专注电子技术学习与研究
51单片机+ISD4002语音芯片读写源代码
作者:佚名   来源:本站原创   点击数:…  更新时间:2014年07月29日   【字体:大 中 小】
 #include <reg52.h>
sbit SS=P2^3; //使能控制端
sbit SCLK=P2^2;
sbit MOSI=P2^0;
sbit MISO=P2^1;
sbit LED=P1^0;
sbit PR=P1^1;//录放控制端,通过开关来调节,高电平为录音状态
sbit ISD_INT=P1^2;//溢出中断
sbit AN=P2^4;
sbit STOP=P2^5;
void delay(uint time)
 while(time!=0)
  time--;
void delayms(uint time)
 TMOD=0x01;
 for(time;time>0;time--)
  TH0=0xfc;
  TL0=0x18;
  TR0=1;
  while(TF0!=1)
  TF0=0;
  TR0=0;
void spi_send(uchar isdx)
 uchar isx_counter;
 SS=0;
 SCLK=0;
 for(isx_counter=0;isx_counter<8;isx_counter++)
  if((isdx&0x01)==1)
   MOSI=1;
   MOSI=0;
  isdx=isdx>>1;
  SCLK=1;
  delay(2);
  SCLK=0;
  delay(2);
void isd_stop(void)
 delay(10);
 spi_send(0x30);//停止录放
 SS=1;//语音芯片没有被使能
 delayms(50);
void isd_pu(void)
 delay(10);
 SS=0;//语音芯片被使能
 spi_send(0x20);//语音芯片进入待命状态
 SS=1;
 delayms(50);
void isd_pd(void)
 delay(10);
 spi_send(0x10);//芯片停止本次操作进入省电状态
 SS=1;
 delayms(50);
void isd_play(void)
 LED=0;
 spi_send(0xf0);//在下一个地址开始放音
 SS=1;
void isd_rec(void)
 LED=0;
 spi_send(0xb0);//在下一个地址开始录音
 SS=1;
void isd_setplay(uchar adl,uchar adh)
 spi_send(adl);
 adh=adh|0xe0;
 spi_send(adh);
 SS=1;
void isd_setrec(uchar adl,uchar adh)
 spi_send(adl);
 adh=adh|0xa0;
 spi_send(adh);
 SS=1;
void isd_overflow(void)
 while(AN==0)
  LED=1;
  delayms(300);
  LED=0;
  delayms(300);
uchar chk_isdovf(void)
 SS=0;
 delay(2);
 SCLK=0;
 delay(2);
 SCLK=1;
 SCLK=0;
 delay(2);
 if(MISO==1)
  SCLK=0;
  SS=1;
  isd_stop();
  return 1;
  SCLK=0;
  SS=1;
  isd_stop();
  return 0;
 uchar ovflog;
  P0=P1=P2=P3=0xff;
  while(AN==1)
   if(AN==0)
    delayms(20);
  isd_pu();
  isd_pd();
  isd_pu();
  if(PR==1)
   delayms(500);
   isd_setrec(0x00,0x00);
   do
    isd_rec();
    delay(20);
    while(AN==0)
     if(ISD_INT==0)//判断中断输出(漏极开路输出)。当存贮器溢出或放音结束标志出现时,该端为低电平并保持
     isd_overflow();//当芯片溢出时LED闪烁
    if(ISD_INT==0)
     break;
    LED=1;
    isd_stop();
    while(AN==1)
     if(STOP==0)
     break;
     if(AN==0)
     delayms(500);
   }while(AN==0);
   while(AN==0)
   isd_setplay(0x00,0x00);
   do
    isd_play();
    delay(20);
    while(ISD_INT==1)
    LED=1;
    isd_stop();
    if(ovflog=chk_isdovf())
     break;
    while(AN==1)
     if(STOP==0)
      delayms(20);
     if(STOP==0)
      break;
     if(AN==0)
      delayms(20);
    LED=0;
   }while(AN==0);
  isd_stop();
  isd_pd();
【关闭窗口】
相关文章
