专注电子技术学习与研究
NRF9E51读IC卡卡号,并把读取到的数据传送出去
作者:huqin   来源:本站原创   点击数:…  更新时间:2013年11月15日   【字体:大 中 小】
发送时间间隔是1.2秒
指示灯:接收灯上电后变红,收到数据后变绿,在3秒内未接收到数据则变红
        发送灯上电后变红,发送数据变绿
// Comment out the following line for nRF24E1
//#define NRF9E5 1
//卡号是916d47
#ifdef NRF9E5
#include <Nordic\reg9e5.h>
#define POWER      3                // 0=min power...3 = max power
#define HFREQ      1                // 0=433MHz, 1=868/915MHz
#define CHANNEL  351                // Channel number: f(MHz) = (422.4+CHANNEL/10)*(1+HFREQ)
#else
#include <reg24e1.h>
//#include<absacc.h>
//#include<stdlib.h>
#include<intrins.h>
//#include<stdio.h>
//#include<math.h>
#endif
#define nop()   _nop_()
sbit LED=P0^5;
sbit data0=P0^4;
sbit data1=P0^3;
sbit fsen=P1^0;
//static volatile uchar timer;
static volatile uchar t0lrel, t0hrel;
static volatile uchar t1lrel, t1hrel;
uchar a[3];
uchar ou_check=0;
uchar ji_check=0;
uchar count=0;
uchar count1=0;
uint count0=0;
bit over_flag=0;
bit over1_flag=0;
//bit over2_flag=0;
uchar code array[3]={0x91,0x6d,0x47};
#ifndef NRF9E5
struct RFConfig
    unsigned char n;
    unsigned char buf[15];
typedef struct RFConfig RFConfig;
#define ADDR_INDEX  8               // Index to address bytes in RFConfig.buf
#define ADDR_COUNT  4               // Number of address bytes
//暂时3个字节卡号无卡号的校验和
const RFConfig tconf =
    15,
    0x18,                           // Payload size transmitter Rx #2 (not used in this example)
    0x18,                           // Payload size transmitter Rx #1 (not used in this example)
    0x00, 0x00, 0x00, 0x00, 0x00,   // Address of transmitter Rx #2 (not used in this example)
    0x00, 0x12, 0x34, 0x56, 0x78,   // Address of transmitter Rx #1 (not used in this example)
    0x81, 0x6f, 0x04
const RFConfig rconf =
    15,
    0x18,                           // Payload size receiver Rx #2 (not used in this example)
    0x18,                           // Payload size receiver Rx #1
    0x00, 0x00, 0x00, 0x00, 0x00,   // Address receiver Rx #2 (not used in this example)
    0x00, 0x12, 0x34, 0x56, 0x78,   // Address receiver Rx #1 (four lower bytes used here)
    0x81, 0x6f, 0x05
#endif
void Delay100us(volatile unsigned char n)
    unsigned char i;
    while(n--)
        for(i=0;i<35;i++)
void fs()
{   uchar i;
    uchar j;
    uchar k;
    uchar ou_check=0;
    uchar ji_check=0;
    for(i=0;i<8;i++)
    ou_check+=((a[0]>>i)&0x01);
    for(i=4;i<8;i++)
    ou_check+=((a[1]>>i)&0x01);
    if(ou_check&0x01)
    ou_check=1;
    ou_check=0;
    for(i=0;i<4;i++)
    ji_check+=((a[1]>>i)&0x01);
    for(i=0;i<8;i++)
    ji_check+=((a[2]>>i)&0x01);
    if(ji_check&0x01)
    ji_check=0;
    ji_check=1;
    if(ou_check)                          //1的个数是奇数
    {   data1=0;
        count1=0;
        over1_flag=0;
        TR2=1;
        while(!over1_flag)
        {   nop();
        //Delay100us(1);
        //data1=1;
        //Delay100us(10);
    {   data0=0;
        count1=0;
        over1_flag=0;
        TR2=1;
        while(!over1_flag)
        {   nop();
        //Delay100us(1);
        //data0=1;
        //Delay100us(10);
    for(i=0;i<3;i++)
    {   for(j=8;j>0;j--)
        {    k=j-1;
             k=(a[i]>>k)&0x01;
             if(k)
             {  data1=0;
                over1_flag=0;
                count1=0;
                TR2=1;
                while(!over1_flag)
                //Delay100us(1);
                //data1=1;
                //Delay100us(10);
             {  data0=0;
                count1=0;
                over1_flag=0;
                TR2=1;
                while(!over1_flag)
        //  Delay100us(1);
                //data0=1;
            //Delay100us(10);
    if(ji_check)                  //1的个数是偶数
        data1=0;
        count1=0;
        over1_flag=0;
        TR2=1;
        while(!over1_flag)
        //Delay100us(1);
    //  data1=1;
        //Delay100us(10);
    {   data0=0;
        count1=0;
