专注电子技术学习与研究
国歌音乐、交通红绿灯的VHDL程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年11月08日   【字体:大 中 小】
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY GUOGE IS
 PORT(CLK,rst:in std_logic;
         out_bit:OUT STD_LOGIC);
END GUOGE;
ARCHITECTURE PVJ OF GUOGE IS
  SIGNAL time:STD_LOGIC_VECTOR(24 DOWNTO 0);
  signal music21:STD_LOGIC_VECTOR(8 DOWNTO 0);
  SIGNAL L5,L6,L7,M1,M2,M3,M4,M5,M6:STD_LOGIC_VECTOR(16 DOWNTO 0);
  SIGNAL LL5,LL6,LL7,C,MM1,MM2,MM3,MM4,MM5,MM6,X0:STD_LOGIC;
     BEGIN
      process(clk,rst)
        begin
        X0<='1';
        if clk'event and clk='1' then time<=time+1;                 --将20M频率6分频
                 if L5=12755  then L5<="00000000000000000";LL5<=not LL5;
                    else    L5<=L5+1;
                 end if;
                 if L6=11363  then L6<="00000000000000000";LL6<=not LL6;
                    else    L6<=L6+1;
                 end if;
                 if L7=10124  then L7<="00000000000000000";LL7<=not LL7;
                    else    L7<=L7+1;
                 end if;
                 if M1=9555  then M1<="00000000000000000";MM1<=not MM1;
                    else   M1<=M1+1;
                 end if;
                 if M2=8513  then M2<="00000000000000000";MM2<=not MM2;
                    else    M2<=M2+1;
                 end if;
                 if M3=7584  then M3<="00000000000000000";MM3<=not MM3;
                    else    M3<=M3+1;
                 end if;
                 if M5=6377  then M5<="00000000000000000";MM5<=not MM5;
                    else   M5<=M5+1;
                 end if;
                 if M6=5681  then M6<="00000000000000000";MM6<=not MM6;
                    else    M6<=M6+1;
                 end if;
                 if time=2499999 then time<="0000000000000000000000000";c<='1';
                 else c<='0';
                 end if;
           end if;
        end process;
   PROCESS(c,RST)
       BEGIN
        if c'event and c='1' then music21<=music21+1;
              if music21=255 then music21<="000000000";
              end if;
        end if;
        if music21>=0 and music21<=1 then out_bit<=LL5;END IF;--低音5    起
        if music21>=2 and music21<=7 then out_bit<=MM1;END IF;--中音1    来
        if music21>=8 and music21<=9 then out_bit<=MM1;END IF;--中音1    不
        if music21>=10 and music21<=13 then out_bit<=MM1;END IF;--中音1  愿做
        if music21>=14 and music21<=15 then out_bit<=LL5;END IF;--低音5  奴
        if music21=16 then out_bit<=LL6;END IF;                --低音6   隶
        if music21=17 then out_bit<=LL7;END IF;                --低音7   的
        if music21>=18 and music21<=25 then out_bit<=MM1;END IF;--中音1  人们
        if music21>=26 and music21<=27 then out_bit<=X0;END IF;--休止符
        if music21>=28 and music21<=29 then out_bit<=MM3;END IF;--中音3  把
        if music21>=30 and music21<=31 then out_bit<=MM1;END IF;--中音1  我
        if music21=32 then out_bit<=MM2;END IF;                 --中音2  们
        if music21=33 then out_bit<=MM3;END IF;                 --中音3  的
        if music21>=34 and music21<=41 then out_bit<=MM5;END IF;--中音5  血肉
        if music21>=42 and music21<=45 then out_bit<=MM3;END IF;--中音3  筑成
        if music21>=46 and music21<=47 then out_bit<=MM1;END IF;--中音1  我
        if music21=48 then out_bit<=MM3;END IF;                 --中音3  们
        if music21>=49 and music21<=51 then out_bit<=MM5;END IF;--中音5  新
        if music21=52 then out_bit<=MM3;END IF;                 --中音3  的
        if music21>=53 and music21<=56 then out_bit<=MM2;END IF;--中音2  长
        if music21>=57 and music21<=64 then out_bit<=MM2;END IF;--中音2  城
        if music21>=65 and music21<=68 then out_bit<=MM6;END IF;--中音6  中
        if music21>=69 and music21<=72 then out_bit<=MM5;END IF;--中音5  华
        if music21>=73 and music21<=76 then out_bit<=MM2;END IF;--中音2  民
        if music21>=77 and music21<=80 then out_bit<=MM3;END IF;--中音3  族
        if music21>=81 and music21<=82 then out_bit<=MM5;END IF;--中音5  到
        if music21>=83 and music21<=86 then out_bit<=MM3;END IF;--中音3  了
        if music21>=87 and music21<=88 then out_bit<=MM5;END IF;--中音5  最
        if music21>=89 and music21<=90 then out_bit<=MM3;END IF;--中音3  危
        if music21=91 then out_bit<=MM2;END IF;                 --中音2  险
        if music21=92 then out_bit<=MM3;END IF;                 --中音3  的
        if music21>=93 and music21<=94 then out_bit<=MM1;END IF;--中音1  时
        if music21=95 then out_bit<=MM2;END IF;                 --中音2
        if music21>=96 and music21<=99 then out_bit<=MM3;END IF;--中音3    候
        if music21>=100 and music21<=103 then out_bit<=X0;END IF; --休止符
        if music21>=104 and music21<=106 then out_bit<=MM5;END IF;--中音5  每
        if music21=107  then out_bit<=MM6;END IF;                 --低音6  个
        if music21>=108 and music21<=111 then out_bit<=MM1;END IF;--中音1 人被
        if music21>=112 and music21<=115 then out_bit<=MM3;END IF;--中音3 迫着
        if music21>=116 and music21<=119 then out_bit<=MM5;END IF;--中音5 发出
        if music21>=120 and music21<=123 then out_bit<=MM2;END IF;--中音2 最后的
        if music21>=124 and music21<=127 then out_bit<=LL6;END IF;--低音6 吼
        if music21>=128 and music21<=133 then out_bit<=MM2;END IF;--中音2 声
        if music21>=134 and music21<=135 then out_bit<=LL5;END IF;--低音5 起
        if music21>=136 and music21<=143 then out_bit<=MM1;END IF;--中音1 来!起
        if music21>=144 and music21<=151 then out_bit<=MM3;END IF;--中音3 来!起
        if music21>=152 and music21<=167 then out_bit<=MM5;END IF; --中音5 来!
