专注电子技术学习与研究
51单片机语音+温度控制的源码
作者:佚名   来源:本站原创   点击数:…  更新时间:2012年10月13日   【字体:大 中 小】
#include <STC12C5A.H>
uchar index;
uchar a,b,c; //定义三个变量、。
uchar m;         //
uint teempr;       //
uint  z,i;
//*********************************************★下面是PWM调制的数组★********************************************************
//220- zhan0.02  214--0.04  209-0.07 203-0.11  195- 0.15  185-0.25  173-0.31 160-0.38  145-0.45 129-0.48 111-0.48   42OFF
//0.74 .81  .91 1.03   1.22   1.45  1.69   2.28   2.62     0.74   0.81   0.90    1.03   右大
// 热敏电阻受热以后阻值变小。受凉以后阻值变大。
uchar code pwm[]={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,
39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,
80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,
116,117,118,119,120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,144,145,146,
147,148,149,150,151,152,153,154,155,156,157,158,159,160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,176,177,
178,179,180,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199,200,201,202,203,204,205,206,207,208,
209,210,211,212,213,214,215,216,217,218,219,220,221,222,223,224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239,
240,241,242,243,244,245,246,247,248,249,250,251,252,253,254};
//3525 2脚电压高输出占空比也大,2脚电压越低那么占空比也就越小。  6脚电压拉低的话频率就升高,6脚电压高频率就降低。
//************************************************ 下面的是DISP显示数组***************************************************
uchar code table100[]={"※※※※※※※※"};
uchar code table101[]={"  www.51hei.com "};
uchar code table1[]={"★当前档位一★"};
uchar code table2[]={"★当前档位二★"};
uchar code table3[]={"★当前档位03★"};
uchar code table4[]={"★当前档位四★"};
uchar code table5[]={"★当前档位五★"};
uchar code table6[]={"★当前档位六★"};
uchar code table7[]={"★当前档位七★"};
uchar code table8[]={"★当前档位八★"};
uchar code table9[]={"★当前档位九★"};
uchar code table10[]={"★当前档位十★"};
uchar code table11[]={"测试版本:V1.1"};
uchar code table12[]={"zhinengjiqi.com"};
uchar code table13[]={"欢迎使用智能机器"};
uchar code table14[]={"GSM:18663523202"};
uchar code table15[]={"警告电压过高保护"};
uchar code table16[]={"警告检测短路故障"};
uchar code table17[]={"警告长时间没放锅"};
uchar code table18[]={"警告线盘温度过高"};
uchar code table19[]={"警告散热器温度高"};
uchar code table20[]={"警告风扇发生故障"};
uchar code table21[]={"警告环境湿度过高"};
uchar code table22[]={"机器锁定咨询客服"};
uchar code table23[]={"警告电源线未接好"};
uchar code table24[]={"Θ开机软启动中Θ"};
uchar code table25[]={"请稍候¨¨"};
//*************************************************按键定义***********************************************************
sbit pd =   P0^4    ;  //占空比升高
sbit px =   P0^5    ;  //占空比降低
sbit zd =   P0^6    ;  //频率增加
sbit zx =   P0^7    ;  // 频率减小
//**************************************************按键定义到此结束。******************************************************
sbit rs=P0^0; //数据,命令选择端
sbit rw=P0^1; //读写选择
sbit beiguang=P0^3;//LED背光
sbit e=P0^2; //使能端
sbit baohu=P5^3; //PWM保护关闭。
//***************************************************  液晶pin定义结束。***************************************************
sbit DQ=P3^4;   //温度探头数据口。
sbit yurest=P4^4; //语音复位
sbit yushuju=P4^1; //语音数据
sbit yuzhuangtai=P4^5; //语音状态
//***************************************************语音pin定义到此结束*****************************************************
//**************************************************** 各种延时子函数*******************************************************
void yanshi(uint xms)//延时多久需要计算。
   uint x ,y;
    for(x=xms;x>0;x--)
   for(y=110;y>0;y--);
void delay_1ms(uint z)   //延时一毫秒的指令。核对过时间很准确
uint x,y;
for(x=z;x>0;x--)
for(y=1800;y>0;y--);
void delay_50us(uint t)  //延时50微秒的指令。核对过时间很准确
uint j;