        over1_flag=0;
        TR2=1;
        while(!over1_flag)
        //Delay100us(1);
        //data0=1;
        //Delay100us(10);
/*void rst_wdog()
{   if((REGX_CTRL&0x10)!=0x10)
    {   REGX_MSB=0x75;
        REGX_LSB=0x30;
    //  REGX_CTRL=0x08;
unsigned char SpiReadWrite(unsigned char b)
    EXIF &= ~0x20;                  // Clear SPI interrupt
    SPI_DATA = b;                   // Move byte to send to SPI data register
    while((EXIF & 0x20) == 0x00)    // Wait until SPI hs finished transmitting
    return SPI_DATA;
void TransmitPacket()
    unsigned char i;
    CE = 1;
    Delay100us(0);
    // All packets start with the receiver address:
    for(i=0;i<ADDR_COUNT;i++)
        SpiReadWrite(tconf.buf[ADDR_INDEX+i]);
    SpiReadWrite(array[0]);
    SpiReadWrite(array[1]);
    SpiReadWrite(array[2]);
    CE = 0;
    Delay100us(3);                  // Wait ~300us
///led000000000000000000000000000000000000
/*定时器0和定时器1的定时间是10ms*/
void InitTimer(void)
    TR0 = 0;
    TMOD &= ~0x33;
    TMOD |= 0x11;                   // mode 1
    CKCON |= 0x98;                  // T0M = 1 (/4 timer clock)
    t0lrel = 0xC0;                  // 1KHz tick...
    t0hrel = 0x63;                  // ... = 65536-16e6/(4*1e3) = F060h
    TF0 = 0;                        // Clear any pending Timer0 interrupts
    ET0 = 1;                        // Enable Timer0 interrupt
    TR1=0;
    t1lrel=0xC0;
    t1hrel=0x63;
    TF1 = 0;                        // Clear any pending Timer0 interrupts
    ET1 = 1;
    T2CON=0x00;
    RCAP2H=0xFE;
    RCAP2L=0x70;
    ET2=1;
void Timer0ISR (void) interrupt 1
    TF0 = 0;                        // Clear Timer0 interrupt
    TH0 = t0hrel;                   // Reload Timer0 high byte
    TL0 = t0lrel;                   // Reload Timer0 low byte
    count0++;
    if (count0==300)
        LED=0;                 // Led off
        TR0 = 0;                    // Stop timer
void Timer1ISR(void) interrupt 3
    TF1 = 0;                        // Clear Timer1 interrupt
    TH1 = t1hrel;                   // Reload Timer1 high byte
    TL1 = t1lrel;                   // Reload Timer1 low byte
    count++;
    if (count == 120)
       count=0;
       over_flag=1;
       TR1=0;
void Timer2ISR (void) interrupt 5 using 2
    TF2 = 0;
    count1++;
    if (count1==1)
        data0=1;
        data1=1;
    else if(count1==11)
    {   count1=0;
        over1_flag=1;
        TR2=0;
void Receiver(void)
    unsigned char b;
    CS = 1;
    Delay100us(0);
    for(b=0;b<rconf.n;b++)           //写入配置
        SpiReadWrite(rconf.buf[b]);
    CS = 0;
    for(;;)
        CE = 1;
        while(DR1 == 0)
        {   //rst_wdog();
            nop();
        a[0]=SpiReadWrite(0);
        a[1]=SpiReadWrite(1);
        a[2]= SpiReadWrite(2);
        CE = 0;
        LED=1;
        count0=0;
        TR0 = 1;
        if(fsen==0)
            fs();
        //rst_wdog();
void Transmitter(void)
    unsigned char b;
    CS = 1;
    Delay100us(0);
    for(b=0;b<tconf.n;b++)
        SpiReadWrite(tconf.buf[b]);
    CS = 0;
    for(;;)
    {   //rst_wdog();
        TransmitPacket();        // Transmit data
        over_flag=0;
        TR1=1;
        LED=1;
        while(!over_flag)
        {   nop();
void Init(void)
{   uchar i;
    uchar j;
    P0_DIR=0x00;
    P0=0xfb;
    P1=0xff;
    SPICLK=1;
    SPI_CTRL=0x02;          //连接到RADIO上
    PWR_UP = 1;                     // Turn on Radio on 24E1
    Delay100us(30);                 // Wait > 3ms
    InitTimer();
    EA = 1;
    for(j=0;j<2;j++)
    {   LED=1;
        for(i=0;i<10;i++)
        {   Delay100us(250);
            Delay100us(250);
        LED=0;
        for(i=0;i<10;i++)
        {   Delay100us(250);
            Delay100us(250);
void main(void)
    Init();
   /*f((REGX_CTRL&0x10)!=0x10)
        REGX_MSB=0x75;
        REGX_LSB=0x30;
        REGX_CTRL=0x08;
    //Receiver();
    Transmitter();
【关闭窗口】
相关文章
