD=P2^7; //MAX7219    Load-Data Input:    rising edge  pin 12
sbit DIN=P2^5; //MAX7219    Serial-Data Input:   rising edge  pin 1
sbit CLK=P2^6; //MAX7219
sbit  TT=P1^4;
sbit  QQ=P3^6;
sbit  RR=P3^7;
//function define
void Write_Max7219_byte(unsigned char temp);//write max7219 a byte
void Write_Max7219(unsigned char address,unsigned char dat);//write max7219 command and data
void Init_Max7219(void);//Initize max7219
//test program display from 1~8
 unsigned char i;
 for (i=0;i<8;i++)
   CLK=LOW;
     DIN=(bit)(temp&MSB);
     temp<<=1;
     CLK=HIGH;
 LOAD=LOW;
   Write_Max7219_byte(address);
   Write_Max7219_byte(dat);
  LOAD=HIGH;
 Write_Max7219(SHUT_DOWN, 0x01);   //Normal Operation XXXXXXX1 Shutdown Mode   XXXXXXXX0
 Write_Max7219(DISPLAY_TEST, 0x00);   //Normal Operation XXXXXXX0 Display Test Mode
 Write_Max7219(DECODE_MODE, 0xff);   //Decode Mode Select D7~D0 1 B decode 0 No decode
 Write_Max7219(SCAN_LIMIT, 0x07);   //SCAN LIMIT 0~7 0xX0~0xX7
 Write_Max7219(INTENSITY, 0x04);
 Write_Max7219(DIG_4,0x02); Write_Max7219(DIG_3,0x01);
 Write_Max7219(DIG_6,0x07);  Write_Max7219(DIG_5,0x05);
 Write_Max7219(DIG_7,0x01);
void init(void)
TMOD=0x01;
TH0=-(50000/256);
TL0=-(50000%256);
ET0=1;
TR0=1;
EA=1;
TT=0;
QQ=0;
RR=0;
Init_Max7219();
void time0(void) interrupt 1
TH0=-(50000/256);
TL0=-(50000%256);
deda++;
void conv(void)
if(deda>=20){deda=0;sec++;Write_Max7219(DIG_8,sec%10); Write_Max7219(DIG_7,sec/10); }
if(sec>=60){sec=0;min++;   Write_Max7219(DIG_6,min%10);  Write_Max7219(DIG_5,min/10);}
if(min>=60){min=0;hour++; Write_Max7219(DIG_4,hour%10); Write_Max7219(DIG_3,hour/10);}
if(hour>=24){hour=0;week++; Write_Max7219(DIG_2,week%10);}
if(week>7){week=1;}
if(hour==3) TT=1;
void delay(uint k)
uint data i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
uchar scan_key(void)
uchar temp;
P3=0x3f;
temp=P3;
if(temp!=0x3f)
   {delay(20);
    temp=P3;
   if(temp!=0x3f) return temp;
return 0x3f;
void main(void)
{uchar key_flag;
 init();
 conv();
 key_flag=scan_key();
 switch(key_flag)
    case 0x3b:if(++min>59)min=0; delay(300); Write_Max7219(DIG_6,min%10);  Write_Max7219(DIG_5,min/10);break;
    case 0x37:if(++hour>23)hour=0; delay(300);Write_Max7219(DIG_4,hour%10); Write_Max7219(DIG_3,hour/10);break  ;
    case 0x2f:if(++week>7)week=1 ; delay(300); Write_Max7219(DIG_2,week%10);break;
    default:  break;
【关闭窗口】
相关文章