for(;t>0;t--)
for(j=91;j>0;j--);
//************************************************以下是12864显示的子函数*****************   ******************************
void write_12864_com(uchar com) //写命令子函数
 rs=0; //数据命令选择端口。=1写数据,=0写命令 。
 P2=com;//把数据送到P2口传递给液晶。
 e=1;//使能端高电平。
 delay_50us(10); //延时一小会保证使能的高电平宽度达到要求、
 e=0;//完成使能信号的脉冲要求给置零。
 delay_50us(2);
void write_12864_dat(uchar dat) //写数据子函数
 rs=1; //数据命令选择端口。=1写数据,=0写命令 。
 rw=0; //读写
 delay_50us(1);
 P2=dat;//把数据送到P2口传递给液晶。
 e=1;//使能端高电平。 delay_50us(10); //延时一小会保证使能的高电平宽度达到要求、
 delay_50us(2);
void init_12864()  //液晶初始化子函数。
     delay_1ms(100);
  write_12864_com(0x30); //基本指令操作); //
      delay_50us(4);
  write_12864_com(0x0c);
  write_12864_com(0x06);
  delay_50us(10);
//***************************************************以下是各个档位的画面***********************************************
void dispdangwei(uint f)     //*****************************f是多少就是几档画面*************************************************
     init_12864();//初始化液晶。
  write_12864_com(0x80);//设定显示位置是第一行。
  for(i=0;i<16;i++)    //第一行有多少字,汉字占两个位置。标点符号一个。
  write_12864_dat(table101[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。
  delay_50us(1);          //延时一会保证数据有发送完毕。
  write_12864_com(0x90); //设定第二行。
  for(i=0;i<16;i++)
  {dat(table100[i]);;
  write_12864_com(0x88); //设定第三行
  for(i=0;i<14;i++)
   switch(f)
     case 1:
     write_12864_dat(table1[i]);
     break;
     case 2:
     write_12864_dat(table2[i]);
     break;
     case 3:
     write_12864_dat(table3[i]);
     break;
     case 4:
     write_12864_dat(table4[i]);
     break;
     case 5:
     write_12864_dat(table5[i]);
     break;
     break;
     case 7:
     write_12864_dat(table7[i]);
     break;
     case 8:
     write_12864_dat(table8[i]);
     break;
     case 9:
     write_12864_dat(table9[i]);
     break;
     case 10:
     write_12864_dat(table10[i]);
     break;
   delay_50us(1);行显示位置。
  for(i=0;i<16;i++)
   write_12864_dat(table100[i]);
   delay_50us(1);
//***********************************************下面是语音参数设定******************************************************
void yufuwei() //语音复位子程序。
 yurest=0;//这句是防止REST不是低电平。保险起见给他拉低。
 yurest=0; //到这里语音就复位结束。
void yuyin(z) //语音的播放程序。Z等于几就播放第几段。(语音参数内部调用,主程序不用。)
  yufuwei();  //清除以前的播放数据进行复位。防止和前次的播放数据相加播放错误、
    while(z>0)
     yushuju=0;
void dangweitouyin() // 语音:档位。 用来给档位语音添加头音。
   yufuwei();  //语音复位子函数。目的是在播放这段之前停止正在播放的。、一小会。
   yuyin(11);  //指定播放语音IC中的第11段语音。
void jinggao() //报警用的音乐文件。 用来给各种告警添加头音。只是警告语音的前头那段音乐。位子函数。目的是在播放这段之前停止正在播放的。、
 机速度太快了延一小会。
   yuyin(23);  //指定播放语音IC中的第11段语音。
void baojing(uint o) // 各种报警的子函数里面的O等于几就是对应的报警。
   jinggao();   //这里是警告的头音音乐文件。
   delay_1ms(2000);//延时2秒想起来警告头音。
   yuyin(o); //警告的内容。
void jinggaoduanlu()  //短路保护警告音。
   baojing(18);//播放第18条报警语音。内容是:短路保护.
void jinggaofengshanguzhang()
   baojing(19);//播放第19条报警语音。内容是:警告风扇故障。
void jinggaoguoyabaohu()
   baojing(21);//播放第12条报警语音。内容是:电源线未接好,请检查。
void jinggaoguowenbaohu()
   baojing(20);//播放第20条报警语音。内容是:警告过压保护。
 void dianyuanxianweijiehao()
   baojing(12);//播放第12条报警语音。内容是:电源线未接好,请检查。
 void jinggaomima()
   baojing(22);//播放第22条报警语音。内容是:请咨询客服输入密码。
void jinggao1() //报警用的音乐文件。 用来给各种告警添加头音。只是警告语音的前头那段音乐。
   delay_50us(1);//单片机速度太快了延一小会。
   yuyin(26);  //指定播放语音IC中的第11段语音。
void music(uint j)   //带参数的子函数,里面的J等于几就是播放 第几段语音。
  dangweitouyin();//档位头音。
    if(yuzhuangtai==0) //检测是不是语音头文件在播放。如果播放就让程序进入里面等一会让头文件播放结束。
  while(!yzhuangtai);//如果检测到语音状态发生了改变那么就跳出来这个死循环。否则就在这原地打转等待。
    if(yuzhuagtai==1) //检测是不是语音头文件播放结束了。如果结束了那么开始播放本段语音。
     if(j==10)   //因为语音的十不是在语音的第十段,那就利用这么两个if语句进行判断是不是档位数据送来10.
