专注电子技术学习与研究
STM32 串口中断接收数据
作者:黄宾山   来源:本站原创   点击数:…  更新时间:2014年03月03日   【字体:大 中 小】
#include "stm32f10x.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void delay(vu32 nCount)
 for(; nCount != 0; nCount--);
main()
 RCC_Configuration();//系统时钟配置
 NVIC_Configuration();//中断配置
 GPIO_Configuration();//GPIO口配置
 while(1)          //LED灯循环亮灭,串口循环发送ASCII“9”
  delay(5000000);
  GPIO_WriteBit(GPIOD,GPIO_Pin_2,Bit_RESET);
  USART_SendData(USART1,'9');
     while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);
  delay(5000000);
  GPIO_WriteBit(GPIOD,GPIO_Pin_2,Bit_SET);
//系统时钟配置
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能串口1的GPIO时钟
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE); //pa.9 pa.10 led0
//串口GPIO口配置
 GPIO_InitTypeDef GPIO_InitStructure;
 USART_InitTypeDef USART_InitStructure;
 /* LED0*/
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
 GPIO_Init(GPIOD, &GPIO_InitStructure);
// GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     //复用推挽输出
 GPIO_Init(GPIOA, &GPIO_InitStructure);
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //悬浮输入
 USART_InitStructure.USART_BaudRate = 9600;      //设定波特率
 USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //传输数据位数
 USART_InitStructure.USART_StopBits = USART_StopBits_1;   //停止位1
 USART_InitStructure.USART_Parity = USART_Parity_No;    //不用校验位
 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和发送功能
 USART_Init(USART1, &USART_InitStructure);       //初始化串口1
 USART_Cmd(USART1,ENABLE);            //串口1使能
 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);     //使能串口1 读中断
//中断配置
 NVIC_InitTypeDef NVIC_InitStructure;
 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);     //先占优先权2,从优先级2位
 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;    //开串口中断1
 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;   //指定抢占优先级别1
 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;    //指定相应优先级别0
 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
 NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)       //串口接收中断,并将接收到得数据发送出
 u16 temp_trx;
 if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)//判断 是否 接收中断
  temp_trx = USART_ReceiveData(USART1);
  USART_SendData(USART1,temp_trx);
     while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);//判断 发送标志
【关闭窗口】
相关文章