        if music21>=168 and music21<=170 then out_bit<=MM1;END IF; --中音1 我
        if music21=171 then out_bit<=MM3;END IF;                   --中音3 们
        if music21>=172 and music21<=175 then out_bit<=MM5;END IF; --中音5  万众
        if music21>=176 and music21<=179 then out_bit<=MM6;END IF; --中音6   一
        if music21>=180 and music21<=183 then out_bit<=MM5;END IF;--中音5    心
        if music21>=184 and music21<=186 then out_bit<=MM3;END IF;--中音3  冒
        if music21=187 then out_bit<=MM1;END IF;                  --中音1  着
        if music21>=188 and music21<=191 then out_bit<=MM5;END IF;--中音5  敌人的
        if music21>=192 and music21<=193 then out_bit<=MM3;END IF;----中音3 炮
        if music21>=194 and music21<=195 then out_bit<=X0;END IF;
        if music21>=196 and music21<=197 then out_bit<=MM1;END IF;--中音1  火
        if music21>=198 and music21<=199 then out_bit<=X0;END IF;
        if music21>=200 and music21<=203 then out_bit<=LL5;END IF;--低音5  前
        if music21>=204 and music21<=207 then out_bit<=MM1;END IF;--中音1  进
        if music21>=208 and music21<=210 then out_bit<=MM3;END IF;--低音3  冒
        if music21=211 then out_bit<=MM1;END IF;                 --中音1   着
        if music21>=212 and music21<=215 then out_bit<=MM5;END IF;--中音5 敌人的
        if music21>=216 and music21<=217 then out_bit<=MM3;END IF;--中音3 炮
        if music21>=218 and music21<=219 then out_bit<=X0;END IF;
        if music21>=220 and music21<=221 then out_bit<=MM1;END IF;--中音1 火
        if music21>=222 and music21<=223 then out_bit<=X0;END IF;
        if music21>=224 and music21<=227 then out_bit<=LL5;END IF;--中音5    前
        if music21>=228 and music21<=231 then out_bit<=MM1;END IF;--中音1    进
        if music21>=232 and music21<=235 then out_bit<=LL5;END IF;--中音5    前
        if music21>=236 and music21<=239 then out_bit<=MM1;END IF;--中音1    进
        if music21>=240 and music21<=243 then out_bit<=LL5;END IF;--中音5    前
        if music21>=244 and music21<=247 then out_bit<=MM1;END IF;--中音1    进
        if music21>=248 and music21<=251 then out_bit<=MM1;END IF;--中音1    进
        if music21>=252 and music21<=255 then out_bit<=X0;END IF;
IF RST='0' THEN MUSIC21<="000000000";END IF;
    END PROCESS;
end;
交通信号灯程序:
十字路口的红绿黄除以红绿黄三色灯显示通行信号外,现在还增加了以红黄绿三色数字显示等待和持续的时间。以下程序经调试即可实现既有三色灯,又有三色数字显示的红绿灯交通信号。
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_LOGIC_unsigned.all;
entity JTRGY is
 port( clk,T:in std_logic;
       EWR,EWG,EWY,SNR,SNG,SNY:OUT STD_LOGIC;
       XS:OUT STD_LOGIC_VECTOR(6 DOWNTO 0);
       EWRR0,EWGG0,EWYY0,SNRR0,SNGG0,SNYY0:OUT STD_LOGIC;
       EWRR1,EWGG1,EWYY1,SNRR1,SNGG1,SNYY1:OUT STD_LOGIC);
END JTRGY;
ARCHITECTURE JT OF JTRGY IS
SIGNAL DISPLAY,Q0,Q1:STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL QQ:STD_LOGIC_VECTOR(5 DOWNTO 0);
SIGNAL C,EWRR,EWGG,EWYY,SNRR,SNGG,SNYY:STD_LOGIC;
SIGNAL XSJS:STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL TIME0:STD_LOGIC_VECTOR(24 DOWNTO 0);
BEGIN
  PROCESS(CLK,T)
    BEGIN
      IF CLK'EVENT AND CLK='1' THEN TIME0<=TIME0+1;XSJS<=XSJS+1;
           IF TIME0=9999999 THEN TIME0<="0000000000000000000000000";C<=NOT C;
           END IF;
      END IF;