      yuyin(28);  //如果来的数据是10,那么就进入把语音的子函数参数修改成 28执行档位十的语音。
     if(j!=10) //又为了避免在档位十的时候送完28的语音参数再过来送10的错误数据,所以在送来不是10的时候才执行1-9数据
          yuyin(j); //播放语音的第K段。~~~~~~~~~~~~~~~内容是:j ~~~~~~~~~~~~~~~~~
//***********************************下面是1-10档位的子函数调用了显示画面和语音*****************************************
void dangwei(uint k) // 档位1-10的子函数。
   switch(k)
 case 1:  //档位1.
 a=25;//火力的占空比是25.
 break;
    case 2:  //档位2.
 a=50;//火力的占空比是50.
 break;
 case 3:  //档位3
 a=75;//火力的占空比是75.
 break;
 case 4:  //档位4
 a=100;//火力的占空比是25.
 break;
 case 5:  //档位5
 a=125;//火力的占空比是25.
 break;
 case 6:  //档位6
 a=25;//火力的占空比是25.
 break;
 case 7:  //档位7
 a=25;//火力的占空比是25.
 break;
 case 8: //档位8
 a=25;//火力的占空比是25.
 break;
 case 9:
 a=25;//火力的占空比是25.
 break;
 case 10:
 a=25;//火力的占空比是25.
 break;
 dispdangwei(k);//档位K的画面
 music(k);//档位K的语音。
//******************************************到这里档位定义信息完毕!!*****************************************************
//****************************************************下面是PCA计数器初始化************************************************
void init_pca(void)//pca计数器初始化函数
CMOD=0x00;
CCON=0x00;
CCAP0=0X2; //8位PWM输出,无中断。PWM0
CCAP1=0x2;//8位PWM输出,无中断 。PWM1
CL=0x00;//清零pca计数器
CH=0x00;
CCA1L=pm[0];    //初始化PWM1输出的占空比
CCA1H=pw[0];
CCA0L=pm[0];    //初始化PWM0输出的占空比
CCA0H=pm[0];
CR=1;//运行pca计数器
void huanying()
     yuyin(30);//语音的欢迎语。
  write_12864_at(table100[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。
  for(i=0;i<16;i++)
   write_1284_dat(table24[i]);
   delay_50us(1;
  for(i=0;i<10i++)
   write_12864_dat(table25[i]);
   delay_50us(1);
   write_12864_com(0x98);//设定第四行显示位置。
  for(i=0;i<16;i++)
   write_12864dat(table100[i]);
   delay_50us(1);
//##################################第二幅画面。
     delay_1s(2000);//延时保持2秒钟的第一幅画面。
  for(i=0;i<14;i++)    //第一行有多少字,汉字占两个位置。标点符号一个。
  write_12864_dat(table11[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。
  for(i=0;i<16;i++)
   write_12864_dat(table13[i]);
   delay_50us(1);
  write12864_com(0x88); //设定第三行
  for(i=0;i<16;i++)
   write_12864_dat(table12[i]);
   delay_50us(1);
  for(i=0;i<16;i++)
   write_12864_dat(table14[i]);
   delay_50us(1);
P4SW=0x7F; //设置P4为双向IO口。
c=0;//写入未执行过按键操作的标志位
baohu=1;//先强制打开保护功能,促使PWN彻底关闭,防止上机的那种不可控的频率。让PWM有规律可循。
beiguang=1;//打开背光
yanshi(30);//延时一小会保证已经彻底关闭。
init_pa();//初始化PWM控制器。
m=0;
temp=0;
init_1864();//初始化液晶。
huanying();//开机欢迎语和欢迎画面。
     if(pd==0)  //档位加
        yanshi(50);
      if(pd==0)
         m++  //检测火力+按键按了几次。是几次就是几档位、
      if(m==11) //当档位增加到11次以后,就给复位到档位1.防止出现错误。
         m=1;
         dangwei(m); //档位的各种信息。
       while(!pd);
   if(px==0) //档位减
        yanshi(50);
      if(px==0)
         if(m==0)
         m=2;
          m--;  //检测火力-按键按了几次。是几次就是几档位、
      if(m<=0)//当档位增加到0次以后,就关闭所有档位的输出。
         m=1;
       while(!p);
      if(zd==0)
        yanshi(10);
      if(zd==0)
          b--;
       if(b<=0)
         b=56;
         c=1;
       while(!zd);
  if(zx==0)
        yanshi(10);
      if(zx==0)
          b++;
       if(b>=56)
         b=0;
       while(!zx);
CCAP1L=pwm[a];    //初始化PWM1输出的占空比
CCAP1H=pwm[a];
CCAP0L=pw[b];    //初始化PWM0输出的占空比
CCAP0H=pm[b];
if(c>=1)//检测是不是已经稳定好了PWM。
   baohu=0;//开启PWM输出。
【关闭窗口】
相关文章
