专注电子技术学习与研究
矩阵键盘扫描
作者:佚名   来源:本站原创   点击数:…  更新时间:2012年11月28日   【字体:大 中 小】
#include"type.h"
BETY_BIT status;
//code P_scanf_data_led_7[10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
code N_scanf_data_led_7[16] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
unsigned char scanf_data[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d};//显存
void Delay_ms(unsigned char z)//延时程序1ms
  unsigned char x;
  while(--z)
    x= 10;
    while(--x);
void Scanf_Display(unsigned char *dat)
   unsigned char x;
   for(x=0;x<6;x++)
    PORT_DATA=dat[x];
          PORT_SCANF=~(0x01<<x);
    Delay_ms(50);
    PORT_DATA=0;
          Delay_ms(10);
       矩阵键盘扫描部分
char proces_data(unsigned char num)
  switch(num)
   case 1:num=1; break;
   case 2:num=2; break;
   case 4:num=3; break;
   case 8:num=4; break;
   default:num=0;   break;
   return num;
unsigned char Scanf_Key(void)
   unsigned char H=0,L=0,port_temp,key_value;
   KEY_COM=0xf0;
   KEY_DOWN = 0;
   key_value = 0xff;
   if(KEY_COM!=0xf0)
     Delay_ms(100);
     if(KEY_COM!=0xf0)
       KEY_DOWN = 1;
       port_temp = KEY_COM;
    H=(~port_temp)>>4;
    KEY_COM=0x0f;
       Delay_ms(10);
    L=(~port_temp)&0x0f;
    key_value=((proces_data(H)-1)<<2)+proces_data(L);
   return (key_value-1);
main()
unsigned char temp;
temp=Scanf_Key();
 if(KEY_DOWN)
 scanf_data[0]=N_scanf_data_led_7[temp];
 scanf_data[1]=N_scanf_data_led_7[temp];
 scanf_data[2]=N_scanf_data_led_7[temp];
 scanf_data[3]=N_scanf_data_led_7[temp];
 scanf_data[4]=N_scanf_data_led_7[temp];
 scanf_data[5]=N_scanf_data_led_7[temp];
 Scanf_Display(scanf_data);
【关闭窗口】
相关文章