----------------以下26秒计时---------------------------------
     IF C'EVENT AND C='1' THEN Q0<=Q0-1;QQ<=QQ+1;
                IF Q0=0 THEN Q0<="1001";Q1<=Q1-1;
                END IF;
                IF Q0=0 AND Q1=0 THEN Q0<="0101";Q1<="0010";
                END IF;
--------------------以下52秒计时-----------------
                IF QQ=51 THEN QQ<="000000";
                END IF;
     END IF;
--------------------------以下红绿灯控制南北方向-------------------------------
   IF QQ>=1 AND QQ<=26 THEN SNR<='1';SNG<='0';SNY<='0';SNRR<='0';ELSE SNRR<='1';END IF;
   IF QQ>=27 AND QQ<=47 THEN SNR<='0';SNG<='1';SNY<='0';SNGG<='0';else SNGG<='1';END IF;
   IF (QQ>=48 AND QQ<=51)or(QQ=0) THEN SNR<='0';SNG<='0';SNY<='1';SNYY<='0';
       ELSE SNYY<='1';END IF;
--------------------------以下红绿灯控制东西方向---------------------------
   IF QQ>=1 AND QQ<=21 THEN EWR<='0';EWG<='1';EWY<='0';EWGG<='0';ELSE EWGG<='1';END IF;
   IF QQ>=22 AND QQ<=26 THEN EWR<='0';EWG<='0';EWY<='1';EWYY<='0';ELSE EWYY<='1';END IF;
        IF (QQ>=27 AND QQ<=51)OR(QQ=0) THEN EWR<='1';EWG<='0';EWY<='0';EWRR<='0';
      ELSE EWRR<='1';END IF;
---------------------以下紧急情况双向显示红灯----------------------------------
IF T='0' THEN
 EWRR0<='0';EWGG0<='1';EWYY0<='1';SNRR0<='0';SNGG0<='1';SNYY0<='1';
 EWRR1<='0';EWGG1<='1';EWYY1<='1';SNRR1<='0';SNGG1<='1';SNYY1<='1';
------------------南北方向红黄绿灯--------------------------------
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;SNRR0<=('0' OR SNRR);
   ELSE SNRR0<=('1' OR SNRR);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;SNRR1<=('0' OR SNRR);
   ELSE SNRR1<=('1' OR SNRR);
 END IF;
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;SNGG0<=('0' OR SNGG);
   ELSE SNGG0<=('1' OR SNGG);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;SNGG1<=('0' OR SNGG);
   ELSE SNGG1<=('1' OR SNGG);
 END IF;
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;SNYY0<=('0' OR SNYY);
   ELSE SNYY0<=('1' OR SNYY);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;SNYY1<=('0' OR SNYY);
   ELSE SNYY1<=('1' OR SNYY);
 END IF;
---------------东西方向红黄绿灯--------------------------------
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;EWRR0<=('0' OR EWRR);
   ELSE EWRR0<=('1' OR EWRR);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;EWRR1<=('0' OR EWRR);
   ELSE EWRR1<=('1' OR EWRR);
 END IF;
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;EWGG0<=('0' OR EWGG);
   ELSE EWGG0<=('1' OR EWGG);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;EWGG1<=('0' OR EWGG);
   ELSE EWGG1<=('1' OR EWGG);
 END IF;
 IF XSJS>=0 AND XSJS<127 THEN DISPLAY<=Q0;EWYY0<=('0' OR EWYY);
   ELSE EWYY0<=('1' OR EWYY);
 END IF;
 IF XSJS>127 AND XSJS<255 THEN DISPLAY<=Q1;EWYY1<=('0' OR EWYY);
   ELSE EWYY1<=('1' OR EWYY);
 END IF;
end if;
  CASE DISPLAY IS
     WHEN "0000"=>XS<="0000001";
     WHEN "0001"=>XS<="1001111";
     WHEN "0010"=>XS<="0010010";
     WHEN "0011"=>XS<="0000110";
     WHEN "0100"=>XS<="1001100";
     WHEN "0101"=>XS<="0100100";
     WHEN "0110"=>XS<="0100000";
     WHEN "0111"=>XS<="0001111";
     WHEN "1000"=>XS<="0000000";
     WHEN "1001"=>XS<="0000100";
     WHEN OTHERS=>XS<="0000001";
END CASE;
END PROCESS;
END;
【关闭窗口】
相关文章
