专注电子技术学习与研究
通过I2C芯片EEPRON24C02控制P1口
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年07月14日   【字体:大 中 小】
通过芯片AT24C02控制P1口。程序:
#include<reg52.h>
sbit sda=P2^1;
sbit scl=P2^0;
void delay1()
void delay()
 int x,y;
 for(x=0;x<5;x++)
 for(y=0;y<120;y++);
void start()
{ sda=1;
 delay1();
 scl=1;
 delay1();
 sda=0;
 delay1();
void stop()
 sda=0;
 delay1();
 scl=1;
 delay1();
 sda=1;
 delay1();
void respons()
 sda=0;
 delay1();
 scl=1;
 delay1();
 scl=0;
 delay1();
void init()
 sda=1;
 scl=1;
void write_byte(unsigned char date)
 unsigned char temp,i;
 temp=date;
 scl=0;
 delay1();
 for(i=0;i<8;i++)
 temp=temp<<1;
 sda=CY;
 delay1();
 scl=1;
 delay1();
 scl=0;
 delay1();
 sda=1;
 delay1();
unsigned char read_byte()
 unsigned char i,j,k;
 scl=0;
 delay1();
 sda=1;
 delay1();
 for(i=0;i<8;i++)
  scl=1;
  delay1();
  j=sda;
  k=(k<<1)|j;
  scl=0;
  delay1();
 return k;
void write_add(unsigned char addres,unsigned char date)
  start();
 write_byte(0xae);
 respons();
 write_byte(addres);
 respons();
 write_byte(date);
 respons();
 stop();
unsigned char read_add(unsigned char address)
{ unsigned char date;
  start();
 write_byte(0xae);
 respons();
 write_byte(address);
 respons();
 start();
 write_byte(0xaf);
 respons();
 date=read_byte();
 stop();
 return date;
 init();
 write_add(3,0x55);
 delay();
 P1=read_add(3);
 while(1);
【关闭窗口】
相关文章
