专注电子技术学习与研究
Tm1639汇编驱动程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2012年03月27日   【字体:大 中 小】
#include<reg51.h>
sbit DIO=P1^2;
sbit CLK=P1^1;
sbit STB=P1^0;
#define DIG0 0xc0
#define DIG1 0xc2
#define DIG2 0xc4
#define DIG3 0xc6
#define DIG4 0xc8
#define DIG5 0xca
#define DIG6 0xcc
#define DIG7 0xce
#define LEVEL_OFF   0x80
#define LEVEL_1     0x88
#define LEVEL_2     0x89
#define LEVEL_4     0x8a
#define LEVEL_10    0x8b
#define LEVEL_11    0x8c
#define LEVEL_12    0x8d
#define LEVEL_13    0x8e
#define LEVEL_14    0x8f
#define MD_WRITE        0x40
#define MD_AUTO         MD_WRITE
#define MD_NORMAL       MD_WRITE
#define MD_READKEY      0x42
#define MD_FIX          0x44
#define MD_TEST         0x48
typedef unsigned char uint8;
typedef unsigned int  uint16;
uint16 key;
code uint8 shuzu[17] ={ 0x3F,0x06,0x5B,0x4F,
      0x66,0x6D,0x7D,0x07,
      0x7F,0x6F,0x77,0x7c,
      0x39,0x5e,0x79,0x71,
      0x00,
void xianshi(uint8 x,uint8 led,uint8 level);
void shizhong();
void chushi();
void ClearAll();
void KeyRead(uint16 *key);
void indate(unsigned char input)
unsigned int i;
STB=0;
for(i=0;i<8;i++) {
    CLK=0;
    if((input & 0x01)!=0)
      DIO=1;
      DIO=0;
    CLK=1;
    input=input>>1;
unsigned char outdate()
unsigned char i,out=0;
DIO= 1;
STB=0;
for(i=0;i<8;i++) {
    CLK=0;
    out=out>>1;
    if(DIO == 0)
        out=out & 0x7f;
        out=out | 0x80;
    CLK=1;
return(out);
void chushi()
CLK     = 1;
STB     = 1;
DIO     = 1;
 void jishi()
 TMOD |= 0x10;
 TMOD &= 0xdf;
 TH1=0xb8;
 TL1=0x00;
 TR1=1;
 EA=1;
    ET1 = 1;
  void ql()
     xianshi(7,0,LEVEL_11);
         xianshi(6,0,LEVEL_11);
   xianshi(4,0,LEVEL_11);
   xianshi(3,0,LEVEL_11);
   xianshi(1,0,LEVEL_11);
   xianshi(0,0,LEVEL_11);
 uint8 i;
 static uint8 cled[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};
  for(i = 0 ;i < 8;i ++ ){
 if((shuzu[led]>>i)&0x01)
  cled[i] |= (0x01<< x);
  cled[i] &= ~(0x01<< x);
 DIO=1;
 CLK=1;
 STB=1;
 indate(MD_WRITE);
 STB = 1;
 indate(DIG0);
 for( i = 0 ; i<16; i+= 2){
  indate(cled[i/2] & 0x0f);
  indate(cled[i/2] >> 4 & 0x0f);
 STB=1;
 indate(level);
 STB=1;
void ClearAll()
unsigned int i;
DIO=1;
CLK=1;
STB=1;
indate(MD_AUTO);
STB=1;
indate(DIG0);
for(i=0;i<16;i++)
      indate(0);
STB=1;
indate(0x80);
STB=1;
unsigned char key1,key2;
STB=1;
indate(MD_READKEY);
key1 = outdate();
key2 = outdate();
*key = key1 | (key2 << 8);
STB=1;
 void delay()
 {  uint16 n;
     uint8 k;
  for(k=0;k<10;k++)
  for(n=0;n<6000;n++)
void zhongduan()interrupt 3
shizhong();
void shizhong()
 static uint16 count=0;
 static uint16 scount=0;
 static uint8  a=0;
 static uint8  b=0;
 static uint8  c=0;
 static uint8  d=0;
 static uint8  x=0;
 static uint8  y=0;
 TH1=0xb8;
 TL1=0x00;
 count++;
 if(count==5)
     count=0;
  scount++;
x=scount/10%10;
y=scount/100%10;
xianshi(7,x,LEVEL_11);
if(scount%600==0)
xianshi(6,0,LEVEL_11);scount=0;a++;
else xianshi(6,y,LEVEL_11);
if(a>=10)
a=0;b++;
xianshi(4,a,LEVEL_11);
if(b>=6)
b=0;c++;
xianshi(3,b,LEVEL_11);
if(d<2){
if(c==10){
c=0;d++;}
xianshi(1,c,LEVEL_11);
xianshi(0,d,LEVEL_11);}
else if(d>=2){if(d>2)d=0;
if(c==4){
c=0;d=0;}
KeyRead(&key);
if(key==0x0008)a++;
KeyRead(&key);
if(key==0x0080)b++;
KeyRead(&key);
if(key==0x0800)c++;
KeyRead(&key);
if(key==0x8000)d++;
if(key==0x0004){scount=0;
x=0;y=0;}
main()
  ql();
  jishi();
     while(1){};
【关闭窗口】
相关文章
