专注电子技术学习与研究
51单片机矩阵键盘检测源代码(按键数码管显示0-F)
作者:寒竹子   来源:本站原创   点击数:…  更新时间:2014年03月23日   【字体:大 中 小】
本程序所用的原理图下载: 点这里 ,单片机芯片使用的stc89c52;找到相应部分即可.这是一整个单片机开发板的电路图其他的忽略.
hex文件及其工程文件下载:http://www.51hei.com/f/juzhen.rar  以下是通过测试的源代码:
*功能:使用矩阵按键使得按键按下时数码管上显示各自对应的数字(0 ~ F);
*日期:2013-05-03-17:51;
*作者:徐冉
*特别说明:本程序代码已经通过调试,仅供学习使用;
/***********AT89C52-RC 单片机51hei 实验板***********/
/*****************51hei-开发板*********************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
sbit FM = P2^3;
uchar code table[] = {
    0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x00  //自定义
uchar key, temp;
void display(uchar num);
void Marix_keyscan();
void delay(uint xms);
 dula = 1;
 P0 = 0x00;
 dula = 0;
 wela = 1;
 P0 = 0xea;
 wela = 0;
  Marix_keyscan();
  display(key);
 dula = 1;
 P0 = table[num];
 dula = 0;
 uint i, j;
 for(i = xms; i > 0; i--)
   for(j = 125; j > 0; j--);
 P3 = 0xfe;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xee: key = 0;
    break;
    case 0xde: key = 1;
    break;
    case 0xbe: key = 2;
    break;
    case 0x7e: key = 3;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfd;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xed:key = 4;
    break;
    case 0xdd:key = 5;
    break;
    case 0xbd:key = 6;
    break;
    case 0x7d:key = 7;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfb;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
     case 0xeb: key = 8;
    break;
    case 0xdb: key = 9;
    break;
    case 0xbb: key = 10;
    break;
    case 0x7b: key = 11;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xf7;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xe7: key = 12;
    break;
       case 0xd7: key = 13;
    break;
    case 0xb7: key = 14;
    break;
    case 0x77: key = 15;
    break;
    default:
    break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(5);
      while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
【关闭窗口】
相关文章
